2017 brake controller
Discussion in 'Towing & Hauling' started by homesteader, Apr 7, 2019.
  1. Apr 7, 2019 at 6:00 PM
    homesteader
    homesteader [OP] New Member
    I'm new here; hope I'm not being redundant:
    I'm thinking of buying at a 2017 Tundra, 5.7l, 4wd, double cab. I'm seeing complaints about the factory controllers on newer models. Is the problem only with 2018 models, or are any older models having problems. I live 6 hours from the nearest Toyota dealer and I sure as heck don't want to have trouble right away with the brake controller.
  2. Apr 7, 2019 at 6:11 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    My 2016 had bad issues, could not get enough brake power, Toyota came out with a TSB in 2017 that greatly improved it braking performance. You need to check with a toyota dealer so see if was done to your truck.
  3. Apr 7, 2019 at 6:27 PM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    I've been researching this and it seems the general consensus is that Factory brake controllers are problematic for all makes and models of vehicles. Not exclusive to Toyota. Good news is it should be a relatively easy and fairly cheap fix to replace them with a Tekonsha P3 or other aftermarket controller. The p3 runs about $150 or so....
    JohnLakeman likes this.
  4. Apr 7, 2019 at 7:34 PM
    homesteader
    HTGreen: Thanks; I'll check on that.
    TacoWuzzaTurd: Thanks.
  5. Apr 8, 2019 at 3:39 PM
    shimloom
    shimloom New Member
    2016 Ltd crewmax
    I have a 2016 and tow a 25 ft trailer, dry weight is 5952. I seem to plenty of breaking with my factory controller. In fact I have it at the lowest setting. It has several option based on the truck trailer break systems.
    Y0TA PR0 likes this.
  6. Apr 8, 2019 at 3:41 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
  7. Apr 8, 2019 at 3:46 PM
    homesteader
    Thanks for this. Most unhappy people comment, while the satisfied ones usually do not, hence a skewed response to queries.
    I have been researching and watched a video on the switch to the Tekonsha P3 and I will probably get one since it is so simple to change, especially with the ready made cable and bracket available. However, since my first tow will be with an empty 2000 lb trailer, I'll probably tow it with the factory controller just for a test.
  8. Apr 8, 2019 at 3:48 PM
    Racingjohndeere55
  9. Apr 8, 2019 at 3:52 PM
    homesteader
  10. Apr 8, 2019 at 3:56 PM
    Racingjohndeere55
    6 hours from the closest toyota dealer?
  11. Apr 8, 2019 at 3:57 PM
    Racingjohndeere55
    I can drive from here to Richmond va in 6 hours
  12. Apr 8, 2019 at 4:03 PM
    homesteader
    Racingjohndeere55: OK, I get it now. Yeah, through the mountain pass and all; speeding a little I can make it in 5 1/2 hours, if the road is dry.
  13. Apr 8, 2019 at 4:05 PM
    TacoWuzzaTurd
    Scottsdale AZ
    Just to be clear it seems that Model year matters. The 2018 and 2019 seems to be the problem year.
  14. Apr 8, 2019 at 4:09 PM
    homesteader
    Racingjohndeere55: NEPA = Northeast Pennsylvania? I guess it's not the National Environmental Policy Act. I once lived in Horseheads, NY. Close, no?
    Racingjohndeere55 likes this.
  15. Apr 8, 2019 at 4:13 PM
    homesteader
    TacoWuzzaTurd: Good to know, but with the replacement bracket and panel availability for the 2017, I suspect they have some trouble too. Unless the 2017, 18, and 19 are all the same fit. In any case, I'll probably get the Prodigy eventually; it seems like a more responsive unit.
  16. Apr 8, 2019 at 4:19 PM
    Racingjohndeere55
    What's a general location.
    :rofl:um, no.... yeah, I'm southwest of scranton. Used to go to HH when I worked for Acme markets
  17. Apr 8, 2019 at 4:21 PM
    Racingjohndeere55
    Either you live in Alaska or north Canada or Peru
  18. Apr 8, 2019 at 4:36 PM
    homesteader
    Racingjohndeere55: I live on the Southern Kenai Peninsula, 1/2 hour East of Homer, AK. Only one road to Anchorage where the Toyota dealer is located.
  19. Apr 8, 2019 at 4:42 PM
    Racingjohndeere55
    :eek2::headbang: I will make it to Alaska some day... don't have real id makes it tough to travel between states without papers......:poking:
  20. Nov 26, 2023 at 4:24 AM
    rodl12
    rodl12 New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    I understand this was a software update. How would the update be done?
