6112s came in today and this is what I found
Discussion in '2.5 Gen Tundras (2014-2021)' started by Savmikey47, Nov 21, 2023.
  1. Nov 21, 2023 at 9:58 PM
    Savmikey47
    Savmikey47 [OP] New Member
    My 6112s came in today and the box looked really beat up. So I decided to inspect everything and this is what I found.
    emailed the the company I purchased from and waiting for a response.
    should I be concerned? Product looks used
  2. Nov 21, 2023 at 10:05 PM
    18" TRD Off Road Wheels
    Did you open the bag, or was it open when you received it?
    Either way, that's pretty beat up. Used or just rough shipping handling it's disappointing to see that kind of damage.
  3. Nov 21, 2023 at 10:05 PM
    737fixer
    737fixer New Member
    Concerned............................................Hell Yes. You have no idea what else was used and why did the previous customer return them. Paid for "NEW", give me F-ing new. I'd cancel the order completely and give someone else my business. Embarrassing.
  4. Nov 21, 2023 at 10:05 PM
    Savmikey47
    Sorry if I posted in wrong section. Still getting used to the forum.
  5. Nov 21, 2023 at 10:06 PM
    Savmikey47
    This how the other bag looked. Beat the hell up
  6. Nov 21, 2023 at 10:07 PM
    Savmikey47
    I found them really cheap at 739. While others were 800+
    now I wonder why
  7. Nov 21, 2023 at 10:08 PM
    Savmikey47
    Posted another pic. Bag was pretty beat up so I opened one. Didn’t bother with the other so I can send pics of it
  8. Nov 21, 2023 at 10:12 PM
    If you think it's in the wrong section you can hit the "report" button at the bottom of your own post, and then explain that you think it's in the wrong section and would like it moved. Mods are always helpful with this type of thing.
    If the bags were still sealed then I don't think you got anything used. It was either a quality control issue or it got handled rough in shipping. Possibly poor packing for shipping. Contact the seller, give them the chance to make it right. If they refuse, get a refund or contact Bilstein to see if they can offer any assistance. Don't fly off the handle all halfcocked like @737fixer is. These were obviously not used if the packaging is still sealed.
    blenton likes this.
  9. Nov 21, 2023 at 10:13 PM
    Savmikey47
    Yep. Looks like someone replaced some used to parts for new parts
  10. Nov 21, 2023 at 10:14 PM
    Savmikey47
    Yessir.
    Waiting for a response and I’ll let you know. Thanks
  11. Nov 21, 2023 at 10:48 PM
    blenton
    blenton New Member
    What do the shock bodies and piston rods look like? That existing damage to the mount itself is almost inconsequential from a function standpoint, but if the piston rod is damaged it WILL start to leak at some point.
    I've seen heavy boxes like that blow apart in shipping and they send a piece or two skidding across the shipping truck floor - or worse, the asphalt. That is also a possibility. They may very well be used as well; if you have a few pics of the shock bodies and springs, we would have better idea if they have been used or not. For example, DIY mechanics usually use a cheap spring compressor to assemble the shocks that mar the powder coated finish. This is usually pretty obvious to those of use who have assembled them before.
    Either way, that's a bummer. See what the seller will do for you. Do you mind if we ask where you purchased them?
  12. Nov 21, 2023 at 10:52 PM
    Savmikey47
    I purchased from off wheeler inc. the box was damaged but not enough to damage what was inside. The items looks more used than your typical carrier mishandling. The springs even have some gouges on them. I’ll snap more pictures tomorrow
  13. Nov 21, 2023 at 11:52 PM
    blenton
    blenton New Member
    Off wheeler inc? On Amazon or eBay? Or Wheelers Off-road? The latter is a reputable company and should do right by you.
  14. Nov 21, 2023 at 11:59 PM
    Savmikey47
    Wheelers off road . Com
  15. Nov 21, 2023 at 11:59 PM
    Savmikey47
    I’m still waiting for a reply so we shall see
  16. Nov 22, 2023 at 12:40 AM
    blenton
    blenton New Member
    I’ve purchased several things from them in the past - including 6112’s. Ha. They have always been good to deal with so I’m sure they will get back to you; however, it being a holiday Thursday they may be short staffed tomorrow.
  17. Nov 22, 2023 at 12:50 AM
    BlueGarden
    BlueGarden New Member
    Paducah, KY
    2002 Tundra Limited 4x4 4.7L
    That looks to me like someone previously bought and returned them after trying to install them.
    Plastic bags could have been replaced, so whether the bag was sealed is not a good indicator of whether it's been opened before.
