ABS and traction control light on. No codes on Scanner. What could it be?
Discussion in 'General Tundra Discussion' started by RockWarriorLover, Nov 26, 2023.
  1. Nov 26, 2023 at 8:49 AM
    RockWarriorLover
    RockWarriorLover [OP] New Member
    MGM 2013 Rock Warrior
    3 inch lift, Flowmaster catback exhaust, BFGoodrich 35s, Rough Country Bull Bar with LED Light Bar. Fender flares
    Hey guys, i need help, ABS light and traction control light are on. Scanned for codes, No codes are present. took MAF sensor off to check if it was the scanner, scanner found the code for MAF sensor. But no codes showed up. I took out a abs sensor, and 4HI started blinking. I put it back in but still the same. I took out the transmission speed sensor and tested with a voltmeter, its fine as well. What could it be?
  2. Nov 26, 2023 at 9:21 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    how long have they been on? mine does that after I disconnect the battery and they usually go off after a short drive. have you tried disconnecting the battery to reset it?
  3. Nov 26, 2023 at 9:37 AM
    RockWarriorLover
    Yes i disconnected it 3 or 4 times, lights came on Wednesday when i was towing. Checked fuses, those are good. What else could it be?
  4. Nov 26, 2023 at 9:42 AM
    helidave
    flagstaff
    2015 DC 4x4
    did you check all 4 abs sensors and plugs? they can get damaged pretty easily
  5. Nov 26, 2023 at 9:45 AM
    RockWarriorLover
    I dont think its abs sensors bc 4hi wasnt on until i broke the drivers side abs sensor out. I can check for damaged wires.
  6. Nov 26, 2023 at 10:18 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    First check your taillights. Make sure you don’t have a burnt bulb.
  7. Nov 26, 2023 at 11:48 AM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Steering position sensor. If your steering wheel is off to one side or another it will set off the lights. Such as in need of an alignment
  8. Nov 26, 2023 at 1:49 PM
    RockWarriorLover
    Would that put a light on the dash but not throw a code?
  9. Nov 26, 2023 at 1:53 PM
    Tiamat
    Tiamat New Member
    It did for me, but if your steering wheel is straight while driving then that is not your problem.
  10. Nov 26, 2023 at 2:06 PM
    RockWarriorLover
    Hmm i mean it seems pretty straight but im not sure. not getting any codes so im not sure what it could be. could towing cause anything?
  11. Nov 26, 2023 at 2:08 PM
    helidave
    flagstaff
    2015 DC 4x4
    Did you do any work or mods to the truck recently or change anything else?
  12. Nov 26, 2023 at 2:11 PM
    RockWarriorLover
    I changed the headlights and did an intake abt a year ago. But no nothing rlly. Just headlights
  13. Nov 26, 2023 at 2:12 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    When I was hauling a load of mulch my ABS and traction control sensors alarmed (along with my TSS sensor). Upon doing a little research it was basically because my rear end dropped so much that is threw everything off (my leafs were shot). Once I removed the load and restarted the truck everything went back to normal. I then upgraded my rear suspension to counteract that issue going forward. I know it's not the exact same situation but it certainly could have had something to do with towing causing sag in the rear end causing the sensors to alarm.
  14. Nov 26, 2023 at 2:13 PM
    helidave
    flagstaff
    2015 DC 4x4
  15. Nov 26, 2023 at 2:24 PM
    RockWarriorLover
    Oh okay, yeah my dad bought a cheap Chinese scanner, im sure it prolly didnt catch the codes. Ill invest in a real one. and return it after im done with it.
  16. Dec 1, 2023 at 6:12 AM
    AlexFIA
    AlexFIA New Member
    Tundra Rock Warrior
    I had some warning lights turn on a couple years ago that made no sense (I think it was ABS and 4Hi failure). Dealer tracked it down to a knock sensor wire that rodents had chewed through when they made a home under my intake manifold. Completely unrelated to ABS or anything else. It was a $19 harness and a lot of labor. However, the dealer was able to track down exactly what it was based on the codes they pulled, so as another poster stated, you might want to get a different scanner.
