D/S Lean
Discussion in '1st Gen Tundras (2000-2006)' started by itsWarrior, Nov 24, 2023.
  1. Nov 24, 2023 at 12:32 PM
    itsWarrior
    itsWarrior [OP] TEQ_Toothless
    Luke
    North Georgia
    Toothless the 06 Tundra SR5 DC RWD
    Bilstein 4600s, Leveled, LT265/70R17 A/T Tires, Lighting, Cosmetic stuff, Stickers and Morale Patches, Recovery Gear
    Hey everyone!
    I'm in the process of ordering everything I need for a (mostly) proper 3" lift for my truck. I'm getting Bilstein 5100 with OME 2885 to get about 2.5" and then possibly putting on 1/4" shims to get another 0.5" if needed to reach 3". I've heard about drivers lean on our trucks and just wanted to see how much lean yall were getting on the DC after a 2.5"-3" lift. Trying to figure this out ahead of time so I can compensate for it.
    Thanks!
  2. Nov 24, 2023 at 1:01 PM
  3. Nov 24, 2023 at 2:12 PM
    flyfisher
    flyfisher Member
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    Left side battery, driver, gas tank together might create a little lean, but hardly noticeable.
  4. Nov 24, 2023 at 2:44 PM
    itsWarrior
    Luke
    North Georgia
    I think I’ll just order everything and then just adjust later if the lean is super noticeable
  5. Nov 24, 2023 at 3:24 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Put some purple drank in the radiator, hopefully she’ll lean the other way and balance out
  6. Nov 24, 2023 at 4:14 PM
    Sizzzzzippin on syzzzzruuup....
  7. Nov 24, 2023 at 7:49 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    I doubt you’re going to get 2.5” with 2885’s with a dc. Why not 2887s?
  8. Nov 24, 2023 at 7:52 PM
    itsWarrior
    Luke
    North Georgia
    We had decided that 2887 (a 700lb spring) would probably be too harsh on a RWD DC in my previous thread.
    I’m always open to other opinions. I’m trying to get to 3” after everything settles
  9. Nov 24, 2023 at 9:22 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I just bought some 885s for my 5100s. Haven’t installed them yet. I was thinking about going one clip up on the drivers side to overcome the lean. :notsure:
  10. Nov 25, 2023 at 4:56 AM
    Elevatorguy
    James
    The 85 and 87 are the same spring rate, It’s not 700. First gen off-road says the 87s will lift a 2wd dc 2.5”.
  11. Nov 25, 2023 at 7:48 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Here is a screenshot I took of the coil info.
  12. Nov 25, 2023 at 7:58 AM
    itsWarrior
    Luke
    North Georgia
    thank yall so much for the info @Elevatorguy and @TX-TRD1stGEN
    I was originally planning to get 5100 with 2887 to shoot for 3" but was told by a couple members that the 2887s would be too much for my 2WD DC. What do yall think I should do to get to that height? I'm open to input and ideas
  13. Nov 25, 2023 at 8:10 AM
    itsWarrior
    Luke
    North Georgia
    And heres some screenshots I tookScreenshot 2023-11-25 at 11.04.55 AM.png Screenshot 2023-11-25 at 11.05.11 AM.png
  14. Nov 25, 2023 at 8:35 AM
    That looks like the selector system from BilsteinLifts aka SuspensionLifts. You need to take its output with a grain of salt. What members have found here would suggest they tend to over-shoot their estimates by a solid half-inch in either direction. In the case of those numbers, I think they're probably 1/2" to 3/4" higher than reality even for the 4WD AC.
    Solely for context, it may be helpful to catch the original thread: https://www.tundras.com/threads/lift-and-wheels-sanity-check.133061/
    It'll also take out some of the 'telephone game' factor out of prior commentary on it. Would love to see your input over there as well.
  15. Nov 25, 2023 at 8:37 AM
    itsWarrior
    Luke
    North Georgia
    @shifty` haha thank you again sir. I'll make sure to return to that thread, I thought i had responded last but I just realized I didnt. Life has been crazy recently. Apologies
    shifty` likes this.
  16. Nov 25, 2023 at 1:18 PM
    Elevatorguy
    James
    Are you lifting it just for looks and bigger tires?
