Alignment issues
Discussion in '3rd Gen Tundras (2022+)' started by Alex1992, Jun 22, 2023.
  1. Jun 22, 2023 at 8:29 AM
    Alex1992
    Alex1992 [OP] New Member
    2023 Tundra Platinum
    Hi All,
    I recently purchased a 2023 tundra platinum crewman after I realized my newly acquired travel trailer was a bit much for my old pilot.
    With and without the trailer, I've felt some vibrations and am having a hard time keeping the vehicle centered in the lane at high speeds (55-65 mph towing, 65-80 mph without the trailer); the steering feels loose. I do use a WDH with sway control.
    I brought the truck to the dealer who did a road force balance and alignment. The alignment paper (attached) shows the caster in the red, lower than the green numbers. The dealer told me it was within spec, but if that's true, I would think it would be green and not red.
    I assume the caster being too low is causing the drivability issues?
    Is the caster adjustable on a tundra without the TRD suspension?
    Is the dealer correct about this being in spec or is the service advisor wrong?
    Thank you all for your help. This is my first body on frame vehicle, so I'm not sure if I'm expecting too smooth of a ride from it.
  2. Jun 22, 2023 at 8:52 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Looks like a Toe and go alignment to me. I have a family own shop (only does alignments) and he sets the toe to 0.
    Make sure your WDH is set up correctly for the new truck also.
    Alex1992[OP] and ryanwgregg like this.
  3. Jun 22, 2023 at 9:04 AM
    AWDDude
    AWDDude New Member
    2023 Tundra Limited - Crew Max TRD Off Road 4x4
    How many miles do you have on your tires? When was the last time you had them rotated? I have had issues with loose steering feeling because the tires needed to be replaced.
  4. Jun 22, 2023 at 9:22 AM
    Alex1992
    Sorry, I should've included that, it has less than 3k miles, it's only 2 months old. I first noticed around 600 miles.
  5. Jun 26, 2023 at 9:37 PM
    AWDDude
    AWDDude New Member
    hmm, that seems too low to be a tire wear problem. Do you keep the tires pressurized to spec? Have you tried rotating the back wheels to the front to see if it helps?
  6. Jun 26, 2023 at 9:53 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    I would ask your dealer to bring caster within spec. 3.4 and 3.3 is, according to the sheet itself, out of spec (4.5 - 6.0).
  7. Jul 28, 2023 at 6:34 AM
    Mrwheelservice
    Mrwheelservice New Member
    Scott
    Caster will not cause a vibration. Caster is a handling adjustment. Those caster numbers are actually pretty good. The truck should drive pretty good down the road. Vibration is never from Alignment. Bad alignment can cause tire wear which ultimately can cause noise and or vibration.
  8. Dec 17, 2023 at 7:38 AM
    Saltydog711
    Saltydog711 New Member
    2023 Toyota Tundra Limited TRD Off Road
    I have 2600 miles on my 23' TRD Off Road and am noticing feathering on the sidewalls also. I also let the steering wheel go on various roads and highways and it's pulling to the right and left at various points. Does not go straight for long. I have an appointment with the dealer on Thursday. We'll see what they say, not a big fan of the dealer I'm going to but in my area there are not many options. I'm surprised a class action has not been started yet.
