  1. Nov 21, 2023 at 1:11 PM
    oscardog86
    oscardog86 New Member
    Southern California
    "Handfuls of orange chain saws and a quiver of orange KTM dirtbikes" I love that visual, lol
    bmf4069 and whodatschrome like this.
  2. Nov 21, 2023 at 3:12 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    This
    It's perfectly OK over Corroseal. In fact, if you look closely you can still see rust spots after your treatment. Rustoleum if you must, but Rust Encapsulator (or POR-15) is better.
    The link that I attached was for Internal Frame Coating. Maybe it didn't take...
    https://www.eastwood.com/eastwood-internal-frame-coating-14oz-aerosol.html
  3. Nov 21, 2023 at 5:21 PM
    Ordered 8 new coils and a maf off scamazon. Only $200! Score!
    CodyP, Voss and shifty` like this.
  4. Nov 21, 2023 at 5:22 PM
    Just kidding! Got them off rockauto. $542 bucks. Let's see if this fixes my "big block with a cam" idle.
    CodyP, Voss, JasonC. and 6 others like this.
  5. Nov 21, 2023 at 5:39 PM
    Speaking of which, how’s the kid’s Tree doing?
    NUDRAT likes this.
  6. Nov 21, 2023 at 7:18 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Sweet! Sounds like we’re dealing with the same thing. Did yours throw a code? I’m trying to get mine to clear naturally but it hasn’t yet and I’ve driven 300 miles. Running smooth as butter though with new Denso Plugs and Coils, oh, and Orange Valve Covers. :rofl:
    Besides, they now match my new dash colors. Nothing like rolling in the Holiday season like a Christmas Tree dash.
    Damn truck runs like a bat out of hell yet won’t clear the mis code P0308:bananadead:
    The Black Mamba, Voss, txagg and 5 others like this.
  7. Nov 21, 2023 at 7:20 PM
    bfunke
    bfunke Tundra Curmudgeon
    What happens if you swap the coil on 8 to another cylinder?
    Voss and KNABORES like this.
  8. Nov 21, 2023 at 7:28 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Well all 8 coils are brand new Denso, and I’m almost positive it isn’t missing, it is running so smooth, you can’t even feel it idle.
    Now that the ECM has disabled all my traction Nannie’s, she does an awesome burnout. Held her right at 6k smooth as butter. The 2UZ is very happy at high RPM’s. I think sounds better than an LS when it bounces off the rev stopper.
    txagg, oscardog86 and BroHon like this.
  9. Nov 21, 2023 at 7:33 PM
    SateenC1
    SateenC1 Fossil
    Bob
    Lake Tapps Washington
    2004 Blue Marlin Pearl Tundra SR5 DC 4×2
    Bilstein 5100s, Helwig Swaybars and Helper Spring, Flowmaster dual exhaust, AfE Cold Air Intake, Dirty Deeds 12 hole 250cc Injectors, MSD Coils, Pedal Commander,Yakima bars and cargo box,17" wheels.
    I like your orange valve covers. They provide some much needed life to what has to be (in my opinion) the dullest engine bay ever. Nice work. :thumbsup:
    oscardog86 and Diablo169[QUOTED] like this.
  10. Nov 21, 2023 at 7:36 PM
    You sir haven’t seen the third gen engine bay
    The Black Mamba and oscardog86 like this.
  11. Nov 21, 2023 at 7:48 PM
    Right right, that's why when I suggested it prior, I also mentioned while swapping #8 pack with #6 pack - because defects do happen! - also pull the #8 plug and give it a once-over. Maybe that plug is loose, or something hinky is going on with it, like maybe the spring from the old coil pack stuck onto the tip of the old plug and you're double-springing it? Again, stupid annoying shit that can happen but usually doesn't. And honestly, the backfire could be causing one or both of the other codes in reality... I think a few of us on here know someone that happened to with injectors, leaving behind an o-ring from an old injector, leading to double-ring action...
    Voss and Diablo169[QUOTED] like this.
  12. Nov 21, 2023 at 8:43 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I have never had my truck above 3.5k rpms. You rev yours to 6?
    oscardog86 and bmf4069 like this.
