General Supercharger Thread
  1. Dec 20, 2023 at 9:17 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    We should be witnessing some type of nuclear reaction going on through that intake window.
  2. Dec 20, 2023 at 9:18 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    It's awesome he said when they used it once lol. Much easier than the turtle back for sure
    Mdl likes this.
  3. Dec 20, 2023 at 9:25 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    We can't ignore all the gobs of hp made with 90mm TB's.
    reywcms[QUOTED] likes this.
  4. Dec 20, 2023 at 9:34 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Well I appreciate baselining anything I have! Though there's better tuners out there that will be able to get more power out of your setup than I, so I would seriously consider OTT, Prospeed, YotaWerx, etc. but I'll tune anything you have if you still want me to :D with all of that said, yes I like the PSB-1 since it has a lot of features and displays both boost and AFR in one gauge. Though AEM or any other brand is fine too, it's really whatever features and aesthetics you prefer, at the end of the day a wideband is a wideband.
    Fastlane47, ARES35, mZiggy and 4 others like this.
  5. Dec 20, 2023 at 9:38 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Alot of coin only to use it Once,hope it works out for him they are nice...but wall pannel issues yikes
    Mdl likes this.
  6. Dec 20, 2023 at 9:46 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea they switched materials but apparently didn't do well in high heat areas. So they replaced them. Shouldn't be an issue moving forward. Yep once since they've got it since it's been back at the shop. Be awhile before they use it again since now the Tundra is in the shop for a full suspension revamp among other things. He's consider the new ZR2 Silverado bison for a tow rig but we will see how it shakes out.
  7. Dec 20, 2023 at 10:52 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Possible ignition coil improvement/upgrade? These are from the Lexus 8AR FTS engine. Direct injection, lean burn, turbocharged with up to 17 psi. Gap for the plug is .035/.9mm… those plugs look nice, too. One coil inbound for inspection.
    73446D2A-27AE-4FAC-9E63-65AEB0C41A6E.jpg 707AFCCD-6EC8-45EC-B3FA-F469DC5BBF32.jpg 50904D4F-DEE4-48A8-87A2-702653A5F8D3.jpg
    ARES35, reywcms, Wynnded and 2 others like this.
  8. Dec 20, 2023 at 11:24 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That looks like some serious reach on those plugs though.
    Mdl likes this.
  9. Dec 20, 2023 at 11:49 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    It does look looong, but same as the stock plugs. Here’s the features sheet… designed for less quench.
    Wynnded, reywcms and Mdl like this.
  10. Dec 20, 2023 at 11:52 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I was heading on the on ramp to hwy and with the 4.5 inch intake and the 103mm TB I got a p0101 code. Hmm I do need a data log.
  11. Dec 20, 2023 at 12:10 PM
    nchlsbr
    nchlsbr New Member
    2018 Tundra
    Looking for any tips to get the stock pulley off of the supercharger. Using a Snap on Puller and it isn’t wanting to come off. Felt like it was bending the pulley. Any help is appreciated!!
  12. Dec 20, 2023 at 12:33 PM
    snivilous
    SW UT
    I bought this shitty 3-jaw set and it's taken two off so far without issue. Definitely depends though, one came off easy, the other one definitely did not want to come off.
    https://www.amazon.com/dp/B084SV21FP?ref=ppx_yo2ov_dt_b_product_details&th=1
    Fastlane47 and nchlsbr[QUOTED] like this.
  13. Dec 20, 2023 at 12:33 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    If the other guys who have actually done it say a method works I’d listen to them. That said if I personally had to try and do it I would try heating up just the pulley (not the hub) with a map gas torch until it is about 120-150 degrees warmer than the hub. I use this method for mounting interference fit bearings on motor shafts at work. They slide on like butter, despite the ID of the bearing being smaller than the OD of the shaft when they’re both the same temp.
    Mdl and nchlsbr[QUOTED] like this.
  14. Dec 20, 2023 at 12:40 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Maf code? Wonder if it's maxing it out or tune adjustment?
    Mdl[QUOTED] likes this.
  15. Dec 20, 2023 at 1:20 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Out of range code. Hadn't come back. The MAF is scaled pretty spot on. But who knows. Add another SABM. Ha
    ssmokedz and reywcms[QUOTED] like this.
