Tire pressure overlay stuck on with digital cluster.
Discussion in '3rd Gen Tundras (2022+)' started by SoulzOfSinner, Nov 28, 2023.
  1. Nov 28, 2023 at 5:04 AM
    SoulzOfSinner
    SoulzOfSinner [OP] New Member
    It seems the overlay is stuck on don't know why, I did do a remote start here and the truck elapsed the 10 min mark before I got out to the truck this shows up even after shutting the truck off. 1794 with TRD Offroad 4x4 package. 20231128_023202.jpg
  2. Nov 28, 2023 at 5:58 AM
    Tom
    Tom New Member
    Is it still stuck after off on?
  3. Nov 28, 2023 at 6:21 AM
    SoulzOfSinner
    Was still stuck after off on and had to just drive to work with it, the tire sensor light did go away once the tires got warm from driving but that overlay is stuck on and it's not the normal tire menu its the idle/door open overlay from what I can tell. Still on when I got to work will check again after work.
  4. Nov 28, 2023 at 7:45 AM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2023 Tundra Platinum Hybrid
    Dobinsons IMS 2"/1", BMS 1" Wheel spacers with OEM Platinum Wheels. Icon Sway Bar Spacer. 285/65/20 Firestone Destination XT Tires.
    I had a similar but different issue. My volume overlay stayed on similar to your tire pressure. It went away the next time I drove the truck.
  5. Nov 28, 2023 at 2:05 PM
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    What happens if you do the "reset" some are using to correct the false full gas tank readings?
    IIRC it was to shut off the truck while still in "Drive".
    Does that do anything?
  6. Nov 28, 2023 at 2:12 PM
    SoulzOfSinner
    The truck fixed itself I'm guessing probably from the deepsleep stated by Ryan and everything seems fine so far. I also had the volume overlay issue but it only happened once and haven't seen it since. 2023 MY
    ryanwgregg likes this.
  7. Nov 28, 2023 at 3:45 PM
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    This happens to me as well but usually the song title pop up when you change songs.
    ryanwgregg[QUOTED] likes this.
  8. Nov 28, 2023 at 5:38 PM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    Same for me, went away after a couple minutes. Only happened once in the several months I've had it
  9. Nov 29, 2023 at 11:59 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    I don’t have digital dash but sometimes I’ll get tpms warning for overinflated and not under inflated.:confused:
