Fox 2.0's.....?
Discussion in 'Suspension' started by BeachyTundra, Aug 30, 2017.
  1. Aug 30, 2017 at 8:49 PM
    BeachyTundra
    BeachyTundra [OP] New Member
    Brandon
    Spokane
    2017 MGM 5.7L DC, Bilstein 5100s
    Alright guys, here's the dilemma.
    Truck is currently in the shop from hitting a deer... but, now I need to figure out my suspension. I'll preface by saying it will be a commuter mostly, but I do ride dirt bikes, camp, etc. so I do end up on dirt/gravel roads pretty regularly. I'd do more of it, just unsure of the area thus far.
    So, here's where the fun starts. I used to drive a Tacoma. I miss my little race-car pickup handling.
    I can quite possibly get around a 50% discount on Fox 2.0 shocks, all around. Or I can go the standard 5100 route in the front, and not touch the rear.
    I would like to level it out, and leave a slight bit of rake. I want to go with 275/70-18's, but the tire i'm leaning toward isn't recommended on a 9" rim, and I'm pretty set on rim, so I may have to bump to a 295/70-18, although I really don't want to.
    Any thoughts? Would you go with the Fox 2.0's depending on discount? Does anybody have experience with them on Tundras? Obviously the 5100's are tried and true, and get plenty of love.
  2. Aug 30, 2017 at 8:54 PM
    I would go with the Fox. Can you get a discount on 2.5's?
    blizz86 likes this.
  3. Aug 30, 2017 at 9:07 PM
    BeachyTundra
    Brandon
    Spokane
    Likely, but then I believe I'd be getting into swapping UCA's and such, and I don't want to start down that road.
  4. Aug 30, 2017 at 9:13 PM
    I would check the wheel and tire page on here, they did a kick ass job with the write ups.
    With 295 tires, you will most likely need 3" lift, and would require the upper control arm replacement anyway if you want the ball joint to live.
    You can never have to much shock, even on a road warrior.
  5. Aug 30, 2017 at 9:25 PM
    BeachyTundra
    Brandon
    Spokane
    Eh, who needs ball joints anyways.
    But, I'm planning on a +18 offset wheel, so that should push me out from the UCAs, then it'd just be clearing the fender...I'm thinking I'd probably be okay doing the CMC, but haven't decided yet.
  6. Aug 30, 2017 at 10:41 PM
    It most likely will clear.
    Screw ball joints!!!:headbang:
    Law323 and BakNBlk2014 like this.
  7. Aug 30, 2017 at 10:57 PM
    BeachyTundra
    Brandon
    Spokane
    Poor Tundra is just trying to show off for the camera :wave:
  8. Aug 31, 2017 at 4:14 AM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    Tundra doin that stanky leg
    Kbrdbnt, JC303, Filthy13 and 2 others like this.
  9. Aug 31, 2017 at 7:23 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Aren't most 2.5 coilovers adjustable?
  10. Aug 31, 2017 at 8:05 AM
    renlo
    renlo New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    Actually all coilovers are adjustable. You can always buy any set of coilovers and adjust them to give you less than 3" of lift.
  11. Aug 31, 2017 at 8:08 AM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Not all are. For instance, no OEM coilovers on Tundras are.
    ColoradoTJ likes this.
  12. Aug 31, 2017 at 8:11 AM
    Beat me to it.
    zcarpenter92[QUOTED] likes this.
  13. Aug 31, 2017 at 8:17 AM
    blizz86
    blizz86 New Member
    I would get 2.5's if you could.. the weight of our trucks really do call for it. UCA's arent required for 2.5. If your alignment cant get where it needs to be then, yes, get UCAs. Or if you want a stronger joint and the cool factor.
  14. Aug 31, 2017 at 8:20 AM
    renlo
    renlo New Member
    Rene
    Well, to me, when most people refer to coilovers and lifting, adjustable coilovers come to mind.
    Rica25 likes this.
