FIPG curing temperature?
Discussion in 'General Tundra Discussion' started by BlueGarden, Nov 22, 2023.
  1. Nov 22, 2023 at 12:00 PM
    BlueGarden
    BlueGarden [OP] New Member
    Paducah, KY
    2002 Tundra Limited 4x4 4.7L
    Hey everybody, I need to replace my valve cover gasket, and I have FIPG 103 for the 1/2 moons and 90 degree bends. Outdoor temperatures are going down since it's late November, and I'm wondering what kind of effect the lower temps will have on the FIPG curing. It's around 50 F during the day when i would be working on it. Am I setting myself up for problems? I don't have an indoor space to work on the truck.
    Thanks,
  2. Nov 30, 2023 at 11:11 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I used it on my rear differential in Dec 32deg out and it set up.
    snivilous likes this.
  3. Nov 30, 2023 at 1:27 PM
    BlueGarden
    Paducah, KY
    That's good to hear. Thanks!
