Retrax XR has some pretty bad leakage... Any advice?
Discussion in '3rd Gen Tundras (2022+)' started by RickyBobbysTundra, Dec 6, 2023.
  1. Dec 6, 2023 at 2:17 PM
    RickyBobbysTundra
    RickyBobbysTundra [OP] New Member
    Phoenix
    2023 Solar Octane TRD Pro
    Living in Phoenix we don't get much rain... Except this past month. I popped my truck bed open to be greeted with soggy wet gear I store under the canister of my Retrax XR. Going through car washes there's never been a drop of water get through the canister, but these recent rains have left my truck bed fairly soaked.
    Got it installed by Rack Attack Tempe but they're not responding, and it's a hike to get back to that side of town.
    I dried everything out, wiped it down /brushed off the rust, and got some tarp bags to help weather proof the gear to stay in truck bed storage.
    Any other advice?
  2. Dec 6, 2023 at 2:23 PM
    RobertD
    Robert
    DFW, Texas
    I know my 2.5 gen has 2 drain lines under the canister. Might check to see if you have open holes there since I don't see drain lines. Its possible the 3rd gen is different but I'd assume the water from the canister goes somewhere..... really, its a wild goose chase until you have a better idea where its leaking. If you have a gap somewhere that would do it, if things aren't adjusted or tightened I could see it leaking. Sorry you had this happen, I get a little water in my bed but I also did with my tri fold.
    RickyBobbysTundra[OP] likes this.
  3. Dec 6, 2023 at 5:54 PM
    Cassidy1866
    Cassidy1866 New Member
    2023 Tundra Limited TRD Off-Road
    I’ve driven through monsoons with almost no water getting into my Retrax-covered bed.
    @RobertD is on point - looks like Rack Attack owes you two drain tubes and an apology.
    RobertD likes this.
  4. Dec 6, 2023 at 7:08 PM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    I don't see drain tubes? You should've drilled holes slightly larger in the bed to accommodate them. The connections to the bottom of the tub can be a pain. You have to make sure the tabs on both sides are flared out and catch or they will leak.
    The circles are where they should be.
    I have this unit on mine, and have zero issues.
    Randy B
  5. Dec 7, 2023 at 3:06 PM
    RickyBobbysTundra
    Phoenix
    I called rack attack and they said they are gonna order the train tubes and install for free
    Sixty9Four20 and RobertD like this.
