Rear suspension
Discussion in '3rd Gen Tundras (2022+)' started by Tj3, Dec 17, 2023.
  1. Dec 17, 2023 at 10:18 AM
    Tj3
    Tj3 [OP] New Member
    Tj
    2023 tundra limited crewmax
    Ruff country 6” lift
    Just put the 6” RC lift on my 23 with rear air ride and now it’s sagging in the rear and feels like the rear air ride shocks are either maxed out bounces wile driving down the rd like there blown out/nothing back there feels like it’s bottoms out anyone know what’s going on taking it back to shop Monday they couldn’t figure it out and it got late
  2. Dec 18, 2023 at 6:34 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    memario1214 likes this.
  3. Dec 18, 2023 at 7:33 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Is the air ride still installed? Did they max out the bags and it's creating a stiff rear end? Can you post a picture of your rear setup?
    Tj3[OP] likes this.
  4. Dec 18, 2023 at 8:59 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
  5. Dec 19, 2023 at 10:09 AM
    Tj3
    Tj3 [OP] New Member
    Tj
    Yes rear end is sagging truck is back at the shop and they can’t figure it out
  6. Dec 19, 2023 at 10:12 AM
    Tj3
    Tj3 [OP] New Member
    Tj
  7. Dec 19, 2023 at 10:12 AM
    Tj3
    Tj3 [OP] New Member
    Tj
  8. Dec 19, 2023 at 10:12 AM
    Is this shop in North Carolina o_O
    des2mtn and Tj3[QUOTED][OP] like this.
  9. Dec 19, 2023 at 10:14 AM
    Tj3
    Tj3 [OP] New Member
    Tj
    I’m not sure what the did I just know it’s messed up feels like a Lincoln when the air ride is out missed 2 days of work today is the 3rd day and they can’t figure it out air bags and suspension were fine when I took it in
  10. Dec 19, 2023 at 10:15 AM
    Tj3
    Tj3 [OP] New Member
    Tj
    Shop is in Salem Oregon I wanted a lift not a low rider
  11. Dec 19, 2023 at 10:17 AM
    The rear is not lifted. They missed something. did they re-use the factory shocks? Is there any error messages about the airride? Have they ever installed one of these before? I see lots pf brackets back there presumably to relocate the components to accommodate the lift. Does the rear bag look like it has any air in it?
  12. Dec 19, 2023 at 10:24 AM
    Tj3
    Tj3 [OP] New Member
    Tj
  13. Dec 19, 2023 at 11:18 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I can't see how they lifted the rear, I'm new to this setup but I feel like something is definitely missing.
  14. Dec 19, 2023 at 12:14 PM
    Breathing Borla
    AZ
    lol, what in the actual hell did those guys do to that poor tundra
  15. Dec 19, 2023 at 1:12 PM
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Is it possible they didn’t install the extended rear air leveling arms? And its stuck in trying to keep the rear air bags in the stock height position?
    Breathing Borla likes this.
  16. Dec 19, 2023 at 1:33 PM
    teab
    Ty
    Denver
    @Tj3 Did you purchase aftermarket shocks for the lift as well that have the appropriate travel? As @KNABORES mentioned. If you didn't order new shocks that were designed for that rear lift which is probably about 5" (in the rear). If that is the case the factory shock would limit the up travel of the airbag and it would keep inflating and inflating till the airbag goes POP!. The factory shocks would prevent the relocated level sensor for the air ride from ever reaching ride height and the bags would get rock hard (being held down by factory shocks) probably till a safety switch shuts them off and driving around the ride in the rear would be super stiff which could also make the airbags go POP too! That or it burned up your compressor motor that fills them. Or you could have blown a fuse on the airbag compressor. @Tj3 Elaborate a little more..... if you have errors on the dash share them too, etc. ....there are a lot of very knowledgeable people on here and we can help you just need more detail.
    You for sure have a Carolina squat truck currently. Call Whistlin Diesel and he'll put er out of its misery. Give us some more detail!
  17. Dec 19, 2023 at 1:51 PM
    teab
    Ty
    Denver
    Also judging by the pics it looks like those might be factory black Hitachi shocks and looking at the instructions sheet for that lift kit it doesn't look like the kit came with new shocks. Looks like the rear end is sitting on the extended bump stops.
  18. Dec 19, 2023 at 1:57 PM
    teab
    Ty
    Denver
    Well maybe not I take that back the rear shock looks like it has a grade 8 bolt and nyloc nut on it...somebody swapped that hardware out so presumably it was to change the shock out? WTF?? did they lose the hardware and decided to just throw a grade 8 bolt in there? I have so many questions.
  19. Dec 19, 2023 at 2:04 PM
    Likely a shock mount extension to make up for the lift and retain the factory shocks. Not a fan
  20. Dec 19, 2023 at 2:07 PM
    teab
    Ty
    Denver
    Oh yep sure as shit...Rough country cheap dog Shit!!!
    From their instructions there is the shock extension....
