03 tundra wire harness discrepancy
Discussion in 'Audio & Video' started by Phil Liebo, Dec 19, 2023.
  1. Dec 19, 2023 at 5:24 AM
    Phil Liebo
    Phil Liebo [OP] New Member
    Phil
    03 tundra 4wd
    Hi! I have 2 ‘03 tundras. One is a four-wheel-drive and one is a 2 Wheel Dr. I am trying to hook up a new head unit and amp, my 4wd one has a 20 pin connector only. The 2 Wheel Dr. has a different style connector with two separate connectors. A 10 pin and a 6 pin. Why would these two trucks have different stereo harness connectors? when you buy a wire harness from auto parts store or online, they seem to be the 10 pin with a separate second connector. I found a 20 pin at AutoZone, but it only has the RCA leads out and I need one that has speaker wire leads out Any suggestions?
