Hazard lights work but turn signal does not work
Discussion in '1st Gen Tundras (2000-2006)' started by Toyota dude, Nov 28, 2023.
  1. Nov 28, 2023 at 11:33 AM
    Toyota dude
    Toyota dude [OP] New Member
    Daniel
    2006 Toyota Tundra
    Cai Catback 3inch tru duels no xpipe two stainless steel race mufflers 1500 stall converter aftermarket jasper transmission 4:10 rear end gears aftermarket swaybar very big throttle body spacer throttle control switch all stainless pulls system forged pistions 4.7 bottom end been beefed up last dyno at 376 hp 400 fpt with half the upgrades I beleive I’m getting into the high 400s
    I have a problem my turn signals all of a sudden stopped working hazards still work but no turn signal all fuses and relays seem fine please I need help vehicle is a 2006 Toyota tundra
  2. Nov 28, 2023 at 1:39 PM
    Do your headlights still work?
  3. Nov 28, 2023 at 5:42 PM
    bfunke
    bfunke Tundra Curmudgeon
    Check all your fuses. I’ve seem to recall if the one marked gauges is blown can cause this
