Ruff country 6”lift
Discussion in 'Suspension' started by Tj3, Dec 16, 2023.
  1. Dec 16, 2023 at 7:56 PM
    Tj3
    Tj3 [OP] New Member
    Tj
    2023 tundra limited crewmax
    Ruff country 6” lift
    I just got my truck back from getting the 6” ruff country lift and there is no suspension in rear feels like a car with hydraulics bouncing down the rd to every little bump and the rear is sagging bad trying to figure out what’s going on anyone have the same issue or know what it would be taking it back to shop Monday.
  2. Dec 16, 2023 at 8:13 PM
    They don’t call it rough country for nothing. Their lifts are not well reviewed. Not sure what the rear setup for the 6” RC lift is on a 23. You have the AVS or the rear air bags?
    reywcms likes this.
  3. Dec 16, 2023 at 8:17 PM
    Tj3
    Tj3 [OP] New Member
    Tj
    Rear air ride
  4. Dec 16, 2023 at 8:18 PM
    that’s likely the issue. The air ride needs adjustment.
  5. Dec 17, 2023 at 12:28 PM
    Tj3
    Tj3 [OP] New Member
    Tj
    How do I adjust air ride and not the controls inside is there another way manual’s
  6. Dec 17, 2023 at 4:16 PM
    Others who have done it would be a better resource than me, but there’s an adjustment arm under the bed above the rear axle. Believe there’s one for each side.
    Tj3[QUOTED][OP] likes this.
  7. Dec 17, 2023 at 4:35 PM
