Ball Hitch
Discussion in '2nd Gen Tundras (2007-2013)' started by Albinator, Nov 23, 2023.
  1. Nov 23, 2023 at 8:15 PM
    Albinator
    Albinator [OP] SAINTRIOT
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    I have a 2008 Tundra 5.7 4x4 Crew. Since it can tow 10,200 lbs, do any of you know which ball hitch I can get for it? I’m not really finding any in the 10k lbs range.
  2. Nov 23, 2023 at 8:22 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I have one that came with the truck that's a curt hitch and ball if I'm not mistaken. I can look tomorrow morning if I remember. It says on it it's rated for 10k or 12k
    Albinator[OP] likes this.
  3. Nov 23, 2023 at 9:13 PM
    blenton
    blenton New Member
    Depends on the trailer coupler size. Most 2" couplers will be for 5k - 7k; 2 5/16" coupler can be rated up to 17k.
    I've used an Anderson RapidHitch for several years with a 2" / 2 5/16" combo and 6" adjustable drop/rise (adjusts in ~1" increments up and down). It is good up past 10k though the 2" ball is limited to 7k lbs if I'm remembering correctly. It has developed a bit of play so I prefer to use a Curt forged stinger with capacity around 16k lbs. Both of those hitches have seen some serious tongue weight and trailer weight. Neither have had issue.
  4. Nov 24, 2023 at 4:19 AM
    Albinator
    Utah
    Great info! I was wondering if 2” has a limit and if I would have to get the multi ball.
  5. Nov 24, 2023 at 7:21 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
  6. Nov 24, 2023 at 7:57 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Here's a pic of my hitch label and one of my balls:rolleyes:
    They came with my sequoia and/or my last tundra
    AZBoatHauler likes this.
  7. Nov 24, 2023 at 7:58 AM
    AZBoatHauler
    So.Arizona
    That’s a strong ball you’ve got.
    :muscleflexing:
    Fotnot[QUOTED] likes this.
  8. Nov 24, 2023 at 8:04 AM
    WBW
    WBW Resident lurker
    Bruce
    THOSE are legendary balls on this site!
    Mike59 and Fotnot[QUOTED] like this.
  9. Nov 24, 2023 at 8:39 AM
    Spoiler alert, your 4x4 CM is likely not rated for 10,200#. Closer to 8,800#. If you’re towing more than about 4000#, Toyota recommends a WDH and a trailer with brakes. The hitches for a WDH setup will be rated for heavier weights.
  10. Nov 24, 2023 at 8:48 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    It seems my reputation is still going strong ;)
    WBW[QUOTED] likes this.
  11. Nov 24, 2023 at 11:44 AM
    Albinator
    Utah
    This is the truck I have with the tow haul that shows the max weight. Am I misunderstanding it?
  12. Nov 24, 2023 at 12:28 PM
    Max is just that. Max for that body style. Any options the truck has subtracts from payload and towing. Check your door sticker
    Albinator[QUOTED][OP] likes this.
  13. Nov 24, 2023 at 7:07 PM
    blenton
    blenton New Member
    You are correct. Any options will subtract from that, but there aren't more than MAYBE a couple hundred pounds of options from the factory if every single box was checked when it was ordered. It wasn't until the SAE J2807 towing standard test was adhered to that we started losing serious capacity. My DC was derated to 9800 lbs... ;)
    Mike59 and Albinator[QUOTED][OP] like this.
  14. Nov 26, 2023 at 5:57 AM
    Albinator
    Utah
    What is a WDH?
  15. Nov 26, 2023 at 5:58 AM
    Albinator
    Utah
    Thanks! What does the red and black parts of the sticker say? I’m wondering if this is still an option to buy. I do have a 7,500 ball so I wasn’t sure if I should upgrade to a higher one or not.
  16. Nov 26, 2023 at 6:11 AM
    weight distribution hitch
    Mike59 likes this.
  17. Nov 26, 2023 at 7:43 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    That's a @ToyoMafia slap
  18. Nov 26, 2023 at 7:56 AM
    AZBoatHauler
    So.Arizona
    Critical equipment. Ball would only be half as strong without it.
    Fotnot[QUOTED] and KNABORES like this.
