1st Gen camper shell buying info
Discussion in 'Tonneau Covers, Caps and Shells' started by shifty`, Mar 26, 2021.
  1. Dec 18, 2023 at 5:52 AM
    #571
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Most of the fishermen I know keep the rods in the interior of the truck. I don't blame them as the rod/reel combos they are using are big money.
    The only problem with using a pipe as storage is the if you put anything in it that is shorter than the full length it will be right in the middle when you want to access it. Much bigger problem in 3-4 inch size.
    They sell nice aluminum caps that have a provision for a pad lock.
  2. Dec 18, 2023 at 6:04 AM
    #572
    shifty` [OP] Earth acid cleanses me, cleanses me clean
    $250 DC camper in eastern WV, bad paint but a nice Leer 100R like mine and it has windoors FFS:
    FirstGenVol and The Black Mamba like this.
  3. Dec 18, 2023 at 6:40 AM
    #573
    That's a great deal!! Already has the rack rails!
  4. Dec 18, 2023 at 6:43 AM
    #574
    Has everything I would want. And I'd need to refinish it anyway because it doesn't match. Someone could have one hell of a score right there. Bargain barrel pricing if you're near the KY/WV state line and have a DC.
  5. Dec 18, 2023 at 7:43 AM
    #575
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You're in a FB group with infidel tundras? Gross :burp:
  6. Dec 18, 2023 at 8:11 AM
    #576
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Have no clue what you speak of
  7. Dec 18, 2023 at 8:28 AM
    #577
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Are the rack rails something that can be added, or are they ordered that way from the factory because of the need to reinforce the fiberglass?
  8. Dec 18, 2023 at 8:33 AM
    #578
    ATBAV8
    Tempe, AZ
    It was a company called "Wildernest". the top opened up like a clamshell and there is a tent that erects. Pretty cool. I don't think they're made anymore.
  9. Dec 18, 2023 at 8:33 AM
    #579
    Can be added. The rack I used was the Rhino Vortex. Like $550. Spendy.
    ATBAV8[QUOTED] likes this.
  10. Dec 18, 2023 at 8:40 AM
    #580
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    theres one for sale on here
    https://www.tundras.com/threads/wildernest-for-sale-3000obo.120682/
    but 80" is a bit too long. But while researching on expedition portal i found a guy who'd had his tent section rebuilt by another company.
  11. Dec 18, 2023 at 9:44 AM
    #581
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It's not a 1GT exclusive FB group. Quite a few exist.
  12. Dec 18, 2023 at 9:51 AM
    #582
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Sales took in a 17 A/C Taco on trade with a Leer top. I measured it for fun. So excited to find the length at 78", so disappointed to find the width at 63"
  13. Dec 18, 2023 at 9:57 AM
    #583
    I see sooooo many Taco caps over here it's crazy. Lots of nice, nice ones too. It makes me sad.
  14. Dec 18, 2023 at 10:49 AM
    #584
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    I’ve seen pvc with some foam that looked like pipe wrap for a big assed pipe jammed in there with cutouts for the reels. With the reels dropped down in their little cut outs the rods couldn’t slide around.
  15. Dec 18, 2023 at 11:14 AM
    #585
    SharkDog
    SharkDog New Member
    Denver
    Here is a goofy, but functional, looking cap. upload_2023-12-18_12-14-37.png
    Nicklovin likes this.
  16. Dec 20, 2023 at 5:29 PM
    #586
    turtlecatcher
    turtlecatcher New Member
    2000 V8 AC 4WD Limited
    If anybody is in Florida and wanting a soft top. Not my cup of tea, but I'm not one to judge.
    Parenthetically--and apologies if this is "hijacking"--can anybody here with a Leer camper tell me where the serial number plate is located? I ended up picking up that black topper I posted a while back. Fit perfectly and was in pretty good condition--only problem was, no keys. To order a new lock I need the serial number, but the previous owner did a very good job of carpeting the inside, including covering the serial number plate. I don't really want to tear up all the carpeting to find the plate. I actually emailed Leer but they said it would be "on the ceiling," which isn't very descriptive.
