Painting Front Tow Loops (Process & Pics)
Discussion in '2.5 Gen Tundras (2014-2021)' started by THOR's, Dec 1, 2023.
  1. Dec 1, 2023 at 2:29 PM
    THOR's
    THOR's [OP] New Member
    Thor
    North Carolina
    2021 Tundra TRD Sport and XP Predator Package
    I had a free afternoon today and thought I'd play with the Tundra a bit. Truck now has 30k on the clock and still loving it every time I drive it. Over the past 4 to 6 weeks I've been thinking about painting the front Tow Loops, but I keep forgetting about stopping to pick up a can of gloss yellow paint to give the truck an accent with a pop of color. This afternoon I was a lazy a$$ and settled for a can of spray paint I had laying around the garage.
    First order of business was the removal of the 2 tow hooks from the frame. Two 11/16 bolts on each bracket and they were off. There was a bit of a surprise that there was bare steel under the Tow Loops. Seems the frame was painted after the installation of the loops. Anyone else see this? I gave each side a quick sanding with some 100 grit dry sandpaper.
    Then the fun began.. as my old man (now I'm the old man) told me, 90% of the paint job is the prep so I began with the 100 grit and then used a scratch pad to make sure all surfaces were roughed up so the applied paint would not have an issue clinging to the surface.
  2. Dec 1, 2023 at 2:36 PM
    THOR's
    Thor
    North Carolina
    Prior to painting, I washed all parts with soapy water, followed by blowing the parts off with air pressure to ensure no water remained in the cracks. Once dry, painted the Tow Loops with the red paint I had on hand.
  3. Dec 1, 2023 at 2:39 PM
    THOR's
    Thor
    North Carolina
    While paint was drying on the Tow Loops, touched up the bare spots on the frame. Still thinking the loops were bolted on the frame and then it was either dipped or painted.
  4. Dec 1, 2023 at 2:42 PM
    RobertD
    Robert
    DFW, Texas
    :thumbsup:
    You'll enjoy the pop of color those provide! Loved having my blue ones peaking from under the bumper.
    BlueRibbon4x4 and THOR's[OP] like this.
  5. Dec 1, 2023 at 2:43 PM
    THOR's
    Thor
    North Carolina
    Here are a few pictures with the Tow Loops bolted back on the frame. Paint matched a lot closer to the sway bar than I originally thought.
    RustyShackle323 and RobertD like this.
  6. Dec 1, 2023 at 2:46 PM
    THOR's
    Thor
    North Carolina
    All done... came out better than I thought! What do you guys think?
  7. Dec 1, 2023 at 2:49 PM
    THOR's
    Thor
    North Carolina
    You picked the right color since that blue on your truck pops! :101010:
    Thanks Bro!
    RobertD[QUOTED] likes this.
  8. Dec 1, 2023 at 3:00 PM
    biebs96
    PA
    Looks good.
    I bet if you hit them with a gloss clear coat they would match the sway bar perfectly.
    THOR's[OP] likes this.
  9. Dec 1, 2023 at 3:06 PM
    THOR's
    Thor
    North Carolina
    Hmmm... good idea. The paint was very close. :thumbsup:
    biebs96[QUOTED] likes this.
  10. Dec 1, 2023 at 3:25 PM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Looks great. So no prime, right to paint, right? On my list of things to do for sure. Great write up, thanks.
    CaptRussia253 and THOR's[OP] like this.
  11. Dec 1, 2023 at 4:19 PM
    THOR's
    Thor
    North Carolina
    Since I did not go down to bare metal except for a few small spots when sanding, I felt there was no need to prime the tow loops. I wasn't concerned about the underside of the loops (where they come in contact with the frame) since they were bare metal to bare metal from the factory. The enamel I used provides 2 layers (red paint and black) so there is no raw metal contact any longer. Figured this should suffice.
    Xcumminsguy[QUOTED] likes this.
  12. Dec 1, 2023 at 4:30 PM
    singletrack_dad
    singletrack_dad New Member
    Ty
    2014 TRD OR CM
    Yeah buddy I did the same and no REGERTS.
