Tonneau cover causing tailgate to stick
Discussion in 'Tonneau Covers, Caps and Shells' started by ehrab, Dec 1, 2023.
  1. Dec 1, 2023 at 3:46 PM
    ehrab
    ehrab [OP] New Member
    Hi folks, recently installed a Toyota OEM cover for my TRD pro PT954-34223 and I am having a hard time with the tailgate not opening. I pushed the cover all the way forward to the cab and it’s still getting stuck. Have to pull on the tailgate for it to open. Any ideas why it’s getting stuck?
  2. Dec 1, 2023 at 3:50 PM
    Tom976
    Tom976 New Member
    Tom
    Lift the cover a little bit and that should release some of the tension on the tailgate.
    To seal or not to seal is the question.
  3. Dec 1, 2023 at 4:16 PM
    ehrab
    Yikes. Doesn’t sound like a well designed part. lol.
  4. Dec 1, 2023 at 4:44 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    Do you want water entering or not?
  5. Dec 1, 2023 at 7:15 PM
    ehrab
    All the videos I’ve seen don’t seem to have this issue.
  6. Dec 1, 2023 at 9:35 PM
    Hella Krusty
    Hella Krusty New Member
    Mine ( Toyota OEM ) you can open with 1 hand, or push the button on the light and it just falls open?
  7. Dec 2, 2023 at 4:01 AM
    ehrab
    Yes, this is what I’m trying to achieve but I can’t figure out what the issue is.
  8. Dec 2, 2023 at 7:40 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    When closed, is the top of the tailgate flush with the top of the side rails of the bed?
    Post a few pics of the rear corners of the bed, with the cover open and closed.
  9. Dec 2, 2023 at 7:45 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    This happens to me now that it is winter, the tailgate is freezing to the cover. What climate are you in?
    Nm6300'asl likes this.
  10. Feb 23, 2024 at 8:43 PM
    jeremyd859
    jeremyd859 New Member
    Jeremy
    Black Toyota Tundra 1794
    Modified exterior to have same look as the Capstone. Take off 22" oem Capstone wheels and new stock tires. Switched grill and lower grill and camera to Capstone series. Ordered body match painted grill surround. Had lower bumper and fender flairs painted body match. Ordered body match painted rear bumper caps. Carbon ceramic tint added. OEM tonneau cover added. Really like the Capstone look but didn't need a hybrid nor did I like the interior of the Capstone or the extra cost.
    I just installed an OEM Tonneau cover and have it pushed as far toward the cab as possible. The auto tailgate drop will not work. I have to assist the tailgate to get it to drop. The tailgate is sticking on the cover. As of now I'm not sure why. Any help is appreciated.
  11. Feb 24, 2024 at 11:36 AM
    ehrab
    Mine resolved over time.
  12. Feb 26, 2024 at 6:57 AM
    jeremyd859
    Jeremy
    Update: I removed the cover to confirm it was pushed as far as possible to the cab, it was. I then reapplied the cover, it continued to stick when trying to drop the tailgate. I then sprayed the tailgate locking mechanism with WD40. I then applied a silicone spray to the rubber weather strip under the back of the cover. The tailgate now drop's perfect with no issues.
    BoomBoomGanoom likes this.
  13. Feb 26, 2024 at 8:41 AM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    That’s a nice tight seal. If you want it loose enough for the gate to pop open it will leak along the edge. Your choice.
    jeremyd859 likes this.
  14. Apr 17, 2024 at 9:30 AM
    MattMan
    MattMan New Member
    I am purchasing this item with my new truck. Is it worth the $350 the dealer is charging for the install?
  15. Apr 17, 2024 at 11:34 AM
    Txrx
    Txrx New Member
    Patrick
    Bellingham WA
    2023 Silver tundra Limited TRD OR, Crew max, 5.5ft
    MX4 Tonno, Go Rhino E-boards, Method 705, BFG AT 285/75/17, Rigid amber fog lights
    Pressing the button a second time and mine would drop. Then added silicon spray and it drops the first time now
    PNW Tundra Mike likes this.
  16. Apr 17, 2024 at 1:43 PM
    jeremyd859
    Jeremy
    That all depends on how busy you are and what your time is worth. I thought the install was pretty easy, and hour or two at most.
  17. Dec 4, 2024 at 5:09 AM
    rapamatic
    rapamatic New Member
    I just wanted to bump this and give a +1 on the silicon spray. I just installed an EGR RollTrac cover and was having to push the release button twice on the tailgate (and it would not drop from the fob or the taillight button). But a quick blast with silicon spray along the seals freed things up and it will now drop and open easily. I don't think this impacts the water resistance of the seal... if anything the silicon spray should prolong the life of the seals (I think).
    Txrx likes this.
  18. Dec 4, 2024 at 5:52 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Does the factory cover easily come off the truck as simply as it folds up? I’m not crazy about folding it up against the cab for big items when I need to do that. Just curious.
  19. Dec 4, 2024 at 11:05 AM
    Hella Krusty
    I had that same concern so I put it up and drove 80 MPH for about 2.5 hours and it didn't budge. Wanted to know it would stay attached before I had a load of something in the back
  20. Dec 4, 2024 at 1:10 PM
    Txrx
    Txrx New Member
    Patrick
    Bellingham WA
    Silicon should be fine for the gasket, just dont huff it. It’s the secret sauce here for door gaskets if the cold freezes them closed. It chases the water away.
  21. Dec 4, 2024 at 1:15 PM
    2wheelsforfun
    2wheelsforfun New Member
    If it's a bakflip then it should have a rod on either side to hold it open, against the back window, it also has a soft rubber bumper that holds it from hitting the back of the truck. If you don't need the entire bed, you can leave the last section and the folded sections will clip onto the last to keep them from flipping up. I had a soft tonneau cover for years that I thought worked well, until the velcro wore out and I couldn't keep it secured in any amount of wind. Thought I would hate a hard folding cover but after having one for years now would never go back to a soft. They work well.
    I don't believe there is an easy way to remove the cover and don't think it's necessary.
    Alex261[QUOTED] likes this.
  22. Dec 4, 2024 at 1:26 PM
    Txrx
    Txrx New Member
    Patrick
    Bellingham WA
    Not sure about the factory tonno, but the Mx4 bakflip can come off, two carriage bolts in the most forward section go through a plate and have threaded knobs on the inside. Just unscrew those and off she goes. Last I saw the factory tonno looked like a clone of the bakflip or vise versa
  23. Dec 4, 2024 at 1:27 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    If it's a Bakflip (which I' believe the OEM are) there's two knobs underneath. Super easy to remove the whole cover... probably 5 minutes
    Txrx likes this.
  24. Dec 4, 2024 at 2:11 PM
    SD Surfer
    Bruce
    So Cal
    You type faster than me. :rofl:
    Txrx[QUOTED] likes this.
  25. Dec 4, 2024 at 3:53 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    I’m learning to love it as well. I had a roll up cover that I thought was perfect and easy and I wasn’t thrilled that this truck came with a $1300 hard fold but I think I will be loving it in time and it seems like my stuff will be totally dry
  26. Dec 4, 2024 at 6:03 PM
    2wheelsforfun
    Plus I have moved some larger items that wouldn't fit easily in the bed on top of the cover, could never do that with a roll up.
