2024 TUNDRA REAR NOISE RATTLE
Discussion in '3rd Gen Tundras (2022+)' started by aleayala18, Dec 14, 2023.
  1. Dec 14, 2023 at 9:03 AM
    aleayala18
    aleayala18 [OP] New Member
    Alejandro
    2024 PLATINUM TUNDRA
    275/65R20 BF GOODRICH ALL TERRAINS
    Guys my 2024 TUNDRA PLATINUM without air bag suspension is making a rear rattle when i go over rough roads, dealer doesnt know what it is, has anyone had this issue and solved it? Sounds like its coming fron underneath the rear seat o under the rear window.
    1794edtundra likes this.
  2. Dec 14, 2023 at 9:05 AM
    aleayala18
    Alejandro
  3. Dec 14, 2023 at 12:59 PM
    grnwdjsn
    grnwdjsn New Member
    2023 Tundra Limited TRD Offroad
    There are a couple of things. Easiest is the spare tire chain. I used a small zip tie to get it shortened up. The other is the bed to frame does not have a rubber or plastic spacer. It is metal to metal and creates a pop or clunk. There is a good thread on here about that with some home remedies. I plan on doing mine in the spring. Yours sounds like the bed to frame (to me).
  4. Dec 14, 2023 at 2:55 PM
    aleayala18
    Alejandro
    I doubt its the chain because of the loud rattle. I saw the other post someone puts a zip tie between the bed and frame, Ill try that. The bed to frame DOES have spacers but not where the bed bolts are. Ill send picture later today. Thanks @grnwdjsn
  5. Dec 15, 2023 at 9:56 AM
    aleayala18
    Alejandro
    Took it to the dealer they took off the entire bed and STILL rattles. Tjhey have two days and havnt found a thing.
    Kerktam, Kap1 and Supertech1 like this.
  6. Dec 15, 2023 at 10:01 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Damn. At least they're actually trying to find it.
  7. Dec 15, 2023 at 1:08 PM
    Supertech1
    Supertech1 New Member
    I’d say you’ve got a good chance of actually confirming what the noise is. Your servicing dealer appears to be putting a lot of effort into correcting the issue.
  8. Dec 15, 2023 at 1:13 PM
    GilFavor
    GilFavor New Member
    2023 silver tundra 1794
    My neighbor said one time, it’s not a real barn if you don’t have a roof leak…I feel like it’s not real truck if you don’t have a rattle or two. :D
  9. Dec 15, 2023 at 3:14 PM
    aleayala18
    Alejandro
    well... now Im starting to think its inside near the battery compartment!
  10. Dec 15, 2023 at 4:41 PM
    MRQZTNDR93
    MRQZTNDR93 New Member
    San Diego CA
    2022 TUNDRA SR5 TRD OFF ROAD
    I have a squeak coming from the bed
    maldo012 likes this.
  11. Dec 15, 2023 at 6:29 PM
    DRP
    DRP Old Member
    Dave
  12. Dec 17, 2023 at 12:50 PM
    MRQZTNDR93
    San Diego CA
  13. Dec 17, 2023 at 3:25 PM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    Almost sounds like a blown end link or tie rod link which there is a lot in the rear of the truck.
    White3actual likes this.
  14. Dec 17, 2023 at 3:54 PM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    Following, love to find out where it's coming from. Seems to be something from the bed but can't replicate when not driving over bumps so hard to narrow it down when parked. No, jumping in the bed doesn't work
  15. Dec 17, 2023 at 3:58 PM
    1BLUEsky
    1BLUEsky New Member
    BRETT
    2007 SR5 CREW MAX 4X4
    Hammerhead bumper, Fuel Shok wheels(18X9), Toytec 3/1.5 lift
    Broken exhaust mount/ bracket?
  16. Dec 17, 2023 at 4:05 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Time to get that fuel line recall done. Easy access :)
    Any little stones stuck on the heat shields? I had a rattle on my Honda and it was a stone. Also, the front swaybar bushings were gone so I got some clunking when the turning.
  17. Dec 17, 2023 at 9:17 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    My truck and my son's truck, which he just got last night, has a rattle over bumps that can only be heard with the back window rolled down. We both assumed it was our tailgates rattling since we've heard about several misaligned tailgates on the Tundras. But who knows? Ours sounds like the tailgate rattling. But if you can hear yours rattling with the windows up, it's probably not the tailgates.
    aaen and Tundraaa3 like this.
  18. Dec 21, 2023 at 5:42 PM
    tcap23
    tcap23 New Member
    Patrick
    2023 Capstone
    My rattle just started today. It sounds just like a heat shield broken or loose. Only happens when I go over some patched places in the road right before I get to my house. Windows up and about 30 MPH on a curving and patched road. My previous Tacoma had exactly the same noise that got worse until the shield over the cat fell off and I ran over it. Truck has about 7000 miles on it. Never been off road.
    The rattle and the driver seat moving is going to drive me crazy. I guess it is time to start a conversation at the dealer. I am going to get under the truck and try to make something rattle. If I find something I will report back.
    thanks
    PT in Tennessee
  19. Jan 24, 2024 at 3:05 PM
    Daniel777
    Daniel777 New Member
    Daniel
    2024 tundra limited
    Let us know if you had any success
  20. Feb 19, 2024 at 10:26 AM
    aleayala18
    Alejandro
    Still no success over here. Ive been told the Hidraulic bed mounts are faulty but since dealer has no RECALL, I cant just start replacing parts will end up with a $200,000 truck.
  21. Feb 19, 2024 at 10:27 AM
    aleayala18
    Alejandro
    I guess only wat to know for sure is to put the truck in one of those vibrating cranes and just get under the truck until the culprit is found. In my ares its now over 8 Tundras in the dealer with the same claim and Rattle.
  22. Feb 19, 2024 at 10:34 AM
    Daniel777
    Daniel
    2024 tundra limited
    Interesting keep us posted!!
  23. May 12, 2024 at 7:11 PM
    24TundraFan
    24TundraFan New Member
    Ever figure out what this was?
  24. May 13, 2024 at 6:25 AM
    aleayala18
    Alejandro
    Yes! Changed the hydraulic cabin mounts and everything stopped!
  25. May 13, 2024 at 6:37 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    How many others, have this problem and the dealer service says it's normal?
    Kap1 likes this.
  26. May 13, 2024 at 6:53 AM
    aleayala18
    Alejandro
    No, it isn't normal, I had a lot of toyota techs inspect it and finally convinced them to change them.
    Tundrastruck91 and cmiles97 like this.
  27. May 14, 2024 at 12:12 PM
    aleayala18
    Alejandro
    All you need to do is go to your dealer and tell them THAT is the issue. they should authorize the replacement no problem. Tell them other dealers are swapping them out. My problem got fixed 100% My truck feels very different.
    1794edtundra and 24TundraFan like this.
  28. May 14, 2024 at 12:21 PM
    ullmsie
    ullmsie New Member
    Limited DC TRDOR
    I remember having a similar issue with my 2005 Tacoma. Something along the lines of the cab mounts being loose or faulty.
    24TundraFan likes this.
  29. May 14, 2024 at 3:36 PM
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    here
  30. May 15, 2024 at 2:49 PM
    24TundraFan
    Took mine to the dealer and they're going to try replacing the hydraulic cab mount, but apparently the part is on back order for a couple weeks. So I guess more waiting...
