Gap in tailgate
Discussion in '3rd Gen Tundras (2022+)' started by weifert, Dec 5, 2023.
  1. Dec 5, 2023 at 8:43 PM
    weifert
    weifert [OP] New Member
    I seem to have a pretty large gap in each upper corner of my tailgate if my 22Tundra limited. See red circles in the pic, taken when sitting in the truck looking backwards.
    I looked around at the new tundras at the dealership today here in Dallas, and all of them seem to have the same type of gap.
    Has anyone tried to address this gap yet? If so, which tailgate seal did you use? There seems to be a ton of them on the market, and I wasn’t sure which one would be best.
  2. Dec 5, 2023 at 9:02 PM
    Hella Krusty
    Hella Krusty New Member
    NORTHof54 and weifert[OP] like this.
  3. Dec 6, 2023 at 5:39 AM
    jcneng
    jcneng Retired
    2023 1794 Off Road Crewmax MGM
    I need to do something as well. I took care of the bottom but on a recent snowy drive quite a bit of snow was sucked in on each side.
  4. Dec 6, 2023 at 6:18 AM
    Todd34
    Todd34 New Member
    I ordered the Retrax gasket and then used the extra to just fill in the gaps where I could. Most of those gaskets seem to be similar so you'll probably be fine with whatever you choose. The tailgate has a lot of gaps though and I don't see it ever being totally sealed.
    weifert[OP] likes this.
  5. Dec 6, 2023 at 6:41 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    Do these seals help with dirt that accumulates in the bed? Some of my tools have a good film of dirt lol
  6. Dec 6, 2023 at 6:42 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    That is a really big gap. Mine dies not have that. I added a Revolver cover and tailgate seal a few months ago. My only weak spot post install was the top gap between tailgate and side bed wall. Added some additional weather stripping on each side and all is dry. Not sure any tailgate seal is magic. Most are similiar. Being very careful with the install and any cuts is key. Like doing a roof; water will be present so just keep in mind how water will flow
  7. Dec 6, 2023 at 7:46 AM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
  8. Dec 6, 2023 at 8:28 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I live 7 miles from the nearest paved road. Our county roads get incredibly dusty. I have a MX4 tonneau cover, and my bed gets filthy. I've tried 3 different tailgate gasket kits, and they've only helped a little. I'm going to try the above solution next.
    I've never understood why truck manufactures can't design a tailgate that seals like a regular passenger door.
  9. Dec 6, 2023 at 9:56 AM
    weifert
  10. Dec 6, 2023 at 9:58 AM
    grnwdjsn
    grnwdjsn New Member
    2023 Tundra Limited TRD Offroad
    I got everything at ACE hardware. I used the thicker expanding weather seal on side and in the big corner gaps. This really cut down on the amount of dust in my bed during my trip to Colorado in the fall. I still get a little water in the corners, but I think this is a tonneau cover issue.
    Tundrastruck91 and weifert[OP] like this.
  11. Dec 6, 2023 at 11:01 AM
    ArticTundra
    ArticTundra New Member
    Cold
    I did the same stuff that Hell Crusty did. Seems to work ok
  12. Dec 6, 2023 at 11:49 AM
    jgoliath
    Good ol lowes. Self expanding weather stripping.
    weifert[QUOTED][OP] likes this.
  13. Dec 6, 2023 at 11:51 AM
    Hella Krusty
    No dust , no moisture. I also pulled the tail gate bump stops out so there was a continuous seal from top to bottom...opposite of what grnwdjsn did above where he cut around them
    mayan[QUOTED] and weifert[OP] like this.
  14. Dec 6, 2023 at 12:58 PM
    Matt2015Tundra
    2023 1794 CrewMax
    I tried that kit and wasn't unimpressed. It stopped maybe 25% of the dust from getting into the bed...maybe.
    How much driving do you do on dusty dirt roads?
  15. Dec 6, 2023 at 4:40 PM
    Hella Krusty
    Would as little as possible be an insult LOL. I dont know, I just drive where I need to go. Being Canadian our issue is moisture, fuckin rain and snow. If I can stop the wet...it will stop the dust
    Mattedfred likes this.
  16. Dec 6, 2023 at 5:17 PM
    windblown101
    windblown101 New Member
    2019 CrewMax Limited
    Because it's an open bed truck, not an SUV. Those seals would get wiped out quickly doing truck stuff.
    Though the gap the op showed looks huge. I'd be pissed. I wonder if they did it to squeeze an extra .25 MPG out of the vehicle by improving airflow at speed slightly.
  17. Dec 7, 2023 at 7:27 AM
    Matt2015Tundra
    2023 1794 CrewMax
    I drive dusty dirt roads daily. I sprayed my bed out a week ago. Here's what it looks like today using the gasket kit you recommended. If you look closely, you can see that pea-sized and smaller gravel also accumulates in the bed. There's got to be a better solution.
    mayan and weifert[OP] like this.
  18. Dec 7, 2023 at 9:43 AM
    Hella Krusty
    Weird......its all I got LOL
  19. Dec 9, 2023 at 4:21 PM
    mayan
    Mayan
    DFW
    Do you have any seals overlapping the bed and tailgate? That gap might be letting dirt in since it’s behind the rear axle.
  20. Dec 9, 2023 at 4:25 PM
    Hella Krusty
    I think its his cover, and not so much the seals. Maybe the cover is lifting a bit while under travel ?? Or it isnt sealed to the box rails?
    Its absolutley filthy in there so it isnt like some little gap exists.
    I would pour water to it, if dust gets in....water will pour in.
  21. Dec 9, 2023 at 4:31 PM
    mayan
    Mayan
    DFW
    Could be
    Hella Krusty[QUOTED] likes this.