  16. Dec 20, 2023 at 1:21 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    use a 6-ton 3 jaw puller. the smaller ones don't work so well
    nchlsbr[QUOTED] and Mdl like this.
  17. Dec 20, 2023 at 1:22 PM
    M3Tundra-JK
    Scott
    2005 GX470
    They even have it in GOLD! @reywcms
    Orion Motor Tech Gear Puller Set, 3" 4" 6" 8" 3 Jaw Puller Kit for Pulley Gear Bearing Flywheel Removal, Heavy Duty Pulley Puller with Reversible Jaws 4 pcs Bearing Puller Tool Kit https://www.amazon.com/dp/B08JLF4JDF
  18. Dec 20, 2023 at 1:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Mine was a bitch getting off. I wound up cutting it off as the shaft was getting mushroomed. Can I say that in the same sentence? Haha. Definitely try heat. I saw a 7 ton 2 and 3 jaw craftsman puller that had decent faced jaws for good purchase on the pulley.
    M3Tundra-JK, ARES35 and reywcms like this.
  19. Dec 20, 2023 at 2:37 PM
    ARES35
    ARES35 New member for life
    Mile high
    Oh yes I see that Hubble reflective gold shining bright there! :D
    Saltyhero13 and reywcms[QUOTED] like this.
  20. Dec 20, 2023 at 6:12 PM
    nchlsbr
    nchlsbr New Member
    2018 Tundra
    Got that bad boy off with a little heat. And you can’t say that in the same sentence. Haha
  21. Dec 20, 2023 at 6:52 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That the second time this year I remembered when I was on the ship. Doing some pump repairs. Getting the bearings out of the galley stove, running with big oven mitts on to the engine room yelling, get out of the way, to get the bearings on before they cooled. Fun times...
    e30cabrio, ARES35, nchlsbr and 2 others like this.
  22. Dec 20, 2023 at 7:01 PM
    Silver17
    Eastern PA
    You repaired mechanicals on a ship? Sounds like a cool job! And yeah I get that. I usually used a bearing cone heater made specifically for heating bearings, which made it a whole lot easier. Kind of need a torch though for the removal part though of course.
  23. Dec 20, 2023 at 7:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @Silver17 Back in 1987 when I was in the USCG. No luxuries back then...ha
    e30cabrio, Fastlane47 and Silver17 like this.
  24. Dec 20, 2023 at 7:51 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Sounds like a mini-ductor heat gun would help a ton pulling them off.
    Mdl and Silver17 like this.
  25. Dec 21, 2023 at 11:54 AM
    ARES35
    Mile high
    Any of you guys having trouble getting lined out for some tuning? I understand it's holiday season so maybe the reason. I've reached out to 3 specific tuners in past weeks but not a word back. Trying to get dialed in once pulley is swapped. Really wish this kit came with the tuner suite and MPVI3 instead of this remote tuning with RTD bullshit id adjust myself but it is what it is:(. Last one to try is OTT I guess
  26. Dec 21, 2023 at 12:01 PM
    JustDSM
    JustDSM New Member
    Justin
    We are an HPTuners authorized retailer. We can can get you setup with an MPVI3 and/or tune you with your existing RTD. Shoot us an email if you need a hand.
    e30cabrio, Mdl, Silver17 and 5 others like this.
  27. Dec 21, 2023 at 12:27 PM
    ARES35
    Mile high
    @JustDSM Will do thank you!
    Mdl and JustDSM[QUOTED] like this.
  28. Dec 21, 2023 at 2:01 PM
    ARES35
    Mile high
    Wow quick delivery thank you @snivilous you the man! Sticker has been installed for more power of course, now just admiring these beautiful shiny circles. The 70mm looks brutal!..... I will call it the widow maker:):headbang:
  29. Dec 21, 2023 at 2:21 PM
    nchlsbr
    nchlsbr New Member
    2018 Tundra
    Anybody have any experience with a bad set of DW 650cc injectors. Everything data wise is pointing to a bad set. Wondering if getting DW to swap them or send another set is something that can be done? Or any alternative brands to check out?
    Mdl likes this.
  30. Dec 21, 2023 at 2:31 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Nope never had an issue. I’m sure they’d swap them out. But seems all would be bad, what issues are you having?
