My truck stopped accelerating while driving and now won’t turn on.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Taylor1919, Dec 17, 2023.
  1. Dec 17, 2023 at 12:07 PM
    Taylor1919
    Taylor1919 [OP] New Member
    Taylor
    2014 tundra limited trd
    I was driving and my truck stopped accelerating. Now, it won’t turn on. Battery is good. Anyone else having the same issue with the 2014?
  2. Dec 17, 2023 at 12:15 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Fuel pump died?
    Mr Badwrench likes this.
  3. Dec 17, 2023 at 12:27 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Gonna need about 400% more information. Check engine light? If so what codes? Does the engine crank and just not fire? Does the engine not crank?
    FlyingWolfe, T-Rex266 and Ruggybuggy like this.
  4. Dec 17, 2023 at 3:06 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Out of gas?
  5. Dec 17, 2023 at 3:29 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Until more info, lots more, comes in we'll start with: easy.
  6. Dec 17, 2023 at 4:20 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Super clogged air filter but fuel delivery is a better guess IMO
  7. Dec 17, 2023 at 5:33 PM
    Burdturger
    Burdturger New Member
    Check the alternator
  8. Dec 21, 2023 at 11:52 AM
    Taylor1919
    Taylor
    Charged the battery for a while and it turned on. Alternator is fine. No codes, but said battery life was 50%. So I bought a brand new battery. Ran good for 2 days, and then did the same thing. I’m at a loss
  9. Dec 21, 2023 at 11:54 AM
    rmorse
    rmorse New Member
    Bobby
    Bowie, MD
    2021 DC Cavalry Blue SR5 TRD Sport 4x4
    Alternator is not fine or cables are bad and it’s not recharging the battery.
    Mike59 likes this.
  10. Dec 21, 2023 at 1:19 PM
    Danman34
    Danman34 New Member
    Danny
    Alternator isn’t fine.
    Mike59 likes this.
  11. Dec 23, 2023 at 9:26 AM
    seydou
    seydou Distinguished Member
    How do you know the alternator is fine? Have you had it tested?
  12. Dec 24, 2023 at 5:43 AM
    Taylor1919
    Taylor
    I had a mechanic look at it. He’s starting to think it’s a bad relay. Has anyone had that problem?
  13. Dec 24, 2023 at 6:06 AM
    rmorse
    rmorse New Member
    Bobby
    Bowie, MD
    This would not cause your truck to turn off while driving. A bad relay can cause a parasitic drain leaving you with a constant dead battery. However, that would prevent your truck from starting. I’m 99% sure there isn’t a relay that tells your alternator to start sending juice to the battery.
    You have a bad alternator. Or possibly bad connection/cables.
    Mike59, Rdrcr and T-Rex266 like this.
