Blue Ribbon 4x4 Build Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueRibbon4x4, Jul 25, 2020.
  1. Nov 24, 2023 at 10:33 AM
    #1171
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
    Well I decided to go back to the horizontal stripes for the turn signals. In person the vertical ones make the headlights look kinda cheap. So we’re ready to seal everything up. Had a test last night and everything works, just got one shot of the demon eyes on. The plethora or harnesses, and the headlamp graveyard.
    Y0TA PR0, Patch999, coldwiz and 3 others like this.
  2. Nov 24, 2023 at 3:47 PM
    #1172
    BlueRibbon4x4
    Geno
    Well, this is what happens when I overthink. Once the headlight bezels got installed in the lenses (the bezels go in the lens and the lens onto the housing), you can’t actually see the blank open area of the striped diffuser. So they got swapped out again, back to the vertical stripes, as I ultimately want these to look much different than I had before. Everything needs to dry again, so they’ll get sealed up tomorrow.
  3. Nov 24, 2023 at 10:36 PM
    #1173
    BlueRibbon4x4
    Geno
    Here they are. Vertical stripes, final decision!!
    Y0TA PR0, jeffw6236, Ryuu and 3 others like this.
  4. Nov 25, 2023 at 8:14 PM
    #1174
    BlueRibbon4x4
    Geno
    Finished!!! The demon eyes got wired to the rock lights, and the shroud LEDs are disabled when the headlight comes on. IMG_9486.jpgIMG_9488.jpgIMG_9493.jpgIMG_9494.jpgIMG_9510.jpgIMG_9511.jpgIMG_9513.jpgIMG_9515.jpgIMG_9509.jpgIMG_9517.jpg
  5. Nov 25, 2023 at 8:34 PM
    #1175
    RobertD
    Robert
    DFW, Texas
    :headbang::headbang:
    Sweet!!!
  6. Nov 25, 2023 at 8:50 PM
    #1176
    BlueRibbon4x4
    Geno
    Thanks!!! And thank you for talking me into keeping the vertical turn signals! I totally dig them.
    RobertD[QUOTED] and GODZILLA like this.
  7. Nov 27, 2023 at 4:31 PM
    #1177
    BlueRibbon4x4
    Geno
    One last thing. Color matched eyebrows. The old lenses has some brown forming on the tops, so they got sanded to 800 grit, applied blue then 2K clear.
  8. Nov 30, 2023 at 7:55 PM
    #1178
    BlueRibbon4x4
    Geno
    A picture showing the color matching eyebrow, the headlight output at 100 ft, and just one more of the DRLs. I’m just super happy with how they turned out. IMG_9536.jpgIMG_9537.jpgIMG_9540.jpg
    Tundra234, biebs96, GODZILLA and 2 others like this.
  9. Nov 30, 2023 at 8:00 PM
    #1179
    RobertD
    Robert
    DFW, Texas
    :yes:
  10. Dec 1, 2023 at 6:29 AM
    #1180
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    your final product is magnificent! They look amazing in the daylight but the night picture is even better. Amazing creativity!
    BlueRibbon4x4[OP] likes this.
  11. Dec 1, 2023 at 1:03 PM
    #1181
    BlueRibbon4x4
    Geno
    Thanks man! I appreciate the compliment.
    Mater likes this.
  12. Dec 1, 2023 at 4:37 PM
    #1182
    GODZILLA Ask me about my hot doc
    Dude. That's so epic. I really liked the previous horizontal lines on the turn signal, before you redid the lights this go around, but the verticals are super sharp. I can't say I like one more than the other. Both are so good, but not just the design choice, your paint skills are slick. They eyebrow is a nice touch that I've seen stick on cheap crap try to imitate, but this just looks custom and classy. You and @ElNopal need to get together and host a clinic on color matching. :bowdown:
  13. Dec 2, 2023 at 3:28 PM
    #1183
    BlueRibbon4x4
    Geno
    Thanks so much for the compliments, Adam!!
  14. Dec 3, 2023 at 5:57 AM
    #1184
    BlueRibbon4x4
    Geno
    Figured I would share a little tool corner for what I use for wiring and such. I have a Weller soldering iron I got at Home Depot, it’s been awesome. I keep it around the 4-5 setting for heat. I grabbed a set of tips off Amazon for super cheap and the threads fit nicely. The wire holders come in handy, and the game changer was the cordless soldering iron I recently got in order to swap a few connectors in the truck. The solder I have is a 60/40 5lb spool I got about 20 years ago from a wire warehouse I used to work in.
