Infotainment Issue (22 Platinum 14" Screen)
Discussion in '3rd Gen Tundras (2022+)' started by amilaw, Dec 29, 2022.
  1. Dec 29, 2022 at 6:44 AM
    amilaw
    amilaw [OP] New Member
    2022 Tundra Platinum
    Tacotunes catalytic converter shield, OEM bed cover
    Ran into a first world problem recently and wanted to see if anyone else has seen it and if they found a fix. It used to be when you asked "hey Toyota" for the weather it would not only tell you the weather, but also show you the weather. Now it only tells you the weather and the screen that normally shows the weather comes up, but it's blank. It doesn't show anything no matter how long you leave it on that screen.
    I initially thought it was me being in an area with low cell reception, but it doesn't seem to be the case. I've tried in areas where there is good reception and the command has worked flawlessly before, but it no longer seems to.
    Gray Hawk likes this.
  2. Dec 29, 2022 at 6:47 AM
    wootFKH
    wootFKH New Member
    22 Tundra Limited w/ pkgs
    Goodyear Ultraterrain 275/65/R20 Chrome Delete Front bumper Tundra decal in white Black out emblems Predator Drop steps Spray in bed liner
    I am not sure what the issue is, I've never tried this. I know the infotainment won't show information if the vehicle is moving sometimes. Just a guess but have you tried that option when the vehicle is not moving or possibly in park?
  3. Dec 29, 2022 at 7:16 AM
    amilaw
    Yeah that was one of my thoughts as well and thought maybe they disabled viewing it while driving, but doesn't seem to be the case. No longer works when parked either. It's odd that the screen for showing weather comes up but its just a blank screen (with the background color). I'll see if I can get a picture of it next time.
  4. Dec 29, 2022 at 7:29 AM
    wootFKH
    wootFKH New Member
    I just tested it on mine. I drove around the parking lot(nothing higher than 15MPH) it works driving and parked. It pops up the weather with a picture(not weather radar) from accuweather. I wish my one buddy was at work, I would ask him about this. My truck still has all the trials going I believe, I wouldn't think it's dependent on those. If you are comfortable, send me your vin via a private/direct message, I can check the telecoms and maybe a few other things to see if something is blocked.
  5. Dec 29, 2022 at 7:48 AM
    TundraWorkHorse
    TundraWorkHorse New Member
    2023 Toyota Tundra Platinum
    Works for me parked and driving
  6. Dec 29, 2022 at 8:40 AM
    amilaw
    Yeah there wasn't ever a weather radar that I remembered, but the basic forecast like in the post above was what always showed up. I'll PM you the VIN shortly. Thanks for looking into it. By the way I did get the parking brake recall/SB updated about 2 weeks ago and I don't remember it being an issue before. Not sure if they are somehow related software wise but also another thing to note.
  7. Dec 29, 2022 at 8:56 AM
    nodak67
    nodak67 New Member
    JR
    if i remember correctly, the weather is updated via hd radio station, at least it was on the old head units (its listed in the manual in my 14 4runner)
  8. Dec 29, 2022 at 9:11 AM
    wootFKH
    wootFKH New Member
    You are correct, that data was HD Radio as long as that signal was being recieved and broadcast through FM HD Radio. I can't confirm how the data is transmitted to the new trucks but I would bet it's cell data based.
  9. Dec 29, 2022 at 9:31 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Is this a Platinum only feature? My 2019 had a weather icon I could select. This 2022 doesn't but I do have the 14" screen.
  10. Dec 29, 2022 at 9:43 AM
    wootFKH
    wootFKH New Member
    It's part of the Toyota Intelligent Assistant, as long as you have it enabled on your radio, Say Hey Toyota, wait for a response than say show me the weather
    Rockgate[QUOTED] likes this.
  11. Dec 29, 2022 at 1:43 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Thanks. I got in my truck before I seen this and pushed the mic icon, and asked. Then a TalkBack told me. I thought well at least it says it, then it popped up on the screen. I then tried asking for other areas around the world. My son asked where's the coldest place in the world and it said Siberia -90° or so.
  12. Dec 29, 2022 at 2:20 PM
    wootFKH
    wootFKH New Member
    Next ask for the temp in Hell, Norway. Right now its 41f. If you got the same temp you can say it's cold as Hell. Good thing you're a dad, you can get a pass on that stupid joke. :monocle::bananadance:
  13. Oct 21, 2023 at 10:37 AM
    SteveKellyS
    SteveKellyS New Member
    Stephen
    2022 Tundra Limited
    Has the weather not showing on the info system issue been resolved? This problem just showed up on our 2022 Tundra Limited. The system says the weather like it always has, the screen is just a blank blue screen. It worked correctly for the past 1+ years.
  14. Oct 21, 2023 at 4:29 PM
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Just curious have you tried rebooting the infotainment system? While on push the volume button down until the screen turns off and reboots. It’s kind of like hard resetting your phone
  15. Oct 21, 2023 at 6:28 PM
    SteveKellyS
    Stephen
    2022 Tundra Limited
    THank you for the idea Matth66! I will give it a try tomorrow and get back to you.
  16. Oct 21, 2023 at 6:57 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    You don't have to press talk either, Toyota is always listening.:eek:
  17. Oct 22, 2023 at 11:12 AM
    SteveKellyS
    Stephen
    2022 Tundra Limited
    Matth66, I tried rebotting the infotainment system today. The problem with weather not displaying after the verbal weather is reported still exists. Any additional recommendations will be appreciated.
  18. Oct 22, 2023 at 11:35 AM
    pwpblue
    Greensburg,PA
    :blahblah:
    ryanwgregg[QUOTED] likes this.
  19. Nov 7, 2023 at 4:28 PM
    CitySlicker1794
    CitySlicker1794 New Member
    I have the same issue with my 2023 1794 edition. It used to works for three months, then it stopped working a couple of weeks ago. I have tried testing it with the truck parked as well and I get the same blank screen as is reported in the threads above.
  20. Nov 7, 2023 at 6:52 PM
    SteveKellyS
    Stephen
    2022 Tundra Limited
    CitySlicker179 - I still have the issue with the weather not showing on my display. I called Toyota's 800# last week... they were not able to help me. They advised to discuss the issue with my dealer. I plan to tell the dealer... but not until an oil change is due... probably in the next 6-8 weeks. Good luck! I hope you find a solution before I do. I don't believe Toyota is going to fix the issue until enough people complain about the problem.
  21. Dec 1, 2023 at 2:05 PM
    CitySlicker1794
    They deleted my profile, then I had to follow the prompts which included entering my cell number, and having the app scan a QR code on the display for authentication. Once completed, the toyota Infotainment system was set up. I used the voice command "hey Toyota will it rain tomorrow?", the system replied and provided the weekly weather again on tge screen.
    Problem resolved.
    You need to have Toyota do the reset.They said it is not possible with a simple reboot.
    Matt2015Tundra and OLV1071571 like this.
  22. Dec 1, 2023 at 5:41 PM
    SteveKellyS
    Stephen
    2022 Tundra Limited
    THANK YOU CitySlicker1794! I am glad to learn that there is a solution.
  23. Dec 1, 2023 at 6:50 PM
    CitySlicker1794
    Your welcome. I am glad there is a platform like this where we can all help each other out.