  17. Dec 20, 2023 at 5:42 PM
    #587
    ATBAV8
    Tempe, AZ
    I just had to order new keys for my Leer Topper. No serial number needed. I just used the alphanumeric codes on the face of the locks, and ordered keys on Amazon. Not exactly the most secure system, but at least they lock. I'm sure you could do some "custom" lock job with a locksmith.
    455h0le_dachshund likes this.
  18. Dec 20, 2023 at 6:13 PM
    #588
    Yup, that info is back over here. 2nd set of bullets, 7th item.
    On newer Leers like the 100R, 100XR and similar, it's normally on the driver's side, just inside the rear door.
    You can see the right-hand rivet in the 1st pic here, you'll see it fully installed in 2nd pic (sometimes it gets removed if people carpet). Some older Leers (no outer flange/overhang) or longer Leers may have it a little farther forward like the 3rd pic. Some even older yet may have it a little further down on the rail like the 4th pic.
  19. Dec 20, 2023 at 7:03 PM
    #589
    turtlecatcher
    Thanks for the replies and photos--going to go out with a razor and check right now. If I can't find the serial number I'll just order new keys, but the lock was pretty janky, so if possible I'd like to get new hardware.
  20. Dec 20, 2023 at 7:06 PM
    #590
    Notice how in the 2nd pic, there's almost a shelf in that spot. You may be able to feel that? I can hardly feel mine because someone carpeted it and did a great job on the roof, but the work got pretty shoddy as you get down and into the corners. Then they re-clamped it while the adhesive was still wet. But the carpet is one of those things ... You can't peel up part of it and blend it in, it's pretty one-shot. So I'm sorta stuck with it.
  21. Dec 20, 2023 at 7:25 PM
    #591
    turtlecatcher
    Success. About two feet in on the driver's side on the flange. Thanks for all the help!
    shifty`[OP] likes this.
  22. Dec 21, 2023 at 11:34 AM
    #592
    Bass1
    Bass1 New Member
    Manuel Bassoco
    02 tundra tundra
    Will anyone know what this camper is worth ? Door is broke . I was told around $500 but want to make sure before posting forsale
  23. Dec 21, 2023 at 11:55 AM
    #593
    JakeJake
    2000 Tundra AC 4X4
    It's only worth what someone will pay for it. A buddy of mine recently picked up a similar model for $75. The seller had originally listed it at $500 and it hadn't sold in 5ish months.
    Jake Jakes pricing guide:
    Do you want it gone? $free to $100
    Do you want to wait (potentially forever) for the right buyer? $500+
  24. Dec 21, 2023 at 12:33 PM
    #594
    Offer 250 and then use a piece of plexiglass to repair the door. They have the panels at HD, just have to measure and make sure they have one long enough.
  25. Dec 21, 2023 at 12:46 PM
    #595
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  26. Dec 21, 2023 at 2:43 PM
    #596
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I really don’t know why I like these caps so much. Maybe not this tall, but I dig em.
  27. Dec 21, 2023 at 2:55 PM
    #597
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I've decided i am going to have to cut a vent in the roof, but the fan is going to have to be removable, so i can open the back window, stand through the vent, and piss without putting shoes on. If the wind isnt cooperative, maybe i'll have a funnel or something.
    I dont NEED a hitch tray, but it is a handy step, not too hard to find an excuse.
    just have to load it so the tailgate still works.
    wonder if FT wondered what happened to his milk crate...it holds my extra wood & empty bottles.
    FrenchToasty and The Black Mamba like this.
  28. Dec 21, 2023 at 5:11 PM
    #598
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Why not just cut a hole in the bed and run a piece of PVC down.
  29. Dec 21, 2023 at 5:15 PM
    #599
    JakeJake
    2000 Tundra AC 4X4
    Holy shit man, just keep some sandals handy.
    Colder than about 20° I have a yellow Nalgene. Don't ever drink out of the yellow Nalgene :rofl:
  30. Dec 21, 2023 at 5:22 PM
    #600
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    My nalgene is a staple. We'd have to be careful.
