  1. Sep 2, 2017 at 5:15 PM
    #8791
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Mlucas555, where did you get your 50cal antenna?
  2. Sep 2, 2017 at 5:21 PM
    #8792
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Go Tigers!
  3. Sep 2, 2017 at 5:29 PM
    #8793
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    I got it on eBay, for about $16. It was one of the few that said that it fit our trucks.
  4. Sep 2, 2017 at 5:35 PM
    #8794
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    Added some dirt from Tucson, AZ. Back side of Mt Lemon.
  5. Sep 2, 2017 at 6:43 PM
    #8795
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Just picked one up but cost $27.
    mlucas555 likes this.
  6. Sep 2, 2017 at 7:01 PM
    #8796
  7. Sep 2, 2017 at 7:44 PM
    #8797
    Tundra Pirate
    Tundra Pirate Bamf
    Kelly
    Stanley, NC
    2014 Super White Tundra Crewmax 4x4 Limited
    Bilsteins 5100 Leveled Method NV Machine KO2
  8. Sep 2, 2017 at 9:50 PM
    #8798
    xoni
    xoni New Member
    Gordon
    2017 Cement Tundra TRD Pro
    Today, 9/2/17 I installed a driver's grab handle (easy-peasy) and the TRD cold air intake on my new TRD Pro. Good additions to an already great truck.IMG_2183[1].jpg IMG_2187[1].jpg IMG_2188[1].jpg
  9. Sep 2, 2017 at 10:36 PM
    #8799
    Desert Dawg
    Desert Dawg New Member
    Paul
    Albuquerque, NM
    2015 Tundra CrewMax 1794 Edition 4X4
    • King OEM Performance Series Suspension • Toytec Front Differential Drop (4x4) • Total Chaos Upper Control Arms • ReayLift Rear 1-inch Block • Coachbuilder Billet +3-inch Rear Shackles - Billet Carrier Bearing Drop Kit - Poly Bushing Kit • ICI Magnum RT Front Bumper with Winch Mount • ICI Rear Bumper with Sensors • ICI Skid Plate • Factor 55 Blue Prolink Shackle Mount' • Smittybilt Gen2 X20 Wireless 12K Comp Series Winch • Smittybilt Hawse Fairlead • Nitto Ridge Grapplers (LT295/65R20 • TIS 535B Satin-Black Alloy Wheels - 20x9 with +18MM Offset • Tundra Pro Grille Insert (Paint to Match) • De-chrome Modifications - PTM Upper Hood Bulge - PTM Grille Surround - PTM Front Bumper End Caps - PTM Door Handles - PTM Mirror Skull Caps • ESP Powder Coated Aluminum Locking Rear Seat Storage Unit • Falcon Zero F170HD+ Dash Cam with GPS • Escort 360MAX • A.R.E. Z-Series Topper with Yakima Roof Track System • Yakima Rack System • LINEX Spray-on Bed Liner • Bed Rug Bed Mat • Rigid Industries 30-inch Dual Row LED Light Bar • Rigid Industries 20-inch Blue Radiance LED Light Bar • Rigid Industries D2 Fog Lights • Air-on-Board LED Light Bar Switches • Air-on-Board LED Dual-Switch Panel • VIAIR 400P Portable Air Compressor • Maxout Chrome Dry Chemical Fire Extinguisher • AMP Research Retractable Power Steps • AntennaX Black Billet (14-inch) • Front Window Tint (to match)
    Here are some of the interior.
    Looking up at headliner:
    Showing match up of large front picture window with Tundra rear widow, large side window, and match between headliner and Bedrug:
    Front window folded down showing pass through into cab:
    Pass through from cab back into bed space:
    Looking from rear seat into bed space:
    Overall look again with Yakima crossbars installed:
  10. Sep 3, 2017 at 12:56 AM
    #8800
    TRDpro619
    TRDpro619 Follow My Build on Instagram:TRDorcaTUNDRA
    San Diego
    TRD Pro CM
    What bed rack is that?
  11. Sep 3, 2017 at 5:33 AM
    #8801
    Tundra Pirate
    Tundra Pirate Bamf
    Kelly
    Stanley, NC
    Looks like 3 Relentless Fab cross rails.
  12. Sep 3, 2017 at 6:38 AM
    #8802
    xoni
    xoni New Member
    Gordon
    Thru the rear window it sorta looks like an unfinished Sequoia.
    Desert Dawg likes this.
  13. Sep 3, 2017 at 6:45 AM
    #8803
    Darth Tundra
    Curt
    17 CM TRD Black
    Pro grille and hood bulge ordered Friday :bananadance:
  14. Sep 3, 2017 at 7:40 AM
    #8804
    Kdgcng
    Kdgcng Rock steady
    Kyle
    2017 Magnetic gray tundra SR5 crewmax
    How'd you get the on and everything?
