Missing skid plate?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Daddio Rick, Oct 12, 2023.
  1. Oct 12, 2023 at 12:57 PM
    Daddio Rick
    Daddio Rick [OP] New Member
    2016 Platinum
    New to me 2016 Platinum 5.7 2wd. Took it in for oil change today. When asked the tech said no skid plate. Is it possible it came from factory without a plate? Thanks.
  2. Oct 12, 2023 at 1:17 PM
    Yes....my 2020 didn't come with one.
  3. Oct 12, 2023 at 3:30 PM
    seydou
    seydou Distinguished Member
    New? Not even the cheap plastic one? I thought that was standard on all trucks.
    AZBoatHauler likes this.
  4. Oct 12, 2023 at 4:39 PM
    Yes....when I bought mine new it only came with the seal (#5).
  5. Oct 12, 2023 at 5:23 PM
    seydou
    Crazy. Learn something new every day.
  6. Oct 12, 2023 at 6:03 PM
    yakeng
    yakeng 3URFE Apologist
    You aren’t missing much, factory skid plate is a joke.
    BravoDeltaRomeo likes this.
  7. Oct 13, 2023 at 4:42 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, basically just a splash shield. I thought they all had the engine skid. I bet the previous owner removed to to make oil changes easier.
    BravoDeltaRomeo and Black Wolf like this.
  8. Oct 13, 2023 at 12:56 PM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    My 20 Platinum came with the cheesy factory plate…
  9. Oct 13, 2023 at 2:51 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I mean most vehicles come with a plastic shield so the fact that its metal is better than most. Id rather have it there than not, even if just to help keep road grime and debris from getting in the engine bay. Its obviously not build for taking hits from rocks but i bet it would be better than having nothing at all, it could probably take one good wack from a rock off-road.
  10. Oct 14, 2023 at 9:01 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I hit a big rock in a creek bed in Tacoma that I thought was just a clump of grass. Glad it was there. It held up well.
    Joe333x[QUOTED] likes this.
  11. Oct 15, 2023 at 3:57 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Last time I had my oil changed in a shop, my skid plate went missing. I'm not happy about it, but the truck is a pavement princess so I can't make myself pony up $250+ for a new one. Waiting to sneak up on a used one.
  12. Oct 15, 2023 at 4:18 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    My 2014 had a dinky little splash shield.
    Probably the same one @Tundra234 mentioned.
    I replaced it with a TRD shield..
    4914D002-E9DC-4D26-A985-3F3400C5B39A_zps_956d3adeb2c80a884fb3a0357bf267c3ea65f4e4.jpg
    Gene_in_FL likes this.
  13. Oct 27, 2023 at 9:40 AM
    AircoolerKirk
    AircoolerKirk Old School VW Nut
    Allen, Texas
    Magnetic Gray Metallic 2017 Tundra TSS 4wd
    I want to replace the one on my'17 with the TRD one for that little access panel. I assume they just bolt right up? I have a cat shield too, so I was curious if they all worked together well.
  14. Oct 27, 2023 at 9:55 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’ve got a 17, went with RCI plate, got a great deal. I also have Valhalla cat shields, they work great together. I recently got a TRD nut plate from talons garage. Best $35 ever spent.
  15. Oct 27, 2023 at 10:14 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    My cat shields mount in the same holes as the TRD skid plate.
    Fortunately, the shield had slots for those bolts, like the Talon shield in the pic..
    I just loosened the rear bolts of the skid plate and slid the cat shield underneath it..
    My shields are Vahallas, but I not longer recommend them, if I needed shields today, I get them from Talons Garage.
  16. Oct 28, 2023 at 4:37 AM
    ultraman29
    ultraman29 New Member
    Katy Tx
    2021 White TRD sports
    Any particular reason why you decided to change from Valhalla to Talons?
  17. Oct 28, 2023 at 8:30 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I have Vahallas, I didn't change them, the plates are very similar.
    I used to be a big Vahalla supporter, but as a one-man operation, he got in over his head.
    His website stated a 4-week runaround, but it was more like 4 months.
    Many a shipping promise was not kept and he even stopped answering emails and PMs for awhile.
    He also lost his vendor status on the forum.
    Talon usually has a decent stock and tries to ship ASAP.
    To anyone buying a shield that has a skid plate, I strongly suggest the nut plate.
    It makes putting the front bolts of the shield with the rear bolts of the skid plate much easier..
    It doesn't look like much, but it is sure a knuckle saver when attaching those bolts..
    TRD Nut Plate – Talons Garage
    [​IMG][​IMG]
  18. Oct 28, 2023 at 8:38 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    For those that don't have the factory front skid plate (shield) or thinking of removing it. If you live were they use road salt, the spray from the road makes its way up to the steering shaft and will seize the U joint at the rack end.
    To make oil changes easier cut a filter access hole in the plate and make a cover for the hole.
    MedCityMoto likes this.
  19. Oct 30, 2023 at 11:55 AM
    AircoolerKirk
    Allen, Texas
    I (think) went with the Desert Eagle Offroad cat shield, since they are local to DFW where I live. I am happy with it. I was definitely wondering how that shield would mount near the cat guard.
    I haven't actually looked at the RCI ones, I'll check it out!
  20. Oct 30, 2023 at 12:12 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    By RCI I meant engine / trans skid plate. Same coverage as TRD pro plate. Everything bolted right up. Get the TRD nut plate!!!!
    Have Valhalla front and rear cat plates. If buying today I’d get talon plates. Same thing, better service.
    AircoolerKirk[QUOTED] likes this.
  21. Nov 1, 2023 at 11:19 AM
    Talon2006
    Talon2006 New Member Vendor
    If you are looking for an aftermarket front plate, we typically have the best prices for Aluminum or 10 gauge steel. We also have oil door, and cutouts for the oil drain and filter access. We use an easy to install 2 piece install that makes any future repairs easy, but also adds a ton of strength to the break over angle.
    https://talonsgarage.com/products/toyota-tundra-engine-skid-plate-2007-2021
    jomikepa and HulkSmurf14 like this.
  22. Dec 7, 2023 at 8:16 AM
    packheavy
    packheavy New Member
    Nice. I have a TRD lift w/o sway bar drop brackets. Will the standard skid work or would I still need your Skid Plate with subcategory TRD lift (which is currently unavailable). 2) Will the Cat Shield work with my lift? Thanks
  23. Dec 7, 2023 at 9:06 AM
    Talon2006
    PM me some pictures of your sway bar and brackets and I can tell you for sure.
    The transmission skid will work with that lift since it doesn’t change the subframe.
  24. Dec 7, 2023 at 10:00 AM
    jomikepa
    jomikepa New Member
    O-H-I-O
    21 black truck
    I've got the Talon cat plates and plan to get the engine skid soon. Their cat plates are legit and easy to install. Highly recommend.
    packheavy[QUOTED] likes this.
