  1. Nov 22, 2023 at 7:29 AM
    Meh, 5100s will do you fine. And cost-effective.
    The Black Mamba and Voss like this.
  2. Nov 22, 2023 at 7:32 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Not a bad idea, I'm loving my 6112's that i threw on a couple months ago. Especially if you get some good deals this week!
    Voss and OverSquareEng like this.
  3. Nov 22, 2023 at 7:37 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    FYI, the Quick struts have a much larger diameter shock shaft than the OEM’s.
  4. Nov 22, 2023 at 7:47 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Nice work man, I'm with you on a TON of stuff ive done, then learned better from (experienced owners... not necessarily from here) the "gentlemen" here :rofl:
    Voss likes this.
  5. Nov 22, 2023 at 8:03 AM
    oscardog86
    Southern California
    Thats true, i had 5100 front and rear for about 5 years before i upgraded to the 6112's and they worked great for me as well.
    Voss likes this.
  6. Nov 22, 2023 at 8:05 AM
    SateenC1
    SateenC1 Fossil
    Bob
    Lake Tapps Washington
    2004 Blue Marlin Pearl Tundra SR5 DC 4×2
    Bilstein 5100s, Helwig Swaybars and Helper Spring, Flowmaster dual exhaust, AfE Cold Air Intake, Dirty Deeds 12 hole 250cc Injectors, MSD Coils, Pedal Commander,Yakima bars and cargo box,17" wheels.
    I agree. The modern engine aesthetic with the big plastic covers doesn't do much for me. I'm old and I liked the simpler times when everything was there for you to see. There are exceptions of course. ;)
  7. Nov 22, 2023 at 8:06 AM
    OverSquareEng
    OverSquareEng New Member
    2006 Sequoia Limited 4WD
    How do the 5100 and 6112 compare? I've read the 6112 is little softer/smoother ride which is why I gravitated towards them. I'm mostly looking to level, and for something decent on the street and dirt roads/fire roads. I don't really have much "real" off-roading around me.
    Voss and oscardog86[QUOTED] like this.
  8. Nov 22, 2023 at 8:11 AM
    Rapid driving on fire roads? Generally smooth, washboard, rough as hell?
    I only ask because what I’d want for chunky/holy dirt roads is not the same as I’d want for predominantly smooth or washboard. Lots of washboard clay roads in the SE USA, at least south of I-16.
    oscardog86 likes this.
  9. Nov 22, 2023 at 8:26 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I don’t always rev it to 6k, except when I do donuts. It’s so smooth at 6k it’s astonishing.
    Just a quick donut and burn out to break in the new plugs and coils.
    I need to take advantage of the C1201 code while I can :rofl::bananadead:
  10. Nov 22, 2023 at 8:30 AM
    bfunke
    bfunke Tundra Curmudgeon
    I like my 4.7 on my 2000. The 5.7 on my 2018 has a stupid plastic shield. When I lifted it off, there was a ton of foam encrusted with mud dauber nests weighing probably 5 pounds.
    bmf4069, NUDRAT, Voss and 2 others like this.
  11. Nov 22, 2023 at 8:33 AM
    That’s perfect weight addition for added traction up front while in 4WD bro.
  12. Nov 22, 2023 at 8:41 AM
    oscardog86
    Southern California
    I would agree with what you read, however the 5100's reuse the stock spring, so those were my original ones. The 6112 gave me a whole new spring which was the 600ft/lb i believe.
    If youre just looking to level and do some dirt/fire roads the 5100s would probably be just fine.
    Also @shifty` brings up a good point on types of dirt roads. Washboard vs smooth. 5100s and 6112 are digressive shocks, so on washboard a Progressive shock would probably do better. I just slow down on the washboards or air down if its bad enough. Or I try to get up to a speed the smooths out the washboards.
    shifty` likes this.
  13. Nov 22, 2023 at 8:42 AM
    SateenC1
    SateenC1 Fossil
    Bob
    I cannot speak from first hand knowledge, and I'm sure the 6112s are just that much more effective in the harsher environment they are designed for. That being said, the 5100s are very good on washboard, gravel, Forest Service roads, and pulling a 20' camper trailer on the highway, which is all I require.
    Voss, shifty` and oscardog86 like this.
  14. Nov 22, 2023 at 8:44 AM
    oscardog86
    Southern California
    Yea the 5100s did great for me on that type of terrain for years, but the shear beefiness of the 6112 is pretty impressive for the price that they are. Definitely a large diameter shock that can move a lot of oil. Some of the others with that same size are 2-3 times the price.
