Text volume via Apple CarPlay
Discussion in 'Audio & Video' started by TF_CC, Aug 8, 2022.
  1. Oct 10, 2023 at 5:43 PM
    #91
    Roziere3
    Roziere3 New Member
    I had the same issue with my 23 TRD sport and it drove me crazy. Took it into the dealer and they said it was an Apple issue they couldn’t address….makes no sense as my previous Fors and Ram both muted the music .
    I ended up installing an android 14” screen to replace my factory 8”…and guess what….it mutes the music during texts etc as it should.
  2. Oct 10, 2023 at 7:20 PM
    #92
    ElectricMan
    ElectricMan New Member
    same problem here. I noticed the greyed out area which I naturally believed the fix would be, but figured since I only have a platinum, it is one of those "you dot get this feature" in the software. I look forward to your update on the 16th. THX for posting this!!!
  3. Oct 10, 2023 at 8:48 PM
    #93
    AzTundraTrd24
    AzTundraTrd24 New Member
    2024 Tundra Limited TRD
    I just got a 2024 limited TRD and this is still an issue.
    Spickett78 likes this.
  4. Dec 9, 2023 at 6:19 PM
    #94
    farinx
    farinx New Member
    Having the same issue on my brand new 24 limited. Very annoying. Also I can't figure out how to make the text message alerts quieter. They are so loud, then I can barely even hear the message when siri reads it when I have music on.
  5. Dec 10, 2023 at 7:40 AM
    #95
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    You can adjust the system voice and driving assist volume in Settings>Sound and Music>Levels.
    Unfortunately, this doesn't solve the problem of the music not automatically muting when Siri reads text messages.
  6. Dec 10, 2023 at 7:56 AM
    #96
    farinx
    farinx New Member
    Mine doesn’t allow me to adjust the ringtone, new message and received volume for some reason:
  7. Dec 10, 2023 at 12:29 PM
    #97
    Matt2015Tundra
    2023 1794 CrewMax
    I just checked mine again, and now my Ringtone, New Message, and Received volumes are grayed out too. Weird.
    This is one of my biggest annoyances with my truck. To reiterate the problem:
    1. Using CarPlay with the music playing.
    2. Incoming text message alert displays.
    3. Select the message and Siri reads the message, but the music doesn't mute, so you can't hear the message being read.
    The only solution I've found is to quickly turn the music off by pushing the volume control knob, then select the message. But you have to be quick, because the massage alert only stays visible for 1-2 seconds, and it's an extra step that shouldn't be necessary.
    Incoming and outgoing calls work as expected. The music automatically mutes as soon as you place or accept a call. Voice text messaging should too. Every time I see this thread pop back up, I hope that someone has found a solution.
    matt2024 and zcardoza1 like this.
  8. Dec 10, 2023 at 3:14 PM
    #98
    farinx
    farinx New Member
    do you know if this is an issue with all the new tundras or is it just the ones with the upgraded JBL system?
  9. Jan 22, 2024 at 1:53 PM
    #99
    matt2024
    matt2024 New Member
    2024 Tundra Platinum
    Same problem with my new 2024 Tundra Platinum. First Toyota for me, every other vehicle I’ve had with car play does not have this issue.
  10. Jan 22, 2024 at 1:59 PM
    #100
    Spartanfam
    Spartanfam New Member
    West Michigan
    2024 Tundra Limited TRD Off-Road
    I have the same exact problem with mine. Thx for digging into it!
  11. Jan 22, 2024 at 2:07 PM
    #101
    farinx
    farinx New Member
    So they are able to fix it at the dealer?
  12. Jan 22, 2024 at 3:43 PM
    #102
    MaxPayne3
    MaxPayne3 New Member
    2024 Lunar Rock SR5 Crew Cab
    Just starting out but never will be done
    I can tell you I just bought a 24 SR5 without the JBL, my settings in Sound and Media are also greyed out. This is super annoying for me since I replaced the speakers and put in aftermarket amps, my ringtones, notifications, and text reading voices are excruciatingly loud and there's no way to turn them down! I had the same set up in my 21 Tacoma, and I could adjust those volumes through the radio menu as well as using the volume button on the steering wheel. I do also miss the native split screen view of the map and radio information. I listen to Satellite Radio and sometimes if there's an unfamiliar song it was nice to have that displayed. Now with the massive screen, you have to fumble and switch through the menu to see what's playing. I could live with that, but not being able to turn down the volume of incoming notifications or calls really has me disappointed because my only other option at this point is to turn off my phone completely which not only means no notifications, but no Apple Car play either :mad:
  13. Jan 22, 2024 at 3:49 PM
    #103
    farinx
    farinx New Member
    Putting the phone on silent silences my notifications on carplay
  14. Jan 22, 2024 at 4:02 PM
    #104
    MaxPayne3
    not on mine, I even tried to use "Focus" to turn them off but I still get notifications for calendar events and such. Very annoying
  15. Jan 22, 2024 at 4:12 PM
    #105
    matt2024
    matt2024 New Member
    My issue is the radio volume does not go down when listening to or sending a text. The lack of split screen is horrible as well. Bigger screen that does one thing at a time is silly
    Not impressed with this truck. Traded in a 2021 Lariat and am so far amazed at the stupid little things that are overlooked.
  16. Mar 29, 2024 at 11:44 AM
    #106
    CoTreeSkier
    CoTreeSkier New Member
    LeMonte
    2024 Tundra Platinum OR
    Wow. Just upgraded from my 2020 Tacoma TRD Pro to the 2024 Tundra Platinum. I was coming home today from having the clear bra and tint done at the dealer. Jammin' to some tunes and wanted to send a text. Hit the voice activation, saw the siri symbol on the screen but couldn't hear a damn thing. My Tacoma would mute the music . . . I'll have to play with the Siri volume on the steering wheel. Does it remember or do you have to do it every time?
