Jump Starting Another Vehicle
Discussion in '3rd Gen Tundras (2022+)' started by tcap23, Oct 18, 2023.
  1. Oct 26, 2023 at 11:43 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    You'd want an 8.0 or 12.0 battery if you want to air up 35s. But this compressor will do it, no problem
  2. Nov 24, 2023 at 8:35 PM
    Breathing Borla
    Northern Illinois
  3. Nov 24, 2023 at 9:04 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I've been using this cheapie jumper to start my work van Nissan nv200, it starts it easy, and didn't have to recharge it for 3-4 jump starts.
    And I've also used my Tundra to jump the van at least a dozen times, so far nothing broke, but sounds like it's a bad idea...
    GIMFOOM Jump Starter, 4000A Car Battery Jump Starter with Wall Charger (10L Gas & 10L Diesel Engines), 12V Jump Starter Battery Pack with 3.4 Inch Smart Display, Jump Box with 400 Lumens LED Light https://www.amazon.com/dp/B0CB7H12GD
  4. Nov 24, 2023 at 9:06 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I've been reading noco brand reviews and there's always some hit or miss ones, and noco is more expensive than other jumpers.
    So since reviews were mixed anyway, I just went with the cheapie $60 jumper that had same mixed reviews. So far so good
  5. Nov 25, 2023 at 5:26 AM
    Breathing Borla
    Northern Illinois
    I’ve never had a problem with Noco stuff, so with the sale and higher watt usb c output I thought it was a good deal
  6. Nov 25, 2023 at 6:45 AM
    racer01
    racer01 New Member
    Geoff
    Aiken South Carolina
    23' TRD Pro
    295/70-18 Nitto Recon Grappler, RB 20 running boards
    Well.....back to original question I used my 23' TRD Pro hybrid to jump a friend's car using the owners manual (used positive blade in fuse box under hood) and it worked just fine and nothing blew up. Went to a ground on the frame rather than whatever they are aiming you at for neg under the engine cover for the black jumper.