  13. Nov 21, 2023 at 9:05 PM
    Live a little
    txagg, Voss, oscardog86 and 1 other person like this.
  14. Nov 21, 2023 at 10:50 PM
    OverSquareEng
    OverSquareEng New Member
    2006 Sequoia Limited 4WD
    Clear naturally? Are you saying you haven't cleared the code after attempting a repair?
  15. Nov 22, 2023 at 12:10 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I cleared it immediately after I swapped in new coils, and instantly the P0308 came back. I drove it about 300 miles this week, and cleared the codes about an hour ago and drove it around, so far nothing popped back up.
    I also checked, and over about 1,000 miles I haven’t lost any coolant, so that’s good.
    I’m not sure I’m out of the woods. I haven’t tossed the old cheapy radiator that blew up on me. I took a look again at it, and literally the plastic looks like it dissolved from the inside out into like a graphite powered that was suspended in the coolant. I’m not sure if this sludge is trapped anywhere in the system.
    The radiator was on the truck when I got it, but just another reminder to only use OEM, Denso or Aisin parts.
    Voss, shifty`, oscardog86 and 2 others like this.
  16. Nov 22, 2023 at 5:33 AM
    Not sure if it has any codes. My check engine light is burnt out. I should probably buy some new bulbs for my dash and hvac too. Nice job on the powder coating; I wanna do mine eventually. It was only natural to do it on the SHOs.
    Diablo169[QUOTED] likes this.
  17. Nov 22, 2023 at 5:46 AM
    Pretty good. I forgot to take it down for the 6th year in a row so it was easy to put up.
  18. Nov 22, 2023 at 5:47 AM
    My normal shift point is 4k.
  19. Nov 22, 2023 at 5:57 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    I am not concerned about the engine, it’s the transmission I worry about.
  20. Nov 22, 2023 at 5:59 AM
    txagg, The Black Mamba, Voss and 3 others like this.
  21. Nov 22, 2023 at 6:12 AM
    SateenC1
    SateenC1 Fossil
    Bob
    You're right, I had not. It's definitely a big improvement over my First Gen. which is a great example of function over form.
  22. Nov 22, 2023 at 6:22 AM
    You cannot actually see the engine of most modern vehicles. The 3rd Gen is a web of hoses and tubes hiding a generally blah looking V6 engine underneath a plastic cover. Not that it really matters what it looks like, as long as it works.
  23. Nov 22, 2023 at 6:55 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Love that tree :thumbsup:
    I have that charger, pretty decent.
    Upgrading your memory?
    bmf4069[QUOTED] likes this.
  24. Nov 22, 2023 at 7:03 AM
    Sequoia.
    bmf4069[QUOTED] and BroHon like this.
  25. Nov 22, 2023 at 7:18 AM
    OverSquareEng
    Nearly finished, just have to button some things up and get the steering rack back in place.
    Fell free to make fun of me for the monroe quick struts, I bought them basically right after I got my truck (1 year ago) before I knew any better, because whatever was in there was on it's last legs... I know better now but I'm still cheap. If they really are that bad, hopefully it will motivate me to crack open my wallet for something nicer.
    Voss, Diablo169, BroHon and 4 others like this.
  26. Nov 22, 2023 at 7:19 AM
    Voss, BroHon, oscardog86 and 2 others like this.
  27. Nov 22, 2023 at 7:21 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    It came, it finally came! Only took an extra 2-3 months lol!
  28. Nov 22, 2023 at 7:26 AM
    Wait, why'd it take so long?!
  29. Nov 22, 2023 at 7:27 AM
    metalpete
    ID
    Had to come all the from Canada, ya hoser! Factory backorder, lead times, etc, etc.
    Funny thing, I was in Denver last weekend and was going to see if they had any on hand lol... but they were closed.
  30. Nov 22, 2023 at 7:29 AM
    OverSquareEng
    I am half hoping that they are so terrible that it motivates me to grab some Bilstein 6112's on sale for Black Friday.
    Voss and oscardog86 like this.
