2024 Tundra Pro Grill install
Discussion in '3rd Gen Tundras (2022+)' started by Foxfloat50, Dec 4, 2023.
  1. Dec 4, 2023 at 3:32 PM
    Foxfloat50
    Foxfloat50 [OP] New Member
    2024 Tundra Limited
    Has anyone installed a pro grill on a 2024 Tundra Limited TRD Off-road? If so were there any modifications required?
    Thanks in advance
  2. Dec 4, 2023 at 5:54 PM
    sirroncire
    sirroncire New Member
    Sherwood, OR
    2024 Platinum Hybrid CM in CSM
    I’m just going to go out on a limb here and be a nice guy for someone who is also new. Yes, the camera is a mod you will need to accommodate but there are several solutions such as trail hunters. I would implore you to do a search regarding this as it’s a heavy discussed topic. When you search make sure to choose the 3rd gen forums and use the “Search this thread only” to help refine your search results.
  3. Dec 5, 2023 at 4:47 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    It’s the same as any other 22+ tundra. Easy enough to do and is a direct swap besides the front camera. If adding marker lights / light bar there is minor wiring. Search here and YouTube and you’ll find everything you need.
