Torque converter shutter when passing.
Discussion in '2nd Gen Tundras (2007-2013)' started by FilchedToyoResto, Dec 22, 2023.
  1. Dec 22, 2023 at 7:43 AM
    FilchedToyoResto
    FilchedToyoResto [OP] New Member
    2007 Toyota tundra 4x4 with 240,000 mi on the truck. There is a shutter from the torque converter when passing a vehicle on freeway speeds going 60 to 70 mph I guess going into 5th or 6th gear? I don't know for sure what gear The truck is going into, but there is definitely a shutter going into gear at higher speeds at a high RPM. Every other gear is fine.
    Would changing out the transmission fluid be a possible solution for the shutter?
  2. Dec 22, 2023 at 8:33 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Possibly, has the fluid ever been serviced? I would certainly do a drain and fill (not flush!) if you have never done it.
  3. Dec 22, 2023 at 9:53 AM
    FilchedToyoResto
    To be honest, I don't believe it's ever been serviced.
    I usually service the transmission every time I get a used vehicle. Anyways. It's most likely overdue IMHO.
  4. Dec 22, 2023 at 12:03 PM
    MyActualName
    MyActualName New Member
    This sounds stupid (because it is) but check your air filter and replace if dirty. Being down on airflow impacts 5th and 6th gear performance.
    My 17 had a small shutter that was like the trans wanted to drop a gear going up hills but couldn't quite convince the computer to do so. Replaced my dirty air filter with a clean one and been fine since. YMMV.
  5. Dec 22, 2023 at 12:29 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Additionally check that bypass hose at the front of the intake manifold. Heat may get to it and split it causing issues with throttle response and transmission hesitation. The bypass hose goes from the center of the intake, once you open the hood dead center there will be a hose that U-turns below the throttle body. If it's cracked, replace it, I think it's like $20, but purchase a throttle body gasket as well since you will need to remove it in order to replace that hose, cuz it goes underneath it and U-turns back in. The new hoses have heat protection almost right up to the intake manifold. I may have posted a pic and part number somewhere. I don't remember where.
  6. Dec 22, 2023 at 12:34 PM
    blackdemon_tt
    This is what I'm talking about, that hose by the red circle and was replaced with pics below. Most of my shutters stopped after I replaced this and a loss of throttle response trying to overtake an 18 wheeler and got nothing.
  7. Dec 22, 2023 at 12:38 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    My 07 4.7 does this as well only at higher RPMs, will shift into final gear no problem at lower RPMs, will sometimes do it if I hang onto S4 in town at 2.5k though. Transmission services have been logged on scheduled, through cooler lines.
    I also have a whine while stopped at lights or signs, which goes away when I throw it into N.
    Am I also looking at a TC issue? I’ve been stressing about the whine / whistle, don’t really want to throw a few thousand at it right now
  8. Dec 22, 2023 at 12:42 PM
    blackdemon_tt
    I have the same while or whistle, but while driving. Assuming I didn't replace my gasket the 2nd time I removed the throttle body to reset the intake hose since it slipped inward toward the throttle, because I placed the edge of the intake too far out.
  9. Dec 22, 2023 at 12:45 PM
    MEWaters
    MEWaters New Member
    Maine
    My fluid was done 20k ago. Don’t hear while driving. Should I just ignore it or be concerned lol
    blackdemon_tt[QUOTED] likes this.
  10. Dec 22, 2023 at 6:11 PM
    blackdemon_tt
    LOL.. idk, at this point if it moves efficiently I'm nit worried about it.
  11. Dec 22, 2023 at 8:11 PM
    Dr_Al
    Dr_Al New Member
    Al
    The 2007 and 2008 5.7s had a service notice for the torque converters. The shuttering could be it locking or unlocking. If so it's the clutch inside is moving freely. When it doesn't move freely it slips, that's causing vibrations. Think of a pressure plate in a clutch not being able to move freely when the driver presses or releases the clutch pedal.
    In 2009 they changed the design. People who complained got their torque converter replaced. If you didn't complain Toyota assumed it was good. You are well out of warranty so you're on your own. It only happens in 4th, 5th, and 6th gears because that's the only gears the computer will lock up the torque converter. It could happen when the engine needs a little more power and the computer unlocks the
  12. Dec 22, 2023 at 8:18 PM
    MEWaters
    MEWaters New Member
    Maine
    Did they send out service campaign memos to the owners or was it just an if you know you know thing. They’re still replacing frames on first gens.
    I might see if I can get lucky and get mine done LOL. I’m a relatively new owner of it
  13. Dec 22, 2023 at 8:32 PM
    Dr_Al
    Dr_Al New Member
    Al
