2024 limited off road OEM wheel offset ? transitioning to new wheel size/tire
Discussion in 'Wheels & Tires' started by packheavy, Nov 21, 2023.
  1. Nov 21, 2023 at 9:01 AM
    packheavy
    packheavy [OP] New Member
    My apologies. I can't find the answer. 100% newbie to this so any feedback is welcome. I don't want to order a tire and have too much poke.
    I have a 2024 TRD OR with 20" OEM black wheels. Tire size is 265/60R20 which are 32.5" tall and 10.5" wide. Does anyone know the offset for this wheel? When I run a plumbline straight down from the fender I have 1/2" of space.
    I prefer my tread blocks to be right at plumbline with the fender. The only part of the tire sticking out is the sidewall. The wheel I'm going with is RR6-H with zero set (17" wheel).
  2. Nov 21, 2023 at 9:05 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Your wheel offset and size should be stamped on the inside of the wheel.
    Something similar to this..
    Most Gen 2.5 wheels are +55 or +60 offset, not sure about your Gen 3
    kirkb and Saltyhero13 like this.
  3. Nov 21, 2023 at 9:12 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Looks to be +60 :thumbsup: upload_2023-11-21_11-11-30.png
    TundraNoob24 and Saltyhero13 like this.
  4. Nov 21, 2023 at 9:13 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    This will help figure out what offset you might want.
    kirkb and packheavy[OP] like this.
  5. Nov 21, 2023 at 9:33 AM
    packheavy
    That calculator is helpful. I'm trying to type and distracted by your hula girl. o_O
    TundraNoob24 and 1lowlife like this.
  6. Oct 21, 2024 at 7:49 PM
    Paul 19
    Paul 19 New Member
    Paul
    2024 Tundra Limited
    2" front level
    I also have a question? I have a 2024 tundra limited with a 2" level I want to use the original 20 inch rims am I able to fit a 35x12.50x20 tire? If not what would be the biggest I could go with ? Thank you Paul
