Ditch Light Hack: SS3 + SSC1 Pods | Diode Dynamics
Discussion in 'Lighting' started by Diode Dynamics, Dec 18, 2023.
  1. Dec 18, 2023 at 3:02 PM
    Diode Dynamics
    Diode Dynamics [OP] New Member
    If you haven't seen it, this is one of the most popular ditch light upgrades trending online using our products!
    Due to the design of our SS3 universal bracket, you can bolt our SSC1 LED pod directly to the side of the bracket for additional output.
    Attach Universal SSC1 U-Bracket to SSC1 LED Pod
    SSC1 LED Pod with U-Bracket Attached
    Slide the included carriage bolt through the SSC1 U-Bracket
    Slide the SCC1 LED Pod with carriage bolt through the side of the SS3 U-Bracket
    SSC1 LED Pod with included carriage bolt through the side of our SS3 U-Bracket
    Thread on the included washer, lock washer, and nut to secure the SSC1 LED Pod to the side of our SS3 U-Bracket
    SSC1 LED Pod attached to our SS3 LED Pod
    If you plan to have your SS3 and SSC1 LED pods backlight and main beam operate together, you'll need our DT 4-Pin Splitter Wire.
    Click HERE to shop our 4-Pin DT Splitter Wire!
    If you prefer to have independent control over your SS3 and SSC1 LED pods, you'll need to wire them using separate 4-Pin Wiring Harnesses.
    Click HERE to shop 4-Pin DT Wiring Harnesses!
    SS3 + SSC1 Ditch Light
    Learn more on Instagram here:
    https://www.instagram.com/p/C07bhB0vHOV/
    If you have additional questions, we'll be happy to help!
    Hours: Monday-Friday 10 a.m. - 5 p.m. CDT
    Email: contact@diodedynamics.com
    Phone: 314-205-3033
  2. Dec 18, 2023 at 3:05 PM
    coTony
    Tony
    Montrose, CO
    Is there bracketry for a 2021 4Runner with those lights? Interested in pricing to surprise my wife
    Diode Dynamics[OP] likes this.
  3. Dec 18, 2023 at 3:11 PM
    Diode Dynamics
    You could just need our Ditch Light Kit for the 2021 4Runner to begin the process of arranging this setup.
    https://www.diodedynamics.com/stage-series-backlit-ditch-light-kit-for-2010-2023-toyota-4runner.html
    Then you would want to add an SSC1 of your choice to your cart:
    https://www.diodedynamics.com/products/led-off-road-lights/led-pods/ssc1/ssc1-standard-bezel.html
    Finally, you would just need our splitter wire as mentioned in this thread:
    https://www.diodedynamics.com/deutsch-dt-4-pin-splitter-wire-one.html
    ryanwgregg likes this.