  13. Dec 1, 2023 at 4:35 PM
    THOR's
    Thor
    North Carolina
    Whew... that red just pops and accents the truck perfectly! Glad I went ahead and made the mod! :yay:
  14. Dec 1, 2023 at 4:39 PM
    singletrack_dad
    Ty
    2014 TRD OR CM
    I also painted my factory crappy skid plate light gray and I also have no regrets on that one, though mods like that sometimes look really cheap and bad im stoked on it.
  15. Dec 1, 2023 at 4:45 PM
    THOR's
    Thor
    North Carolina
    I was thinking about that but with Christmas coming, I asked for the aluminum TRD skid plate. Maybe the family will chip in and get that for me!
    RustyShackle323 likes this.
  16. Dec 1, 2023 at 8:34 PM
    SYNCRO
    SYNCRO New Member
    These red loops are looking great fellas. Not to hijack but what size BFGs are you running?
  17. Dec 2, 2023 at 4:08 AM
    singletrack_dad
    Ty
    2014 TRD OR CM
    315/70/17 on bone stock suspension & no CMC
    SYNCRO[QUOTED] likes this.
  18. Dec 2, 2023 at 4:22 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Thanks for the nice write up! On my list to do very soon! If your family does get you the TRD skid plate, I’d take your stock one off your hands ;):)
  19. Dec 2, 2023 at 4:33 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Can I send you mine,I must have not let them dry completely when I painted mine they are all crazed and cracked and look like crap
  20. Dec 2, 2023 at 4:40 AM
    THOR's
    Thor
    North Carolina
    I’ll keep you in mind! :p
  21. Dec 2, 2023 at 4:44 AM
    THOR's
    Thor
    North Carolina
    Sorry to hear that… could very have well not been dry or there was some oil/grease film on the loops. I washed mine off with Dawn dish washing detergent (remove oil and grease), blew them off with the compressor, and then painted after about 30 minutes (made sure they were dry). Put light coats on and used a heat gun to ensure the paint was dried before applying another coat.
  22. Dec 2, 2023 at 4:46 AM
    singletrack_dad
    Ty
    2014 TRD OR CM
    I live in Phoenix az so I didn’t even clean mine I just primed them & painted them lol. Came out easy especially when it’s 118* outside.
    Edit ok nvm I did clean mine in a soapy bucket lol I just remembered.
    THOR's[QUOTED][OP] likes this.
  23. Dec 2, 2023 at 4:47 AM
    19PlatinumCrew
    Dave
    What was the color code you used they look perfect
  24. Dec 2, 2023 at 5:01 AM
    THOR's
    Thor
    North Carolina
    At 118 degrees you certainly don’t need to be using a heat gun! :rofl:
    I also suspect there is little to no humidity… it’s a dry heat! Perfect weather for painting.
  25. Dec 2, 2023 at 5:02 AM
    singletrack_dad
    Ty
    2014 TRD OR CM
    Here’s what I used
    THOR's[OP] and RustyShackle323 like this.
  26. Dec 2, 2023 at 5:04 AM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    I need to get off my @$$ and do mine,l. I'm going to sandblast, then paint them.
    THOR's[OP] and Xcumminsguy like this.
  27. Dec 2, 2023 at 5:18 AM
    THOR's
    Thor
    North Carolina
    This is what I used, believe it or not the paint can states it’s a Ford red. Interesting :monocle:
  28. Dec 2, 2023 at 5:22 AM
    THOR's
    Thor
    North Carolina
    I have a glass bead setup and was thinking about blasting them, but since they were in such good condition I figured I’d leave the factory finish and apply the red as a top coat. If I had a lot of bare metal I would have definitely primed them like you did.
    :thumbsup:
  29. Dec 2, 2023 at 5:26 AM
    THOR's
    Thor
    North Carolina
    If I wasn’t in a hurry, I should have went out to the store and bought some Rust-oleum! I suspect you’ll never have to touch them up.
  30. Dec 2, 2023 at 12:43 PM
    singletrack_dad
    Ty
    2014 TRD OR CM
    On my Tacoma I painted the entire armor of the truck with rustoleum self etching primer and satin paint. No issues. Especially out here in the SW
