2008 Tundra has no electrical power
Discussion in '2nd Gen Tundras (2007-2013)' started by kcwoerner30, Nov 22, 2023.
  1. Nov 22, 2023 at 6:43 PM
    kcwoerner30
    kcwoerner30 [OP] New Member
    Kennan
    Hi guys. This is my first post, but I’m hoping someone can help. My 08 Tundra has zero electrical power after attempting to start. I’ve checked the battery voltage and it read 12.89, so it appears the alternator is charging. I drove for a month with a brand new battery, but it refused to start today. I cranked it twice and the engine attempted to fire, then nothing. I have zero working lights on the dash and throughout the truck. Has anyone seen anything like this? Like I said, the battery has voltage, it’s just not getting to the rest of the truck. Thanks.
  2. Nov 23, 2023 at 7:28 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Any chance you new battery was ever hooked up backwards? Sounds like it could be a bad main fuse, no power to interior fuse box.
    Does it still crank or did you look power to the entire engine fuse box as well?
  3. Nov 23, 2023 at 11:24 AM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    Start with basics. Check connections for contact and corrosion. Check for stored codes. Check for a burnt fuse. Check voltage at power ports; should be close to voltage at battery terminals.
