2007 tundra wiring diagram
Discussion in 'Electrical' started by Bud1623, Aug 26, 2023.
  1. Aug 26, 2023 at 2:21 PM
    Bud1623
    Bud1623 [OP] New Member
    Bud
    2007 Tundra 5.7 SR5 Silver
    none
    Im trying to install a back up camera and I need to identify the positive wire going into the backup light.
    Thanks Bud1623
  2. Aug 26, 2023 at 2:37 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    IIonPilgrimg likes this.
  3. Aug 26, 2023 at 2:41 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Just for giggles, the other wires on your tail light.
    R4 and R5
    upload_2023-8-26_16-39-3.pngupload_2023-8-26_16-39-28.pngupload_2023-8-26_16-40-6.png
  4. Aug 26, 2023 at 4:38 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    I would assume you mean the trigger wire at the back of the radio headunit that tells the radio when the truck is in reverse?
  5. Dec 19, 2023 at 12:39 AM
    IIonPilgrimg
    IIonPilgrimg New Member
    2008 Tundra Limited Double Cab 4x4 5.7 6-speed Red Rock
    Interesting...
    My 2008 schematic shows (I've confirmed visually) easy access at J77 (Pin #8 - Red).
    Mine transitions to Violet at the other end (Pin #6). Yours appears to transition to Blue (Pin #7) ... Our J77 junctions may have different pin counts.
    While you're under there, you might tap the Parking Brake wire also... Tan or Beige wire (you may need it if you ever install a DVD or Nav head unit.)
