2021 front bench console mods?
Discussion in '2.5 Gen Tundras (2014-2021)' started by steamcheng, Dec 28, 2022.
  1. Dec 28, 2022 at 10:26 AM
    steamcheng
    steamcheng [OP] New Member
    Davis
    Virginia
    2021 Tundra SR Double Cab Barcelona Red
    OK, I am not totally thrilled with the seatback "console" on the middle seat. It is just about useless as storage space the way it is layed out, and unless you always ride around with a Big Gulp for a drink, the drink holders are crap.
    Are there any mods anyone has seen or done? I have an idea to remove the headrest and make a proper drink holder on my 3D printer to attach into the mounting holes for the headrest. That'll give me a good drink and order-o-fries holder. At a minimum, I'd try making inserts for the stock drink holders to make them fit something I use.
    Also, what a about a drop-in console to put on the floor in front of the seat? I have seen some "console organizers" for cars and trucks, but they all seem too small for the area in front of the middle seat. Would like something I could install a wireless phone charging pad into and some other odd storage for things like tape measures, small tools, spare fuses, trailer bulbs, etc.
    Has anybody else come up with a good improvement to this?
  2. Dec 28, 2022 at 11:01 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I have the regular center console in my Tundra, but the cup holders look to be the same size between the center console and seatback console. I bought these to "right size" the cupholders:
    https://www.amazon.com/gp/product/B01MSBQ8AQ?ie=UTF8&th=1
    I had to trim the middle piece on the sides of the cupholder "adapter" a little bit to make them work, but now my 20 and 30oz Yetis fit perfectly.
    steamcheng[OP] likes this.
  3. Dec 28, 2022 at 11:43 AM
    steamcheng
    Davis
    Virginia
    Thanks. I have only just started looking at those cupholder adapters. I have a pretty significant road trip coming up in a couple of weeks and will probably find some of those that will work to make things more comfortable.
  4. Dec 28, 2022 at 12:05 PM
    Rocko9999
    Rocko9999 New Member
    Got any pics of them installed? I love my bench armrest console but the holders are too small for cans-they tip over.
  5. Dec 29, 2022 at 1:37 AM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    I've 3d printed some chicken nugget sauce holders (as well as some regular sized cup holders)
    A little hard to tell from this shot but I also replaced the headrest with a little tray table I made. I keep the headrest in the middle seat bottom storage in case I do need to utilize the seat (rarely)
  6. Dec 29, 2022 at 4:16 AM
    BlueCrushSC16
    Charleston, SC
    Here you go.
    Rocko9999[QUOTED] likes this.
  7. Dec 29, 2022 at 4:58 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Nothing fancy but made my own smaller cup holders with a piece of black plastic pipe and foam weatherstrip with adhesive backing.
    Works good and they come out if you need the large cupholder.
    For the floor got this organizer from Auto Zone. It’s a little too wide so I had to trim a little off the side with the cup holders on my table saw. (Pic is upside down, cup holders are next to the seat). I get two more cup holders and some useful storage.
    steamcheng[OP] and Rocko9999 like this.
  8. Dec 29, 2022 at 5:46 AM
    steamcheng
    Davis
    Virginia
    Thanks for the photos! That's pretty much what I had in mind for the headrest mod. Originally, I was thinking of making better cup holders and a feature to hold my french fries, but I can probably live with the existing cup holders if I make inserts like those shown by Northbound Train above. I like the sauce caddies, though. Great idea! My headrest mod might be a tray like yours or maybe add a phone stand with wireless charging pad.
    Thanks also for the photos and ideas. I may have to look at Auto Zone again. I did not find any organizers that big when I looked before, but I have a few other stores in my area to check.
  9. Dec 29, 2022 at 7:34 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I find the center console on mine to be pretty sufficient for my needs so only mod I did was hang a little trash pouch on the front of it using the headrest.
    Rocko9999 likes this.
  10. Dec 29, 2022 at 8:07 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    That dipping sauce holder is fantastic! Hella creative and utilitarian.
  11. Dec 29, 2022 at 8:21 AM
    Rocko9999
    Oh man that is Slick! I'd love to have that regular cup holder mod. Like I said, soda cans rattle all around in the stock opening.
  12. Dec 29, 2022 at 8:22 AM
    Rocko9999
    What type of pipe? Looks like it has a flare on the ends.
  13. Dec 29, 2022 at 1:31 PM
    Northbound Train
    Glenn
    Western MA
    It’s regular ABS drain pipe from Home Depot. I made the flare with a die grinder.
  14. Dec 29, 2022 at 1:44 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    [​IMG] I Bought two of these for my truck. They fit perfectly and take the large hole down to the size of an aluminum can. Amazing mod for 3 bucks.
  15. Dec 29, 2022 at 1:46 PM
    Northbound Train
    Glenn
    Western MA
    If interested, this is the storage bin on the AutoZone web site. Keep in mind it need to be trimmed to fit.
    steamcheng[OP] and Tundyfundy like this.
  16. Dec 29, 2022 at 4:40 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
  17. Dec 29, 2022 at 6:12 PM
    steamcheng
    Davis
    Virginia
    Ahhh! Fernco coupling? That's an excellent option!
    Thanks for the pointer to that thread! It didn't turn up in my searches, since I didn't think to look for stuff about the column shifter. There I go with my linear thinking again...;)
    Tundyfundy[QUOTED] likes this.
  18. Dec 30, 2022 at 5:56 PM
    brigand80
    brigand80 New Member
    Roman
    2017 Limited CM MGM 2WD
    Its Always A Work In Progress...Because Its A Labor of Love!! - aFe Pro Dry Filter + TRD Intake Flow Accelerator + Carbon Filter Delete - nFab Podium Steps - TRD Rear Sway Bar - TRD Pro Grill - Color Matched Hood Bulge, Front Bumper End Caps, Mirror Caps, Door Handles - Nightshade "Limited' Badges & Others De-badged - NSV LED Lightbar - Desert Eagle Offroad Catalytic Skid Plate - Craven Speed Untenna - Diaz Fabrication TEQ Trailer Hitch Cover - Klearz 3rd Brake Light Smoked Lens - Winjet Renegades Smoked Tail Lights - Headlight Revolution GTR Lighting LED Bulbs - Morimoto 4 Banger HXB LED Fog Lights (White) - XD 847 Outbreak 18x9 +12 5x150 - Gorilla Black Spline ET Lugs - AJT TRD Key Fob + Interior Chrome Delete Kit - TRD Shift Knob (Black) - JimmyRigged ToYoda Steering Wheel Emblem Overlay - JRT Tech 12 Front Dash JL Audio Speakers - K&N Cabin Filter - Chalk Bag Mod - Weather Tech Mats - Ceramic Window Tint
    Strider Wolf and steamcheng[OP] like this.
  19. Dec 31, 2022 at 5:10 AM
    steamcheng
    Davis
    Virginia
    Looks like you have the center console with floor shifter in yours instead of the center seat and column shift. I don't think the organizer you have would work with mine.
  20. Dec 21, 2023 at 2:31 PM
    SkipMGMXPSeries
    SkipMGMXPSeries New Member
    Robert Butcher
    Ocean County
    2021 MGM Tundra SR5 XP Series
    None at the moment....
    Just bought a 21 Crewmax with the bench seat...UGH!!! Stowage sucks in these things, the center seat has some but not enough and forget about putting anything under the back seat and or behind it...WTF. Looking at many threads and options to maximize the space available.
