  1. Dec 11, 2023 at 5:59 PM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    That is a great tool to have in your back pocket!
    Don't discount the motion of the axle. That pin does have some motion in the axle. I had a problem on a Tacoma in the past. Loosening the springs and sliding the axle made a difference. Does not seem like much but....
    vtl[QUOTED] and HulkSmurf14 like this.
  2. Dec 11, 2023 at 6:27 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yeah. When weather allows, I'll slacken both sides and pull both ends in opposite to shift it CCW. It is not much, maybe a degree or so.
    I actually paid for alignment to correct that. $180 and here I go: a front toe adjusted, so the steering wheel looks straight. Not the truck drives straight, it is too involved and out of budget.
    The tool is very useful and will eventually pay for itself.
  3. Dec 11, 2023 at 6:30 PM
    Teegee
    Teegee Around
    Grouch
    21 MAX
    Chillin
    Made my own brackets, all oem parts with Hayden cooler.
    Only 22k miles and the fluid was really dirty so I did a drain a fill as well
    Wallygator, pvn.beluga, Jego and 15 others like this.
  4. Dec 11, 2023 at 9:13 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Ah, simple enough. Thanks for the pic. I just changed the PCV valve, so can see exactly how that works.
    pvn.beluga[QUOTED] likes this.
  5. Dec 12, 2023 at 7:40 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Any chance you'd be able to share how you made the brackets?
    reywcms likes this.
  6. Dec 12, 2023 at 7:49 AM
    ffdawson
    ffdawson #DBB
    NorCal
    Sandra, Sandy for short
    Rad ass parts, big tires.
    Took her out to play in the snow!
    41D9B775-48B2-4693-A891-35BC76E726BE.jpg E03BCEB4-572B-4895-9F59-EC4ECB25B078.jpg
    Jego, Helo, grant.ducckk and 20 others like this.
  7. Dec 12, 2023 at 8:09 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Where did you go to get your tree?
  8. Dec 12, 2023 at 8:13 AM
    seydou
    seydou Distinguished Member
    Do yourslf a favor and buy a proper seal from a topper place. Not that much money and does exactly what it is supposed to.
    bulldog93 likes this.
  9. Dec 12, 2023 at 8:18 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Did you guys snap the tree? LOL
    JMGmanAZ likes this.
  10. Dec 12, 2023 at 10:48 AM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
  11. Dec 12, 2023 at 10:49 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    #drool
    831mic, JMGmanAZ and AGTundra[QUOTED] like this.
  12. Dec 12, 2023 at 2:44 PM
    Jnickoles
    Jnickoles New Member
    2021 Tundra sr5
    It wasn’t, my clamp just shot out from my pliers lol
  13. Dec 12, 2023 at 2:47 PM
    Jnickoles
    2021 Tundra sr5
    Dude that looks legit lol. I thought that was a different truck at first
    lerbud1 likes this.
  14. Dec 12, 2023 at 3:15 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    My wife is Mexican…. If I gave her a choice like that she’d pop me in the face then make me buy her something :rofl:
  15. Dec 12, 2023 at 4:13 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Ah, nothing like an old good married knife fight!..
    jeffw6236[QUOTED] likes this.
  16. Dec 12, 2023 at 4:46 PM
    singletrack_dad
    singletrack_dad New Member
    Ty
    2014 TRD OR CM
    My knees told me I had to replace my inner tailgate panel & to be honest I am sick and tired of not being able to set almost anything down on it without it falling over because of the hard ribbed design. So I cut out a piece of .5” hardwood plywood and screwed it on. This is temporary & I will eventually stain and finish the wood but for now this is such an upgrade to use as a work surface, kitchen or a bench. And I refuse to pay $250*+ for the aftermarket tailgate panels. Also scored a cheap Amazon awning on fb marketplace for $50. Working on my mounts for it now.
  17. Dec 12, 2023 at 10:07 PM
    Teegee
    Teegee Around
    Grouch
    21 MAX
    Drill and 4.5” cutting wheel on my disc grinder lol.
    I used some flat steel I had laying around. Just measure, cut and drill. Mine is mounted in 3 locations and I only drilled 1 hole in the center support. The other 2 were factory holes. It will depend on what cooler you use and where you want to mount it.
  18. Dec 13, 2023 at 5:01 AM
    Not a bad idea. I'm wondering how Raptor liner would work on it versus stain.
    bulldog93 and NewImprovedRon like this.
  19. Dec 13, 2023 at 6:19 AM
    singletrack_dad
    Ty
    2014 TRD OR CM
    Yeah either way I’m not worried about it staying “nice and new” looking. I think I’m going to stick with a simple waterproof sealer that way it isn’t overly tacky or anything. Just a durable work surface for whatever I need.
  20. Dec 13, 2023 at 6:21 AM
    True. It won't be seen most of the time. The only advantage to the pockets on the tailgate is for holding hardware when doing a project. Otherwise its hard on the knees. A flat bed surface would be nice too.
    NewImprovedRon and bulldog93 like this.
  21. Dec 13, 2023 at 10:12 AM
    RI2021Platinum5.7
    RI2021Platinum5.7 New Member
    Added A TRD CAI ! :muscleflexing:
  22. Dec 13, 2023 at 10:14 AM
    Purely cosmetic. You already had a CAI.
  23. Dec 13, 2023 at 10:17 AM
    RI2021Platinum5.7
    Yes indeed but I do find more HP’s in my Butt Dyno !
    Jcmf52, BlueRibbon4x4, WFD473 and 3 others like this.
  24. Dec 13, 2023 at 10:26 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    New power steering cooler. Thanks for the idea @Vizsla.
  25. Dec 13, 2023 at 10:33 AM
    THOR's
    THOR's New Member
    Thor
    North Carolina
    2021 Tundra TRD Sport and XP Predator Package
    Ooooo.... I like this! Would you share where you got it and the cost? :thumbsup:
  26. Dec 13, 2023 at 10:41 AM
    Its about $400 of wasted money other than being pretty.
  27. Dec 13, 2023 at 10:46 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  28. Dec 13, 2023 at 10:51 AM
    Oh lord! :stirthepot: lol
    D3VA, Ace96 and bulldog93 like this.
  29. Dec 13, 2023 at 11:01 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
  30. Dec 13, 2023 at 11:05 AM
    coTony
    Tony
    Montrose, CO
    Been on my list for a while. I put one on my LandCruiser and it made a huge difference with the steering with the offroad quick steering. It is coming