  15. Sep 3, 2017 at 9:18 AM
    #8805
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    It's really easy. That part around the shifter pops off. Once it's off, just pull the shifter boot through the bottom, then run the shifter through the hole in the boot and then snap it back in place. You can use the Tundra shift knob, but it doesn't look right with the boot. You need a shorter shift knob for it to look right.
  16. Sep 3, 2017 at 9:32 AM
    #8806
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    Mounted my flash lights driver & passenger side on ESP underseat storage
  17. Sep 3, 2017 at 9:45 AM
    #8807
    Desert Dawg
    Paul
    Albuquerque, NM
    Yeah, sort of does...lol. I am getting a full Bedrug Liner that will dress it up just a bit more.
  18. Sep 3, 2017 at 10:23 AM
    #8808
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Oil change today...what a bitch on wheels. Got the truck with 26k on it and took a trip, ran it up to 30k and needed the oil change. No problem I thought, this will be 5-10 minutes like it was on my Taco. Had to use a breaker bar on the filter housing to get it off, some dumbass over torqued the hell out of it. One of the tabs is bent almost 90 degrees from it being put on so tight. Thinking I should swap out the housing on the next oil change just because...
  19. Sep 3, 2017 at 2:50 PM
    #8809
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Tall relentless fab bed bars
  20. Sep 3, 2017 at 3:36 PM
    #8810
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Spent about two hours washing it inside and out- not that it was very dirty at all, but still :D
  21. Sep 3, 2017 at 4:35 PM
    #8811
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    All painted, just need to install....
    Tracker, edwin729, 4x4_Angel and 2 others like this.
  22. Sep 3, 2017 at 8:19 PM
    #8812
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    http://www.vleds.com/
    Just put in your vehicle info and it's under auxiliary lights. Best bet is to call them with vehicle info, which is what I did. They have a front kit that replaces and attatches to oem little bulb under dash on driver side, from there u just run them around to rear if u want that too, like I did. Hope helps good luck.20170624_201400.jpg 20170624_201340.jpg 20170621_165410.jpg The top row plus last 4 packages to my right foot is for footwell. Top row 1st on left is what plugs in place once removing factory small bulb under driver dash, the next 5 packs to right are the wire lengths to connect between led strips. Bottom row last 4 packs on right are the led strips. Keep in mind that's front and rear. Cut in half if u only want front. Pretty easy to do, good luck.
    iHacker, driverdog, JAMES and 5 others like this.
  23. Sep 3, 2017 at 9:00 PM
    #8813
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    One of my best mods...:thumbsup:
  24. Sep 4, 2017 at 1:33 AM
    #8814
    mgm16trdpro
    Northern NJ
    Awesome, glad u like, and glad I could be of some small assistance.
  25. Sep 4, 2017 at 1:41 AM
    #8815
    mgm16trdpro
    Northern NJ
    Unless of course you found that 1 on your own. I can't remember anymore. I've pointed so many people in that direction I can't remember who I pointed there and not. Lol. Awesome product no doubt. I got another 1 coming real soon. Working on the thread right now. I'll let u all know when I post it. I know a bunch of guys are interested. It's all hooked up and functioning.
  26. Sep 4, 2017 at 6:17 AM
    #8816
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    My "like" is in support of what you did - I did mine some time ago, but I agree VLEDS made it easy (I too have lost track of everyone I referred
    0. I used their LEDs for high powered backup lamps, cargo lamps (to match my white bed OEM bed LEDs) and on the interior, the vanity, map and dome lamps. I also updated my puddle lamps to LED using another vendor. Makes a big difference, but I really like VLEDS quality. My wife really likes them too!
    NewImprovedRon likes this.
  27. Sep 4, 2017 at 8:13 AM
    #8817
    Darth Tundra
    Curt
    17 CM TRD Black
    Love affair...i GET IT....On a separate note...hey Sean ,I ordered a '16 Pro grille for my 17 SR5 ...it will fit ???..Wondering if you know ?
  28. Sep 4, 2017 at 8:42 AM
    #8818
    Same body style, so yes.
    Darth Tundra[QUOTED] likes this.
  29. Sep 4, 2017 at 8:43 AM
    #8819
    Darth Tundra
    Curt
    17 CM TRD Black
    Thanks for replying...ya , Almaboy told me the same over in the green room
  30. Sep 4, 2017 at 8:55 AM
    #8820
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    o_O:crazy::facepalm: dumb AF....
    will never live in NY....sounds dumber and dumber each time i hear something about it.
