  1. Dec 6, 2023 at 10:12 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Voss and 455h0le_dachshund like this.
  2. Dec 6, 2023 at 10:34 AM
    I found a pic of those codes. This was from back in August.
    Voss likes this.
  3. Dec 6, 2023 at 10:35 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :eek2:
    Yeah you misfiring like a MFer.
    Didn't you recently replace all the coil packs? Did you do the spark plugs too?
    Given your mileage and the fact you have multiple misfires and lean codes, I'm gonna say it's time for injectors.
  4. Dec 6, 2023 at 10:38 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  5. Dec 6, 2023 at 10:45 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Didja get enough from those SHO's to get a 5.3 or 4.8 LS & megasquirt? I'd bet @JakeJake could build an adapter plate & flexplate.
    lq9.
  6. Dec 6, 2023 at 11:17 AM
    Mr.bee[QUOTED] likes this.
  7. Dec 6, 2023 at 11:18 AM
    Did you pull neg batt cable for 10min after the new MAF?
    oscardog86 likes this.
  8. Dec 6, 2023 at 11:19 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I thought it woulda been insulting to ask. Of course he did.
  9. Dec 6, 2023 at 11:20 AM
    I like to hot swap the MAF with the engine running for maximum effect.
  10. Dec 6, 2023 at 11:32 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Knife edge the tb plate & cut the turbulence. If fact some sorta resistor could be used to help a truck with a filter & headers run richer to compensate for the flow... i dunno, efi tuning doesnt make any sort of sense until you're adding boost & compression...my truck gets out of its own way fine, & i've never needed more power for the loads i pull. The engine is tuned to be happy in 3rd at highway speeds & heavy. Never even had trouble with my brakes, but maybe the powerstop z23's are making it work. The as a fan of the manual trans; i do appreciate the OD button, but i would prefer a +/- toggle like the titan has. The 4 speed can take jeep aw4 (flappy paddle) controls, but there is an aussie company that makes tunable controllers. You get the toggle, but you can program what the trans does & makes a detroit 3-53 swap that much easier.
  11. Dec 6, 2023 at 11:36 AM
    I saw they make a TB spacer for the 2UZ, saw it the other day, a couple of manuf'ers. Granted, it was in a 'sponsored result' price advert at a website I was on, but ... I didn't realize it was a thing. I guess I should've though.
  12. Dec 6, 2023 at 11:44 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Tb spacers are a lol. Especially the tornado or whatever ones. You would want 8 tubes (if the throttle plate tip backwards, you'd want the 8 tubes on top. If it tips forward, you'd want those tubes at the bottom. Running a chunk of higher velocity air into the ports.
    455h0le_dachshund likes this.
  13. Dec 6, 2023 at 11:54 AM
  14. Dec 6, 2023 at 12:00 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  15. Dec 6, 2023 at 12:02 PM
    Read the whole post! That was August.
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1771#post-3404256
  16. Dec 6, 2023 at 12:03 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    The later model 1st gens have a fan spray nozzle. Which that one is.
    Yikes. Check your wiring for rodent damage? Bad ground for the coils?
  17. Dec 6, 2023 at 12:04 PM
    Not yet. I'm charging the batteries for him and he'll be here this month sometime. No chebby motors for me. I'd do a cummins 4bt with a 6 spd manual and a manual xfer case. But, that'd be hard to do with only $3500.
  18. Dec 6, 2023 at 12:05 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yes
  19. Dec 6, 2023 at 12:09 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    3-53 detriot. 2 strokes are the meat, 4 strokes are potatoes.
    https://youtu.be/f1WDZ-49BRQ?si=fUbVITbt5YKi4asV
    txagg likes this.
  20. Dec 6, 2023 at 12:34 PM
    I did clean out a nest from under my intake, but that was 5 years ago.
  21. Dec 6, 2023 at 12:54 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    This is the way.
  22. Dec 6, 2023 at 1:31 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    We need a poll! I'm old and bearded :)
    bmf4069, txagg and oscardog86 like this.
  23. Dec 6, 2023 at 1:46 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    So what age begins old? To millennials, I’m old at 41. Oh, I’m also bearded:thumbsup:
    bmf4069, oscardog86 and Jack McCarthy like this.
  24. Dec 6, 2023 at 1:48 PM
    rock climber
    It's a state of mind and I feel old. Also when you get a small scratch and it takes 6 months to heal.
    txagg and Jack McCarthy like this.
  25. Dec 6, 2023 at 1:54 PM
    Thirty and over according to the movie Logan's Run.
  26. Dec 6, 2023 at 2:00 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    According to the kids at work, anyone born in the 20th century, i.e. your birth year starts with a 19, is old:boom:
    NUDRAT likes this.
  27. Dec 6, 2023 at 2:36 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I like to attempt to startup with MAF unplugged, myself.
    KNABORES[QUOTED] likes this.
  28. Dec 6, 2023 at 2:38 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You going to get your truck tuned or no?
  29. Dec 6, 2023 at 2:41 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    And? Didn't you say it's still fucked? I did not see you mention spark plugs, maybe I skimmed over it. I still say injectors. You can have my OEM injectors for the price of shipping if you want em. You'll have to get em refurbished.
    If your brakes are pulsing, it's probably the rears. I had that issue myself after changing the drums and stuff. Turns out one was bad.
  30. Dec 6, 2023 at 2:52 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    FTFY Millennials are in their 30's and the oldest of us are already 40. That's how long we've been the butt of bad jokes.
    OverSquareEng likes this.
