Texoma needs all the chrome
Discussion in '2.5 Gen Builds (2014-2021)' started by texoma, Nov 28, 2023.
  1. Nov 28, 2023 at 2:55 PM
    texoma
    texoma [OP] Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Bought a 2018 white Limited Tundra the day before Thanksgiving 2023 because my Taco w/ 255k miles spun a journal. This pushed the purchase up a year ahead of schedule, but I’m perfectly fine with that. So may as well create a build thread to document all the things I do to this truck. Hope y’all enjoy.
  2. Nov 28, 2023 at 2:56 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    How it sits now, all stock.
  3. Nov 28, 2023 at 2:59 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    First purchase was for my pup and also to keep the leather seats pretty.
    Lusso Gear Dog Car Seat Cover for Back Seat, Protects from Scratches, Scuffs, Shedding, Mud, & More, 100% Waterproof, Non-Slip Cover Stays Securely in Place, Fits Your Car, Truck, & SUV (Black) https://www.amazon.com/dp/B08SHWBMCL
  4. Nov 28, 2023 at 3:00 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Next I replaced the windshield wipers with Rain X wipers from Walmart. Oh and the dog cover thing fits good.
  5. Nov 28, 2023 at 3:01 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Found a guy here in Austin that is trying to de chrome his truck and has chrome side steps. Hopefully I can swap those in for the black ones I have.
  6. Nov 28, 2023 at 3:03 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Sitting at discount tire now getting the tires balanced because it feels like driver front is out of balance. Having them rotate the best tread tires to the rear as well.
  7. Nov 28, 2023 at 3:04 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Just pulled the OE chrome steps off my truck. Getting ready to list them in the market place, likely too cost prohibitive to send them to TX.
  8. Nov 28, 2023 at 3:06 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    I’m also tracking fuel efficiency for the next 2 tanks and when that’s done I’ll tune it with my brand of tune (Triple C Chop Shop Powerthirst Tune) and collect fuel efficiency data from that as well.
    Tundra Parameters, 2.5 Gen Reg Fuel
    1. Accelerator/ Request to airload
    2. ACIS Control/ TPS Zones/ ACIS High TPS
    3. Air Fuel/ Targets/ Wide Open Fuel Target AFR
    4. Engine/ Limiters/ RPM Limiter Fuel Cut, RPM Limiter Fuel Cut 2, Vehicle Maximum Speed Global
    5. Fuel Delivery Electronic/ Temperature Enrichment/ Fuel Adder for Catalyst Temperature
    6. Oxygen Sensor Targets
    7. Temperature Models/ Expected Catalyst Temperature/ EQ Ratio Base Comp Protection
    8. Torque Model/ Optimal Torque/ Transmission Throttle/ Transmission Shift Throttle Reduction 1,
    Transmission Shift Throttle Reduction 3
    9. Transmission Shifting/ Primary Engine Warm/ Downshift Schedule 1 to 2 Engine Warm
    10. Variable Valve Control/ Exhaust Camshaft/ Base Exhaust Valve Angle Target, Intake Camshaft/
    Base Intake Valve Angle Target
    Premium Fuel
    1. Spark Ignition Control/ Base Ignition/ Compensations/ Ignition Transient Retard for Valve
    Timing, and Port Injection Active/ Base Ignition Timing
  9. Nov 28, 2023 at 3:08 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    I appreciate the thought. I’m sure there’s plenty of local folks who would love to trade chrome for black. I don’t know why everyone hates chrome so much. I fukkin love it.
  10. Nov 29, 2023 at 6:55 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Tires balanced, no more 60mph vibration. I do feel a little something, but I think it’s brake related. I am planning to replace the brakes front and rear soon enough. Stopping power isn’t that great, and the front rotors are a bit grooved.
  11. Dec 8, 2023 at 10:07 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Here’s some fuel efficiency data. Now I’ll tune the truck and see what effect it has on efficiency.
  12. Dec 12, 2023 at 10:48 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Tuned my truck over the weekend. Went a little too saucy with the throttle response, so dialed it back last night, could use a touch more to be perfect. Once I get that dialed, I’ll start tracking fuel efficiency.
  13. Dec 17, 2023 at 2:17 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Finally got someone to trade me my black steps for their chrome steps. I dig it.
  14. Jan 4, 2024 at 1:49 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Replaced my front brakes this last Saturday. I can tell you right now that the person who previously did these brakes was a degenerate. Spring clips were broken, both passenger caliper bolts were loose, and one had trashed threads. Replaced one caliper bolt, and went to torque, it just kept spinning. Got new calipers for both sides from O’Reilly because the driver side piston boot was a little funky too. Brakes good now. I found the pad n rotor set on FB marketplace for $60, Raybestos R Line. I have the Raybestos element 3 on my wife’s 4Runner and they break like a mofo.
    Reddawg1100 likes this.
  15. Feb 2, 2024 at 11:47 PM
    Savmikey47
    Savmikey47 New Member
    Nice build
  16. Jun 27, 2024 at 8:01 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Forgot that I added Bilstein 5100 shocks front n rear. Set the fronts to the 2nd clip and now the truck sits almost totally level. Rear might be 1/8th” higher than front. The ride is much better, I assume that I was riding on the original factory shocks of 150k miles, so they were def toast.
  17. Jun 27, 2024 at 8:02 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Also since I’ve finally gotten the roof replaced on my house, and have the motor in my Tacoma now, I can start playing a little more with the mods on the Tundra.
  18. Jul 16, 2024 at 9:40 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Got on eBay and got the revosol steering wheel hydrodipped carbon fiber. Plus I picked up a fancy carbon fiber shift knob as well.
    Ceezurin and RobertD like this.
