2021 SR5 Alternator Fuse
Discussion in '2.5 Gen Tundras (2014-2021)' started by Scungil99, Nov 24, 2023.
  1. Nov 24, 2023 at 7:49 AM
    Scungil99
    Scungil99 [OP] New Member
    Hey guys, anyone know if there is a fuse that controls the alternator? Truck died on me driving home the other day and wondering if I can solve it easy. Thanks
  2. Nov 24, 2023 at 7:51 AM
    AZBoatHauler
    So.Arizona
    Alt-s fuse controls output. It’s in the fuse box under the hood.
  3. Nov 24, 2023 at 8:52 AM
    Retired...finally
    Curious if you have made any changes to your truck that involves the wiring?
  4. Nov 24, 2023 at 9:12 AM
    Scungil99
    Haven't done anything to it. It just died while driving home the other day and seems like an alternator problem. Came out of nowhere
  5. Nov 24, 2023 at 9:23 AM
    AZBoatHauler
    So.Arizona
    Under warranty? I’d think battery before alternator.
  6. Nov 24, 2023 at 9:28 AM
    Scungil99
    Was driving for an hour then it just happened.
    Not under warranty
  7. Nov 24, 2023 at 9:43 AM
    AZBoatHauler
    So.Arizona
    Well the battery is probably toast either way so I’d replace it and check voltage with the truck running.
  8. Nov 24, 2023 at 10:43 AM
    ConcordCarlos
    ConcordCarlos New Member
    Carlos
    2021 Tundra SR5
    Loose cable, positive or ground near the battery would be my guess. Battery itself is also a likely culprit.
    Did the truck die suddenly? Or start with dimming lights ands and warning lights flashing?
  9. Nov 24, 2023 at 1:08 PM
    Scungil99
    Died suddenly after driving for about an hour. It's prob a bad alternator
  10. Nov 24, 2023 at 1:12 PM
    AZBoatHauler
    So.Arizona
    The alternator is in a terrible spot so hopefully not.
  11. Nov 24, 2023 at 1:29 PM
    ConcordCarlos
    Carlos
    2021 Tundra SR5
    Do you have a volt meter?
    AZBoatHauler likes this.
