King OEMs on 24 Tundra with 3” Factory Lift Questions.
Discussion in '3rd Gen Tundras (2022+)' started by thatyotayacht, Dec 4, 2023.
  1. Dec 4, 2023 at 1:51 PM
    thatyotayacht
    thatyotayacht [OP] New Member
    Southern California
    2024 TUNDRA LIMITED TRD OFF-ROAD
    Hello everyone! I have a 2024 Tundra with the factory 3” Suspension Lift Kit (3inch front, 2inch rear). I really enjoy the ride height of the vehicle now however it rides like crap on and off-road. I’m looking to purchase king OEM shocks, however am confused on spring rates. I’ve tried to see what is on it now, however haven’t had any luck. I’m planning on purchasing the shocks through accutune and having them tune before delivery. My question is will I need to adjust the shock collar down to almost max with the 650lb spring + tune in order to receive the desired 3 inches of lift up front? Or should I get a stiffer spring (700lb) to not have to adjust the collar as much. The goal is to get as much comfort and travel as I possibly can with the ride height I have. A picture of my truck will follow for reference, thank you!
    AccuTune Offroad likes this.
  2. Dec 4, 2023 at 1:57 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    @AccuTune Offroad is here and can assist. They’ll recommend and set the suspension correctly per the needs of the truck.
    Sierradevil and AccuTune Offroad like this.
  3. Dec 4, 2023 at 4:12 PM
    mass-hole
    mass-hole New Member
    My guess is you could have them install a slightly taller 650 lb spring so that you dont have to run as much preload on the collar.
  4. Dec 4, 2023 at 4:36 PM
    Hella Krusty
    Hella Krusty New Member
    That truck looks awesome ....well done
  5. Dec 4, 2023 at 4:43 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Put a few thousand miles on it.
    Should settle down a bit.
    What pressure are you running your larger E rated tires?
  6. Dec 4, 2023 at 5:57 PM
    thatyotayacht
    Southern California
    Running them at 45PSI at the moment. Also have 3k miles on the truck, rides a bit better than when I took delivery but still really stiff.
  7. Dec 4, 2023 at 8:04 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    I just passed 10k miles and either I don’t notice how tight it is anymore, or it is less noticeable.
    Likely I’m just used to it now.
    My Tire pressure is around 42 now with cooler weather.
  8. Dec 8, 2023 at 9:47 AM
    PAtundra24
    PAtundra24 New Member
    What wheel/tire setup are you running? Looks perfect. Any rubbing?
  9. Dec 8, 2023 at 10:19 AM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    That truck looks sweet! Congratulations!
  10. Dec 8, 2023 at 10:55 AM
    thatyotayacht
    Southern California
    Thank you! Tires are Toyo Open Country R/T Trail 35x12.5x17 0mm Offset. Wheels are Method 314 in Black. These tires are the best I’ve ever had (coming from BFG and Falkens). Very quiet on road and very aggressive in slippery/wet conditions. Never have I lost traction once. Only thing I’d change is maybe a slightly more positive offset, however that’s just preference looks wise. My truck came with a Factory 3” Lift, all I had to do was remove the front mud-flaps and pin back the carpet with a zip tie. Full turning radius with no rubbing. More pictures to follow.
  11. Dec 8, 2023 at 11:39 AM
    PAtundra24
    I think that is the perfect and easiest setup from the factory. Well done.
  12. Dec 8, 2023 at 12:24 PM
    lgbtri15
    lgbtri15 New Member
    Ed
    Getting a less aggressive tire will help tremendously with ride quality. I don't how badly you need the type of tire you have, but an A/T tire will help you more than different struts IMHO.
  13. Dec 8, 2023 at 12:38 PM
    Roccahtx
    Roccahtx New Member
    Joseph
    2023 Silver Tundra 1794
  14. Dec 8, 2023 at 12:38 PM
    Roccahtx
    Roccahtx New Member
    Joseph
    What are your tire specs?
  15. Dec 9, 2023 at 8:39 AM
    Vipers28
    Vipers28 New Member
    Does the King OEM set require you to change the upper control arms and to extended CV axles? I have a Limited non-TRD but considering the Kings for my next upgrade.
  16. Dec 9, 2023 at 8:50 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    You're just changing shocks, no need for new axles. Upgraded UCA's are highly recommended.
  17. Dec 9, 2023 at 8:53 AM
    Vipers28
    Vipers28 New Member
    Thanks for the info. I wasn't sure as the Fox set up says to change CV's etc., and I really don't want to change that much on my truck
  18. Dec 9, 2023 at 9:03 AM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    I guess 3" lift from the FOX puts the CV's on a rather uncomfortable angle on non-TRD Off-Road/PRO trucks... seems rather arbitrary on Toyota's part... I'd be concerned about angle more than length.
    Vipers28 likes this.
  19. Dec 9, 2023 at 9:10 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    I own a 19 but I will say that does look amazing...good job.
  20. Dec 13, 2023 at 9:18 PM
    ncart
    ncart New Member
    Virginia
    2022 Lunar Rock TRD Pro
    Love the stance and look forward to hearing how the King’s affect the ride. If you do it.
  21. Dec 17, 2023 at 9:59 PM
    thatyotayacht
    Southern California
    It’s not mandatory to change out C.V. axles if you’re not long travel or going above 2.5 inches of lift. I’ve seen people run 2.5 inches of lift and their C.V. boots are not torn or leaking. I’d recommend going with the kit, but only run a max of 2 inches of lift via adjusting the preload on the shock collar. I’d also install an aftermarket UCA while you’re at it too (Total Chaos and Camburg seem to be the best imo).
  22. Dec 18, 2023 at 12:14 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    all the models except the Offroads and pros have a more angle limited axle design.(not a double CV axle. instead a tripod inner joint) that seems to be the only reason why toyota includes different axles for the TRD 3" lift (they might be a hair longer too. but i never checked that)
  23. Dec 18, 2023 at 11:50 AM
    Vipers28
    Vipers28 New Member
    Thanks for the info, just want to make sure I do things right the first time and not mess anything up.
    We have similar rigs, running RT 35's, white CM...also tow my side by side with it.
  24. Dec 18, 2023 at 4:11 PM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    Spring likely should not change for stock weight, although sometimes we drop in spring rate. These coilovers are adjustable and are intended to be adjusted to get the desired lift height. No need to stress it, our sales team can confirm all of that for you and make some recommendations. We just recently removed the Kings to start working on the Fox 2.5 shocks, so we have a pretty good tune ready for the Kings. Let us know when we can help!
