4HI, ABS Traction Control, Lights on
Discussion in '2nd Gen Tundras (2007-2013)' started by Tayray, Dec 20, 2023.
  1. Dec 20, 2023 at 6:04 PM
    Tayray
    Tayray [OP] New Member
    Taylor
    2013 Silver Sky Double Cab Tundra
    Over the past week of driving I’ve noticed my 4HI light flashing, ABS light on and the traction control light is on.
    I have unplugged the battery for 30 minutes hoping it would reset and it did not.
    I went to an auto parts store for them to read the codes and they said they can’t read anything because the check engine light is not on.
    Any help or suggestions would be great.
    I’ve heard maybe transfer case actuator, or some sensor related.
    kandreas likes this.
  2. Dec 20, 2023 at 6:08 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    When was your battery last replaced? Did they test your battery?
  3. Dec 20, 2023 at 6:11 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    Could be battery, abs sensor, wheel speed sensor. Lots of threads on here with the symptoms you’re describing.
    any work done to the wheels lately?
  4. Dec 20, 2023 at 6:20 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    An OBD reader will narrow down the problem. Get an OBD reader ($20) and scan your own codes and tell us what it says.
  5. Dec 22, 2023 at 4:42 AM
    kandreas
    kandreas New Member
    Kent
    2007 tundra SR5
    This is such a common issue, I think it might be in the wheel speed sensor harness somewhere> Currently have the same issue, wonder if you can put the truck in and out of 4wd.. mine won't unless I shut it down and restart it.
  6. Dec 22, 2023 at 11:07 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    That's what he tried to do
    Did they actually physically hook up the scanner or just say what you stated here?
  7. Dec 22, 2023 at 6:49 PM
    Tayray
    Taylor
    Battery has been checked, all good. New tires were put on last month. They just said they can’t really read the scanner because my check engine light is on.
    When I first start to accelerate it feels like something is trying to spin (maybe go into 4hi) and then when I brake the brakes become mushy and then after a minute they brakes work fine again.
  8. Dec 23, 2023 at 2:35 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
