Are A750E Transmissions Interchangeable?
Discussion in '1st Gen Tundras (2000-2006)' started by 1Cor1031, Dec 9, 2023.
  1. Dec 9, 2023 at 7:28 PM
    1Cor1031
    1Cor1031 [OP] New Member
    2006 Toyota Tundra, 4.0L, RWD
    Helical Limited Slip
    My truck needs a new transmission and I've found a good deal on a rebuilt A750E but it came out of a 4Runner. Can I easily put it in my Tundra? How can I find out for sure if they are or not?
    (Below is a picture of the tag on the trani out of the 4Runner.)
    Thanks!
  2. Dec 9, 2023 at 11:29 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    ehh. im not sure of any internal differences. the only major thing i can think of being potentially an issue is the wiring inside the transmission? and if the transmissions from a v8 you'll need the bellhousing from your old one
  3. Dec 10, 2023 at 1:57 AM
    1Cor1031
    Yeah, I was wondering if I need to swap the bellhousings. I'm guessing I should be able to do that without any serious problems. What is the issue with a difference in wiring? Are the harnesses not going to match up?
  4. Dec 10, 2023 at 2:22 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    2WD? You might be OK. 4WD, not so much.
  5. Dec 10, 2023 at 6:52 AM
    empty_lord
    05 rollover special
    Not sure honestly. The internal harness to the transmission is likely the same Pin put. But you may want to double check wire diagrams or part numbers to be sure
    I don’t think they made 2wd v8 4Runners so you probably won’t have to swap bell housings since you’ve got a 4.0
