Halogen Headlight Upgrade Options
Discussion in '2.5 Gen Tundras (2014-2021)' started by B-Lo, Nov 29, 2023.
  1. Nov 29, 2023 at 4:05 AM
    B-Lo
    B-Lo [OP] New Member
    Brett
    2018 Black Tundra SR5
    I’m looking to swap out my 2018 SR5 stock halogen headlights to an all LED option. What are the best out there?
  2. Nov 29, 2023 at 4:20 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Here ya go. Everything you need to know is probably in here. The search bar is your best bet
    This is the go to thread about this same thing!
    https://www.tundras.com/posts/3397803/
    This will get you to pages of info
    JMGmanAZ likes this.
  3. Nov 29, 2023 at 7:17 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Get the stock LED lights and you need the ihacker harness. One of the best upgrades for the money.
    Jaypown, JMGmanAZ and sonofdad like this.
  4. Nov 29, 2023 at 7:27 AM
    sonofdad
    sonofdad New Member
    steamboat springs, co
    2017 Tundra SR5
    +1 on this ... night and day difference compared to the stock halogens
  5. Nov 29, 2023 at 2:30 PM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    Unless you want to spend big money on Morimoto XB’s..
    Go with OEM LED TRD pro housings with the ihacker harness. I hummed and ha’d about it for a while but oh my what a great upgrade. They look amazing and the light output is fantastic for an OEM light. Ihacker harness is plug and play, and on par with OEM quality, if not higher.
    RobertD likes this.
  6. Nov 30, 2023 at 5:15 AM
    B-Lo
    Brett
    Will the harness also take care of the fast blinking turn signals?
  7. Nov 30, 2023 at 5:36 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    The OEM LED light have halogen turn signals, so you'd have to swap them out with LEDs if you want those. I have an iHacker harness, but just left the halogen bulbs.
  8. Nov 30, 2023 at 5:38 AM
    Taco-Spike
    Two Trucks
    The OEM ‘LED’ headlights don’t have led turn signals or parking lights. Only thing led is drl, high and low beam
  9. Nov 30, 2023 at 8:40 AM
    SPOirish28
    Ontario, Canada
    2014 SSM SR5 DC
    Rapid blinking light usually means you have a bad bulb/ connection
  10. Nov 30, 2023 at 4:06 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I see that most have gone with the LED OEM headlights. How do they compare to the stock halogen headlight with LED bulbs? I installed a set of Auxito LED bulbs and impressed with the light output and sharp cut off line with no scattered light.
  11. Nov 30, 2023 at 4:59 PM
    RobertD
    Robert
    DFW, Texas
    I think you will get variety responses since the led bulbs vary greatly. Going from stock halogen to the pro led headlights was staggering. I did not want to believe it was that much of an improvement, but the first night driving the the led assemblies I probably had double the visibility up front and so much more visibility on the sides. Just crazy improvement.
    Ruggybuggy[QUOTED] likes this.
  12. Nov 30, 2023 at 5:24 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Your absolutely right about the led bulb quality and output. The first set I bought were terrible and I returned them. The second set, the Auxito's are great and a big difference over the stock halogen bulbs. You right in that the question will get such a variety of responses that the info will be meaningless.
    RobertD[QUOTED] likes this.
