Super secret remote start
Discussion in 'General Tundra Discussion' started by Libertytree, Jun 15, 2023.
  1. Jun 15, 2023 at 5:21 AM
    Libertytree
    Libertytree [OP] New Member
    I have a 2015 Tundra Limited. I had a work cap installed, and had them install electric locks on the cap doors. One of the covers fell off and I reinstalled it. While lining up the electric lock mechanism, I hit the lock/unlock on the key fob several times and my truck started.
    Does anyone know how I started the truck? I can't seem to repeat it. It's not the typical lock 3 times and hold on the third press. I've tried that several times.
  2. Jun 15, 2023 at 5:52 AM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    Depending on what remote start you have, some of them are programmable so that you can use a different sequence of button presses instead of the typical 'lock', 'lock', 'lock'.
  3. Jun 15, 2023 at 5:56 AM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    I have one of the remote systems from @Tech12volts (I think). Mine is hit lock button 4 times and it starts. Does not turn off after opening doors. I think it is the EVO-Fortin remote start, but I could be mistaken.
  4. Jun 15, 2023 at 6:08 AM
    coTony
    Tony
    Montrose, CO
    Are you the original owner and know for sure an after market kit was not installed? If not try the 3 click LOCK LOCK LOCK and hold on the 3rd LOCK. With yours being a limited you may have the factory remote
  5. Jun 15, 2023 at 6:14 AM
    18" TRD Off Road Wheels
    You might have the stock one. Push the lock button 3 times and hold it on the 3rd. You have to hold it longer than you think. Toyota never advertised it, but lots of the older vehicles had it. My brother's 4Runner had it and he owned it for a year before he found out a bout it.
  6. Jun 15, 2023 at 6:17 AM
    Welcome from NY.
  7. Jun 15, 2023 at 6:24 AM
    Libertytree
    I'm not the original owner, I don't know if an aftermarket one was installed. It's not lock 3 times, it's not lock three times and hold, it's not lock 4 times, it's not lock 4 times and hold. I've tried to do random combinations of lock and unlock and nothing seems to work.
  8. Jun 15, 2023 at 6:25 AM
    Libertytree
    Thanks!
  9. Dec 13, 2023 at 9:17 AM
    SMXM
    SMXM New Member
    2019 Tundra Crewmax SR5
    I just found my truck was setup with Lock-Unlock-Lock. Might be worth trying that. The other option is to open up the panels and see if there is anything installed.