  17. Mar 29, 2024 at 11:59 AM
    #107
    Matt2015Tundra
    2023 1794 CrewMax
    Sadly, this is continuing problem. I was hoping the most recent head unit update would fix it, but no joy. The only way around it is to either turn the music off, or turn the volume down, before you dictate or listen to text messages using Siri.
  18. Mar 31, 2024 at 1:39 PM
    #108
    DontEatTacosDriveEm
    DontEatTacosDriveEm New Member
    Just bought a 2024 Tacoma TRD Sport yesterday and encountered this issue. Thought I was crazy... just stumbled upon this thread. Will be following...
  19. Apr 18, 2024 at 11:47 AM
    #109
    MattMan
    MattMan New Member
    Just took delivery of my Platinum Tundra and have the same issue as described. Driving home from the dealer and couldn't hear the text. Assumed that this was surely just a setting that I would have to toggle on the "mute media while using Siri" or something similar............um nope. I have owned/rented/ridden in many cars sense the advent of both plug in and wireless CarPlay and I cant remember one that had this issue.
    I know how many computers and similar tech items my truck has because my closing guy reminded my 10 times while trying to sell a warranty. I guess they need one more computer.
  20. Jun 4, 2024 at 1:41 PM
    #110
    BigTrout
    BigTrout New Member
    2024 Tundra Platinum TRD Off Road
    Has anyone had luck with the dealer to address this?
  21. Jun 4, 2024 at 2:47 PM
    #111
    CoTreeSkier
    LeMonte
    Nope. I opened a ticket with Toyota USA. They referred me to my dealer and I've left their customer success person four messages - nada. Now I just turn down the music to use Siri with CarPlay. Super frustrating though.
  22. Jun 28, 2024 at 7:10 AM
    #112
    sad tundra
    sad tundra New Member
    Has anyone had any luck with a software update at a dealership ? My service dept hasn't heard about this issue (weird). So, I don't want them messing with my truck if there is no fix right now.
    Honestly, I would have never bought a TUNDRA if this was told to me ahead of time.
  23. Jun 28, 2024 at 7:38 AM
    #113
    Breathing Borla
    AZ
    you would not have bought the truck over a CarPlay text volume?
  24. Sep 19, 2024 at 2:42 PM
    #114
    CoolBeans3
    CoolBeans3 New Member
    Between that and the host of other annoyances? I definitely regret my 23 platinum. After 18k miles my list is long.
    The volume thing is annoying
    JBL sound system is very disappointing. And the surround sound option in the settings makes it sound terrible for some reason…
    Even if you’re subscribed to the app to remote unlock you can not lock the keys in the truck ever. Unless you throw them in the window and roll it up I guess?
    The keyfob has a 50’ range at best with a direct line of sight. More like 15’ if there’s obstacles.
    The remote start is pointless unless you’re going to use the app to do it from far away because for some reason the truck shuts off completely as soon as you unlock it.
    the inside feels so cheap compared to my old Toyotas and other vehicles. Everything creaks if you put any pressure on it, including the stupid little storage area in the middle of the console. The fascia suffers from this as well. Feels incredibly cheap. Even with a 1 finger press the whole thing will flex and creak.
    There’s very little storage room inside compared to most half tons. Speaking of which. Has anybody opened their glovebox? You have enough room in there for maybe 10 paper towels and an envelope maybe but even that’s gonna be a tight fit.
    The steering wheel cruise control buttons frequently require multiple presses to work.
    If I'm idling at a stop light or in a drive thru for more than a minute or 2 something under the hood starts to sound like a typewriter being used in front of a megaphone.
    The seats having the plastic bracket for the seat controls coming up into the bottom of the cushion is noticeable and uncomfortable (I’m a bigger guy so that may just be me but I’ve never had the issue in other trucks).
    Using my truck for work it would be nice to have a 12v outlet that wasn’t in the dash and a 120v that wasn’t in the back seat.
    Doesn’t feel like Toyota is making vehicles to the same standards they used to. And it doesn’t feel like they stand behind them like they used to.
    Only real reason I could recommend this truck to somebody is if they just want compliments on how nice the truck looks and that it holds its value best in the segment. Other than that I can’t really think of anything that sets Toyota above the competition like they used to.
  25. Feb 9, 2025 at 2:03 PM
    #115
    Matt2015Tundra
    2023 1794 CrewMax
    Resurrecting this thread from the dead to see if anyone has heard anything new from Toyota?
    The problem still exists for me even after the most recent head unit software update.
    Very annoying.
    Korj26 likes this.
  26. Feb 9, 2025 at 9:32 PM
    #116
    CoolBeans3
    Nah. Traded the truck in mid November.
  27. Mar 20, 2025 at 6:19 PM
    #117
    Jeffro18
    Jeffro18 New Member
    Jeffro
    2025 Blueprint 1794 TRD
    Got a new 2025 1794 a few months ago and once I realized the problem went on the threads and saw it's been an issue. Called Toyota and they said when an update comes they'll send me a first class letter - since then I've heard nothing. Now I just flood any social media I see from Toyota - I leave a message stating great truck crappy tech and that they should hire a new IT crew to fix what should be a simple fix/update.
  28. Apr 10, 2025 at 10:09 AM
    #118
    Broncorm
    Broncorm New Member
    Vermont
    25 limited
    Just got 25 limited last week and did a search to hoping to find a solution to this problem. So it still going on
  29. Apr 10, 2025 at 11:08 AM
    #119
    Jeffro18
    Jeffro18 New Member
    Jeffro
    IMG_0376.jpg I harassed Toyota on IG and this was there reply….
