Joying Sequoia 2013
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by Sequoia Nick, Nov 19, 2023.
  1. Nov 19, 2023 at 9:18 AM
    Sequoia Nick
    Sequoia Nick [OP] New Member
    2013 Sequoia
    I just installed a joying unit on my 2013 sequoia with JBL. I have the correct harness. I can’t get the OEM backup camera to work. It identifies the reverse mode but the screen is blank as in no input. Also I was wondering if anyone knew how to connect the rear entertainment system. Thanks in advance fir any help.
  2. Nov 19, 2023 at 10:11 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Backup cam is usually yellow rca to yellow rca. I see you have done that on one, have you tried the other yellow rca?
    Factory connector plugs into the wire harness and that converts it to RCA, then plug that RCA into the one coming out of the joking hu
  3. Nov 19, 2023 at 12:56 PM
    Sequoia Nick
    2013 Sequoia
    Thanks for the help. Apparently it was a setting thing on the unit. Backup camera issue resolved.
    M3Tundra-JK likes this.
  4. Nov 20, 2023 at 6:48 AM
    zoomspeed05
    zoomspeed05 New Member
    marc
    2006 tundra double cab sr5 4WD
    What was the setting that needed to be changed?
  5. Nov 20, 2023 at 7:37 AM
    Sequoia Nick
    2013 Sequoia
    Here is the correct setting
  6. Nov 20, 2023 at 7:39 AM
    zoomspeed05
    marc
    thanks, im getting ready to install mine today. i appreciate it.
  7. Nov 20, 2023 at 7:45 AM
    Sequoia Nick
    2013 Sequoia
    I found the unit a bit wobbly after install so I used the factory brackets on the joying and it worked great.
  8. Nov 20, 2023 at 7:56 AM
    M3Tundra-JK
    Scott
    2005 GX470
    Ah, that's a newer setting. The AHD cameras are nice, Analog HD 720p. Not sure what the other camera formats are.
    Edit: CVBS is composit video baseline signal and supports resolution of 480 and 570p
    If you don't have the AHD backup cam, it's a good $20 upgrade
  9. Nov 20, 2023 at 8:05 AM
    Sequoia Nick
    2013 Sequoia
    Where do I get at AHD camera? Is it an easy install? Thanks
  10. Nov 21, 2023 at 7:29 AM
    zoomspeed05
    marc
    thanks, i got it installed with the brackets as well, changed the setting for the camera worked too but the oem camera quality sucks haha. i need to upgrade for sure.
  11. Nov 21, 2023 at 7:34 AM
    Sequoia Nick
    2013 Sequoia
    Agreed. Let me know if you find a good replacement.
  12. Nov 21, 2023 at 1:43 PM
    M3Tundra-JK
    Scott
    2005 GX470
    They sell them on Joyjngs website and Amazon. Just search Joying AHD backup cam.
  13. Nov 24, 2023 at 4:46 AM
    zoomspeed05
    marc
    question, does your steering wheel controls work? on mine only one button works.
