Rebuilt 2005 GX470 Project + random E46 M3 and JK updates
Discussion in 'Lexus GX Builds' started by M3Tundra-JK, Oct 23, 2023.
  1. Nov 21, 2023 at 5:46 PM
    #211
    Azblue
    The Dirty T ( ^_^)_且
    Disconnect the battery, put the ground of the welder as close as possible to the weld area. Also do small welds, I assume you will mig weld, do a series of small tack-style welds alternating areas. It won't look like a bead of stacked dimes, but you do have a grinder, right? And that grinder can generate enough heat to warp shit too, just keep it in mind.
  2. Nov 22, 2023 at 1:09 PM
    #212
    M3Tundra-JK
    M3Tundra-JK [OP] New Member
    Scott
    2005 GX470
  3. Nov 22, 2023 at 1:20 PM
    #213
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  4. Nov 22, 2023 at 1:48 PM
    #214
    M3Tundra-JK
    Scott
    2005 GX470
    After wire wheeling and degrease cleaning. About to do.the metal prep and then paint
  5. Nov 22, 2023 at 2:23 PM
    #215
    M3Tundra-JK
    Scott
    2005 GX470
    Old vs New rear sway bar end links
    + $40
  6. Nov 22, 2023 at 2:38 PM
    #216
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Aren’t you glad that’s not in your lungs.
  7. Nov 22, 2023 at 2:55 PM
    #217
    M3Tundra-JK
    Scott
    2005 GX470
  8. Nov 23, 2023 at 5:10 PM
    #218
    M3Tundra-JK
    Scott
    2005 GX470
    After POR15
  9. Nov 23, 2023 at 5:28 PM
    #219
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Nice^^^:)
    M3Tundra-JK[OP] likes this.
  10. Nov 24, 2023 at 4:29 AM
    #220
    e30cabrio
    Great work!
  11. Nov 24, 2023 at 9:34 AM
    #221
    M3Tundra-JK
    Scott
    2005 GX470
    Black@Blue19, b6graham and RobertD like this.
  12. Nov 24, 2023 at 12:49 PM
    #222
    M3Tundra-JK
    Scott
    2005 GX470
  13. Nov 24, 2023 at 2:40 PM
    #223
    M3Tundra-JK
    Scott
    2005 GX470
    POR15 kit I've been using
    e30cabrio and Black@Blue19 like this.
  14. Nov 24, 2023 at 2:41 PM
    #224
    M3Tundra-JK
    Scott
    2005 GX470
    And basic wire wheels on an impact drill
    e30cabrio, T-Rex266 and Black@Blue19 like this.
  15. Nov 24, 2023 at 3:01 PM
    #225
    M3Tundra-JK
    Scott
    2005 GX470
    Highly considering an Alibaba Tesla style Head Unit. I know there's Aurcar and Pheonix that sell them, but they're twice the price. And tbh, don't look as good as this one. I'd rather do the Joying Android HU, but you have to convert from NAV to Non-NAV HVAC controls and extend the wiring. That ends up costing more than the Aucar/Pheonix prices because you have to source your own factory HVAC control unit used.
    https://www.alibaba.com/product-det...offerlist.normal_offer.d_title.519b4e072Tx3os
  16. Nov 24, 2023 at 5:28 PM
    #226
    M3Tundra-JK
    Scott
    2005 GX470
    1, 2, 3 on the rear crossmember
    Fobroader, RobertD, e30cabrio and 4 others like this.
  17. Nov 25, 2023 at 4:31 AM
    #227
    e30cabrio
    Awesome progress!
    M3Tundra-JK[OP] and Black@Blue19 like this.
  18. Nov 25, 2023 at 5:12 PM
    #228
    M3Tundra-JK
    Scott
    2005 GX470
    Spare tire carrier crossmember done
  19. Nov 26, 2023 at 11:08 AM
    #229
    M3Tundra-JK
    Scott
    2005 GX470
    Old OEM Rear Lower Control Arm vs New SPC Performance Control Arm w/xAxis Sealed Flex Joint
  20. Nov 26, 2023 at 1:34 PM
    #230
    M3Tundra-JK
    Scott
    2005 GX470
    Ran out of foil, but cling wrap seems to work even better! Well, unless the metal prep spray melts it lol. We'll see!
    Doing POR15 to rear passenger side Lower Control Arm, shock, and spring perch mounts
  21. Nov 26, 2023 at 2:10 PM
    #231
    M3Tundra-JK
    Scott
    2005 GX470
    Kinda hard to get in all the tight places, but this is after the metal prep. Drying before the POR15 paint
    e30cabrio, AZTundra and Black@Blue19 like this.
  22. Nov 26, 2023 at 2:33 PM
    #232
    Black@Blue19
    Ken
    SE Texas
    You are all in it that’s for sure! Keep on keepin on. :)
  23. Nov 26, 2023 at 4:05 PM
    #233
    M3Tundra-JK
    Scott
    2005 GX470
    Ordered a rear OEM Track Bar. Cheaper than the adjustable ones after the BF discount. And I'm only lifting 1" so no real need either.
    + $210
    e30cabrio, Brownsfanhere and T-Rex266 like this.
  24. Nov 26, 2023 at 5:11 PM
    #234
    M3Tundra-JK
    Scott
    2005 GX470
    After
    Fobroader, RobertD, e30cabrio and 2 others like this.
  25. Nov 27, 2023 at 11:13 AM
    #235
    M3Tundra-JK
    Scott
    2005 GX470
    While my transmission crossmember really isn't bad, I couldn't pass up this FB deal.
    + $60 for brand new crossmember. Cheapest blackfriday dealership deal I could find was $140
  26. Nov 27, 2023 at 11:34 AM
    #236
    M3Tundra-JK
    Scott
    2005 GX470
    Some other goodies just arrived!
  27. Nov 27, 2023 at 11:41 AM
    #237
    M3Tundra-JK
    Scott
    2005 GX470
    Still deciding on what size tire to put on it. Since I'm going with the smallest lift possible, I'm thinking in the 31" range. 285's (32.7") will easily fit, but also stuffed in there. I'm going to wait until the rear suspension is done before deciding. Plan is to set the rear adjustable hight springs to the lowest setting. Then, go back and adjust the front to be level.
  28. Nov 27, 2023 at 12:46 PM
    #238
    M3Tundra-JK
    Scott
    2005 GX470
    Old vs New Rear Upper Control Arm.
  29. Nov 27, 2023 at 1:15 PM
    #239
    M3Tundra-JK
    Scott
    2005 GX470
    Got the BBS wheels sold. Super disappointed with that buy but lesson learned
    RobertD and Black@Blue19 like this.
  30. Nov 27, 2023 at 1:17 PM
    #240
    Black@Blue19
    Ken
    SE Texas
    Seems to be working out with all the Things… :)
