SRS warning message is illuminated after a dead battery was exchanged
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shooter Tx., Mar 19, 2022.
  1. Mar 19, 2022 at 11:50 AM
    Shooter Tx.
    Shooter Tx. [OP] New Member
    Rick
    2018 SR 4.6 L V8
    None
    Afternoon all! I had to install a new battery in my 2018 Tundra Wednesday. After installing, the truck started and died. I’m sure that was because of an ECM adaptation reset. It ran fine after that but the SRS warning stays illuminated on the dash. Anyone know about a way to reset that without a $600.00 code scanner or another trip to the Toyota store on a weekday? It’s an SR with a 4.6 engine. Any help appreciated! BTW I had it at a Toyota dealership today and they only had the quick oil change people in.
  2. Mar 19, 2022 at 12:44 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Check fuses in the e-box both engine and cab.
    And typically, battery disconnect will clear codes - so maybe try that again.
    Shooter Tx.[OP] and Bob like this.
  3. Mar 19, 2022 at 1:44 PM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Let us know what you come up with.
    Shooter Tx.[OP] likes this.
  4. Mar 20, 2022 at 8:05 AM
    Shooter Tx.
    Rick
    2018 SR 4.6 L V8
    None
    Well no joy on any blown fuses. Btw the fuse box in the cab ain’t the easiest on I’ve ever had to get to. Remove left lower door sill cover, left kick panel and the box is way up over a bundle of wiring.
  5. Dec 13, 2023 at 1:43 PM
    CS1989
    CS1989 New Member
    I just paid a shop $125 to scan the truck and show me that the front impact sensor (which is directly in front of the battery) yellow harness got bumped while replacing the battery. Fully plugged it back in and the issue was solved.
  6. Dec 13, 2023 at 3:49 PM
    JohnWhicker
    JohnWhicker New Member
    Yeap, always trace the movement of what happened around the work that was done. Shit gets displaced and broken around it :) We all been there