    Voss and TX-TRD1stGEN like this.
  15. Nov 22, 2023 at 9:24 AM
    vst
    vst New Member
    Scott
    2005 DC 4wd
    I love my 6112’s I thought with them being digressive they would be harsh on the slower stuff but they’ve been really smooth. I had 5100’s along time ago on a Tacoma and I remember them being really harsh
  16. Nov 22, 2023 at 11:55 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    I loaded mine up with a load of dirt today. Definitely don't like the way the leaf springs are bending right now...
    bmf4069, KNABORES, oscardog86 and 2 others like this.
  17. Nov 22, 2023 at 12:04 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Mine do that too when I load up. Nice reverse curve. I’ll replace them sooner or later.
  18. Nov 22, 2023 at 12:11 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i was riding on bumpstops after 2 days (1200 miles) of a full camping load. But my soft shocks makes the truck avalon nice (with just the cap), so its a little fancier than a camry with a bed. Floats over rough roads with grace.
    oscardog86 and Voss like this.
  19. Nov 22, 2023 at 12:47 PM
    kentuckyMarksman
    I'm a bit bummed by the Avalon being discontinued. I settled for a Camry as my main family car. Wanted an Avalon though. During Covid lock down I didn't own a car, then after a year was told to go back to the office and had to buy a car on short notice. A Camry was what I could get for a decent price.
  20. Nov 22, 2023 at 1:03 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Its an es300 or 350 or whatever now, right?
  21. Nov 22, 2023 at 1:13 PM
    Dakillacore
    Georgia
    I agree. The last model that released was really, really good looking. Especially the TRD version. But it was booted to the curb to make way for the Crown's revival.
  22. Nov 22, 2023 at 2:06 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Xmas vibes
    Diablo169[QUOTED] likes this.
  23. Nov 22, 2023 at 2:10 PM
    Voss
    2003 AC TRD 4x4
    Lol
    bmf4069[QUOTED] likes this.
  24. Nov 22, 2023 at 2:13 PM
    Voss
    2003 AC TRD 4x4
  25. Nov 22, 2023 at 2:18 PM
    Voss
    2003 AC TRD 4x4
    I had 5100’s on the 1st notch with the stock TRD springs for a while. I’m no racer off-road but for what I did, on or off road was a good ride.
    Mr.bee likes this.
  26. Nov 22, 2023 at 6:30 PM
    oscardog86
    Southern California
    Hey guys, im starting the install of my Archive Garage medium duty leaf packs. Ive got one leaf spring out and was thinking of buying new bolts now that I think about it. The 3 main bolts per leafspring, (1 on each end of the leaf spring in the "eyelets" and the 3rd one in the shackle). Im having trouble finding them online to order. I know some of you guys are wizards at finding parts so figured Id see if any of you could help me with a part number or link for these. Thanks!
    Happy Thanksgiving everyone!
    NUDRAT likes this.
  27. Nov 22, 2023 at 6:35 PM
    I reused my oem, and whatever else came in the kit for the rest
    805Tundra and oscardog86[QUOTED] like this.
  28. Nov 22, 2023 at 6:41 PM
    oscardog86
    Southern California
    I was thinking id end up doing the same if i cant get the new bolts soon. But one of the bolts looked a little corroded. I might just try to clean it up and reuse it though. The others so far looked pretty good. Still gotta remove the passenger leafspring pack after I button up the driver side. Hopefully those bolts are in good shape too.
  29. Nov 22, 2023 at 6:53 PM
    oscardog86
    Southern California
    @FrenchToasty I got a question for ya since it sounds like you did this upgrade. Or really anyone else that has done leafsprings or and AAL.
    Ive only just removed the Driver side leaf spring and then called it quits for the day. But seeing as the new leaf pack is a little bigger and more arch, im thinking its kinda tight and ill need more room.
    So my question is, if i need more room out of the axle on the driver side, should i unbolt the rear driver side lower shock bolt to get extra down travel to fit the new leaf pack. Ive done an AAL before but cant remember if i removed the bottom bolts on the shocks to get extra working room. Thanks!
  30. Nov 22, 2023 at 6:56 PM
    oscardog86
    Southern California
    Edit: I think last time, i just lowered the floor jack thats under the rear diff and that allowed the unconnected side to droop and give me room. Im pretty sure this is a dumb question, but its bugging me that i cant remember what i did last time, haha
