Coolant pH test strips, anyone trust them, use them?
Discussion in '2nd Gen Tundras (2007-2013)' started by KeepOnTruckin, Dec 20, 2023.
  1. Dec 20, 2023 at 12:18 PM
    KeepOnTruckin
    KeepOnTruckin [OP] New Member
    Randy
    2010 4.6 4x4 Bare Bones
    I grabbed the Tundra used and the previous owner had several records for basic maintenance and generally tried to do the right thing. Even had the pan dropped on the trans which when I did it at 110k, was spotless. It's a 2010 4.6.
    I'm curious if anyone trusts these pH test strips? I have SLLC but the weather is crap so I used a test strip to see if I can push this out until spring? It tested well. Is it newer or pushing 14 year old coolant Idk...
    #coolant ph testing
  2. Dec 20, 2023 at 1:56 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    It depends on whether your coolant uses an organic acid. Even then, that's for corrosion resistance. I don't know if pH can measure freezing or boiling point metrics.