    Weller 40W Digital Soldering Station -WLC100 Black https://a.co/d/fsFXV1x
    Soldering Iron Tips 12 pcs 900M... https://www.amazon.com/dp/B086H1Y7WT?ref=ppx_pop_mob_ap_share
    NEIKO 01902 Adjustable Helping... https://www.amazon.com/dp/B000P42O3C?ref=ppx_pop_mob_ap_share
    FrogBro 11W 2500mAh Cordless... https://www.amazon.com/dp/B0BR6G8Q1C?ref=ppx_pop_mob_ap_share
    Heat shrink tubing is crazy cheap on Amazon, but I’ve gotten crappy ones that seemed too thin. I’ve been buying these and they’re great, with 3x shrinkage. The cheaper stuff usually is 2x shrinkage.
    Waterproof Heat Shrink Tubing Kit... https://www.amazon.com/dp/B08SQHH9NS?ref=ppx_pop_mob_ap_share
    The two and three lead waterproof connectors I usually get are these ones, requiring a solder joint. I also have a set that you can build, which are nice because you can build them in a tight space in the truck, or just depin the connection and make a bigger one if needed. I have seen other types similar to the ones Diode Dynamics uses up for sale now. If you’re familiar with them, they’re a super solid connection. The tiny connectors are great for the tiny wire connections, like single LEDs.
    NAOEVO 3 Pin Connector... https://www.amazon.com/dp/B092ZCM9VK?ref=ppx_pop_mob_ap_share
    LanHong 2 Pin Way Car Waterproof... https://www.amazon.com/dp/B01F54PFLE?ref=ppx_pop_mob_ap_share
    BTF-LIGHTING 20 Pairs 2pin SM JST... https://www.amazon.com/dp/B01DC0KHM0?ref=ppx_pop_mob_ap_share
    My hands-down favorite tool are these Klein flush cutters. Trimming wire, cutting zip ties flush, trimming plastic when needed, they’re just super sharp and cheap enough to replace when needed.
    Klein Tools D275-5 Pliers, Diagonal Cutting Pliers with Precision Flush Cutter is Light and Ultra-Slim for Work in Confined Areas, 5-Inch https://www.amazon.com/dp/B000GTMZHG
    These self adjusting strippers are awesome, but recommended for larger wire. The smaller wire has thinner stranding, and these will take a few with it.
    Klein Tools 11061 Self-Adjusting Wire Stripper / Cutter, Heavy Duty, for 10-20 AWG Solid, 12-22 AWG Stranded, and Romex Wire 12/2 and 14/2 https://www.amazon.com/dp/B00CXKOEQ6
    I have these for stripping small wires and various crimping, but I do need a better set for crimping while building harnesses.
    Klein Tools 1010 Multi Tool Long Nose Wire Cutter, Wire Crimper, Stripper and Bolt Cutter Multi-Purpose Electrician Tool, 8-Inch Long https://www.amazon.com/dp/B0000302WX
    I have this tiny butane torch, not the larger one. But it works great for heating shrink tube in the truck without heating anything else up nearby. It came with solder tips, but I wasn’t happy using it for that purpose as the heat was inconsistent.
    Bernzomatic Creator Torch Kit - Maker Precision Torch and Maker Detail Torch Bundle Completed with 3 Butane 5.6 Ounce Refill Cylinder https://a.co/d/0yoLifR
    Of course, everyone needs a 12v tester. I had a crazy old one for so many years. This LED one lights up bright and gives the voltage as well. But I’m always weary of voltage/heat/power ratings from a product like this. I’m not 100% sure that I like the clip yet on this yet, I may replace it with a different one.
    AWBLIN Automotive Test Light... https://www.amazon.com/dp/B09BFN8GT9?ref=ppx_pop_mob_ap_share
    Bappa, AthenaOffroad, Gecko. and 2 others like this.
  15. Dec 16, 2023 at 9:39 PM
    #1185
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    You got mad skills ! Looks bad A$$ :muscleflexing:
  16. Dec 17, 2023 at 5:49 AM
    #1186
    BlueRibbon4x4
    Geno
    Yo, thanks Rafael!
