How many miles before Fuel Pump actually failed
Discussion in '2.5 Gen Tundras (2014-2021)' started by Legbuh, Aug 12, 2021.
  1. Aug 12, 2021 at 6:39 PM
    Legbuh
    Legbuh [OP] New Member
    2019 Crewmax Limited
    I know there are probably some out there that missed the fuel pump recall or ignored it, or your specific year wasn't included yet, so I'm curious at what mileage did you actually have a problem that was caused by this recall?
    I did look and didn't see other threads asking this.. so I am just curious.
    I wonder if we should also add to the details:
    flex or not?
    what gas you use?
    what size tank?
    Only looking for replies where your fuel pump actually failed because of the recall issues.
  2. Aug 13, 2021 at 2:54 AM
    blanchard7684
    blanchard7684 New Member
    That recall is over?
  3. Aug 13, 2021 at 1:38 PM
    Legbuh
    Huh? I dont follow..
    Mainly asking if anyone's pump actually failed and when.
  4. Aug 13, 2021 at 3:08 PM
    737fixer
    737fixer New Member
    Recalls are not done from the manufacturer. They are issued by NHTSA and do not end or expire. Service bulletins and the like can be recommended by NHTSA or the manufacturer but are generally "keep the customer happy items". You will constantly here someone bitching about things like chevy's window regulators CONSTANTLY failing on every model for 30 years and they should be recalled but NHTSA has no authority over that. Recalls are safety only. The Toyota Fuel Pump recall or SAFETY RECALL 20TA02 - NHTSA Recall No. 20V-012 & 20V-682 will never expire. There is a point where Toyota has proven they contacted every vehicle's owner several times and were ignored thus the recall being called COMPLETED but even then they will still be required to keep the new part available for a very long time. The ongoing recall includes many Toyota & Lexus vehicles therefore negating any relation to a flex fuel issue or gas tank size. It has also been shown that there is no age time for the failure as it was happening to new vehicles along with many years old ones. I got mine done at 20,000 miles on a 2019 but never had any issue whatsoever with the fuel pump.
  5. Aug 13, 2021 at 4:14 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Going in for the fuel pump recall next week, my truck has 23,000 miles. In the last 10,000 miles when my truck is on any incline at slow speeds my truck stutters and feels like the transmission is acting weird or maybe the fuel pump isn't performing correctly. Has anyone else had this experience?
    I’ll update everyone after the recall is complete.
  6. Aug 13, 2021 at 4:35 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Is this just on the recent year models?
    Mine's an '08 with 193k on the clock. Just changed the fuel pump because the screen was clogged. The pump still worked just fine, but since I already had the tank out I figured I might as well take care of it rather than taking a chance on having to do all that work again later.
  7. Aug 13, 2021 at 4:41 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    My 2017 was NOT in the recall.
  8. Aug 13, 2021 at 4:55 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Nor was my 2018 ... at least as of yet. Still hasn't shown up on Toyota's web portal as a recall and even had the dealer check it by VIN but nothing.
  9. Aug 13, 2021 at 4:58 PM
    I’m at 155k on the original fuel pump. I might change it soon to get a finger workout.
    bmf4069 and Darkness like this.
  10. Aug 13, 2021 at 5:31 PM
    Jas4tundra
    Jas4tundra New Member
    Jasmeet
    2019 Tundra limited white
    Stock
    I just did recall on the fuel pump at 86000 miles on 2019 tundra. Truck was running fine earlier also no issue with fuel pump, dropped at the dealer early morning was done by evening.
  11. Aug 13, 2021 at 5:55 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    86k on a 19? Holy cow!
    I had the recall done on my 19 GS350 and my 19 Highlander Hybrid. I hope my 2020 GS350 and 2021 Tundra won’t need it.
  12. Aug 13, 2021 at 5:56 PM
    abomb60
    Massachusetts
    Yeah that's quite a few miles! I mostly drive around town and just hit 17k on my 2018!
    JDR76[QUOTED] likes this.
  13. Aug 13, 2021 at 7:24 PM
    Tileguy
    Tileguy New Member
    Birmingham, Alabama
    2011 Toyota Tundra
    Fuel pump failed at 232k on my 2011.
  14. Aug 13, 2021 at 7:30 PM
    737fixer
    737fixer New Member
    Bring your truck in with almost no gas. They probably told you 1/4 tank or less but do your mechanic a favor and go less. Nothing better then a grateful mechanic. I also took my truck to a self spray car wash a couple days before and gave that area inside and above the drivers side rear wheel well a quick cleaning. They will be pulling I believe three separate lines to the tank and leaving them hang there. Nice to get rid of some of the old stuck on dirt/mud in the area. Took about 2.5 hours.
    georgiey22[QUOTED] likes this.
  15. Aug 13, 2021 at 7:31 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    240k no problem
    bmf4069, georgiey22 and FrenchToasty like this.
  16. Aug 13, 2021 at 7:46 PM
    Damn, you got miles!
    Darkness[QUOTED] likes this.
  17. Aug 13, 2021 at 9:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  18. Aug 13, 2021 at 9:57 PM
    TheBeast
    TheBeast The Beach
    I need to take my 2018 camry in for the recall. 47K miles on it.
  19. Aug 14, 2021 at 5:59 AM
    I'm at 320k. Still on the original pump. And my cams aren't leaking either.
    dondino, NyCSnEaK, Tileguy and 4 others like this.
  20. Aug 14, 2021 at 6:18 AM
    175,000 miles here, O.G. fuel pump on my O.G. Tundra.
    georgiey22, bmf4069 and FrenchToasty like this.
  21. Aug 14, 2021 at 7:25 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Are the flex fuel Tundras part of the recall, or is it only for non-FFV?
  22. Aug 14, 2021 at 7:44 AM
    blanchard7684
    Recalls have expiration dates.
    Your post reads like the expiration date has passed on this recall.
  23. Aug 19, 2021 at 4:31 PM
    georgiey22
    Recall for my fuel pump is now complete. I drove 20 miles and some of this was at an incline. So far the stutter I’ve been experiencing has gone away which is a good sign. Will keep all updated.
    The work took the dealer 5 hours and I got under the truck to inspect the tank, tank straps and they did a nice job. Crossing my fingers my truck gives me a flawless 500,000 miles!
    Henry1jg and Mike59 like this.
  24. Dec 17, 2022 at 6:11 PM
    Northwoodsguide
    Northwoodsguide New Member
    2007 tundra crewmax 275k miles my fuel pump just went. it did it's job.
    dondino likes this.
  25. Dec 17, 2022 at 8:38 PM
    Pac12AfterDark
    Pac12AfterDark New Member
    All you high milage beauties are making me so happy.
    dondino likes this.
  26. Dec 5, 2023 at 10:01 AM
    tundraguy89
    tundraguy89 New Member
    2019 Toyota tundra
    I have a 2019 Tundra with 73k miles, and it does not qualify for the recall. But is having the same issues as the other ones recalled. My VIN does not qualify. I don't know what to do.
  27. Dec 5, 2023 at 10:45 AM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    2014 FFV - Failed at 90k - Sluggish acceleration, hesitation on heavy throttle
    2017 FFV - 96k - Rough startup - Techstream Alcohol % Relearn has solved this issue so far...fingers crossed.
    rodm1 and tundraguy89 like this.
  28. Dec 8, 2023 at 1:37 PM
    tundraguy89
    2019 Toyota tundra