    Y0TA PR0[QUOTED] likes this.
  17. Jan 6, 2024 at 9:24 PM
    #1187
    Nic146
    Nic146 New Member
    Probably stuck somewhere
    2016 Barcelona Red TRD CM
    I’ve been a quiet admirer for some time now…love all your retrofit lights.
    I have been going through the last few pages closely and I can’t seem to figure out my answer.
    How are those thin red DRL’s lit? Is it a LED tube light? Or is it just a couple LED’s projected into it?
  18. Jan 6, 2024 at 9:31 PM
    #1188
    BlueRibbon4x4
    Geno
    Thanks so much! There are two LEDs lighting each bar. One on each end, the LED lights ip the end of the clear bar, and the bar carries the light. That’s why they don’t light up uniformly.
    RobertD and Nic146 like this.
  19. Jan 6, 2024 at 9:36 PM
    #1189
    Nic146
    Nic146 New Member
    Interesting…wouldn’t have guessed that…but it does make sense.
    That’s super helpful. Thank you…!
  20. Jan 6, 2024 at 9:38 PM
    #1190
    BlueRibbon4x4
    Geno
    No problem! :thumbsup:
    Nic146 and RobertD like this.
  21. Jan 20, 2024 at 4:04 PM
    #1191
    BlueRibbon4x4
    Geno
    I’ve just recently heard that the PCV valve needs replacing every 30,000 miles (the numbers are all over). But a faulty one can create pressure in areas of the engine where there shouldn’t be, creating small leaks. The most popular one being a rear main seal leak. People have reported their main seal leak went away after replacing it. I have a small rear main seal leak. Not enough to drip but just a seepage. So I just bought one, (Toyota, $12). After a super quick YouTube video, the job took 10 minutes. Needed a 22mm deep socket, but I used an 7/8” 02 sensor socket because it’s all I had and it fit. We’ll see about the seal leak, but I actually think the old one was functional, as I could hear the piston moving in it still.
  22. Jan 24, 2024 at 6:57 PM
    #1192
    BlueRibbon4x4
    Geno
    Air upgrades! Moving up to 3/8” line to the new schrader valves at each wheel well. At the moment I have just one quick connect at the rear bumper on 1/4” line. The goal is to get air to each tire and have just four short fill lines to carry. The larger line and splitters will hopefully put less stress on the compressor, which has overheated while trying to fill a second set of tires. This happened twice while it was over 100° outside, but I’m sure the snall line didn’t help.
    Florida AF, Sean492, RobertD and 3 others like this.
  23. Jan 24, 2024 at 7:38 PM
    #1193
    Between your build and @reywcms "flying truck" build, I can't keep up lol.
  24. Jan 24, 2024 at 7:42 PM
    #1194
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    this is on my short list. are you putting a receiver tank in there anywhere?
  25. Jan 24, 2024 at 7:55 PM
    #1195
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    lol I feel like the UPS guy and I have been fighting he hasn’t been around as often lol.
  26. Jan 25, 2024 at 5:39 AM
    #1196
    BlueRibbon4x4
    Geno
    Oh, I don’t think there’s matching @reywcms. Just following his build is like having another build. :rofl:
    reywcms likes this.
  27. Jan 25, 2024 at 5:42 AM
    #1197
    BlueRibbon4x4
    Geno
    I’ve thought of this, but I really wonder how big of a tank I would need to be beneficial for 4 tires. I assume it’s just a basic volume equation that I’m too lazy to figure out. But I also figure that I do have a line running to the rear and I’m keeping the bumper quick connect. So a quick add-on tank wouldn’t be too difficult. Where were you thinking of putting one?
  28. Jan 25, 2024 at 6:17 AM
    #1198
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    We’ve got a big tank in the old man’s rig and I can confirm not really beneficial. Spend more time waiting to fill the tank rather than the tires. I run my ARB and fill all four no issues and it doesn’t take long at all.
  29. Jan 25, 2024 at 6:27 AM
    #1199
    BlueRibbon4x4
    Geno
    Sweet, thanks for the input! I have a Smittybilt under the hood I’ve been using and it’s great. :thumbsup:
    reywcms[QUOTED] and HulkSmurf14 like this.
  30. Jan 25, 2024 at 7:13 AM
    #1200
    RainMan_PNW
    Casey
    Clark County, WA
    Good to know
